ZACHARYSBEADLE Posted April 18, 2016 Share Posted April 18, 2016 I just got myself a 2005 Legacy GT Limited, automatic (COMPLETELY STOCK) and wanted to know what are the first few upgrades I should get for more power/horsepower with my Legacy. Already purchased new brakes Link to comment Share on other sites More sharing options...
coldsoda Posted April 18, 2016 Share Posted April 18, 2016 all the preventative and needed maintenance you can afford 1st. check out the sticky threads here about banjos, then find a reputable tuner. set a budget, then start with keeping your tuner in the loop, since a protune is the best money you can spend, then when it comes to parts you will likely do the exhaust first (up pipe, downpipe), then from there things can start to add up. a new turbo is the next large jump in power after the exhaust, but with that comes quite a bit more extra parts. Link to comment Share on other sites More sharing options...
battelready Posted April 18, 2016 Share Posted April 18, 2016 What he said. Check out the build threads either here or the pictures section. You can get a good idea of what to start on. I bought an auto be more involved in my uninvolvedness . 200k+ Club If you can't blind them with brilliance, baffle them with bullshit. My high mileage turd. Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted April 18, 2016 Share Posted April 18, 2016 Read, read, read. It's as simple as that. There's a ton of build threads out there. See what others are doing and being successful with. Have a plan or some goals in mind. These cars don't do well with random mods, not in the engine bay at least. Just about every performance part will require a tune so if you if you can do it all in one shot that will save on tuning. As coldsoda said preventative maintenance above all else. Mistakes don't come cheap with these cars. To answer the question though, an Accessport (or laptop w/tactrix cable) for protune and up-pipe/downpipe combo seem to open these cars up nicely from stock. You'll wanna get rid of the catted up-pipe anyway for your turbo's safety, along with the banjo bolt screen filters. Good luck! Link to comment Share on other sites More sharing options...
Max Capacity Posted April 18, 2016 Share Posted April 18, 2016 How many miles on it ? A compression test might be a idea. These cars have been known to burn valves on the stock tune. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ttnio Posted April 18, 2016 Share Posted April 18, 2016 I just got myself a 2005 Legacy GT Limited, automatic (COMPLETELY STOCK) and wanted to know what are the first few upgrades I should get for more power/horsepower with my Legacy. Already purchased new brakes Welcome! I would put in a Cobb accessport. Good luck on your power. Don't forget to read the forum's topics. Link to comment Share on other sites More sharing options...
ZACHARYSBEADLE Posted April 18, 2016 Author Share Posted April 18, 2016 How many miles on it ? A compression test might be a idea. These cars have been known to burn valves on the stock tune. 70k miles Link to comment Share on other sites More sharing options...
Max Capacity Posted April 18, 2016 Share Posted April 18, 2016 Learn how to check the oil and keep it topped off. Cobb AP version 2 or 3 will be fine, if your good with a lap top get the cable and learn how to data log that way. It can be cheaper. I would drive the car for a while, learn how it feels and sounds before you spend a lot of money and then something breaks. Clean the MAF sensor and make sure the air filter is clean. Keep the stock cold air intake, its hard to beat until your way up in HP. You'll want to get the stock up pipe replace with a catless one, at that time you put on a 3" down pipe too, along with removing the banjo filter from the back of the passenger side head. Replace the turbo oil return hose too. My Tuner is www.tuningalliance.com contact him when your ready for a great safe tune. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
ZACHARYSBEADLE Posted April 19, 2016 Author Share Posted April 19, 2016 Learn how to check the oil and keep it topped off. Cobb AP version 2 or 3 will be fine, if your good with a lap top get the cable and learn how to data log that way. It can be cheaper. I would drive the car for a while, learn how it feels and sounds before you spend a lot of money and then something breaks. Clean the MAF sensor and make sure the air filter is clean. Keep the stock cold air intake, its hard to beat until your way up in HP. You'll want to get the stock up pipe replace with a catless one, at that time you put on a 3" down pipe too, along with removing the banjo filter from the back of the passenger side head. Replace the turbo oil return hose too. My Tuner is www.tuningalliance.com contact him when your ready for a great safe tune. So is a turbo-back exhaust straight from the headers to the mufflers? Why would you want to remove the banjo filter? Where can I get the oil return hose replaced? Thanks! Link to comment Share on other sites More sharing options...
coldsoda Posted April 19, 2016 Share Posted April 19, 2016 no... turbo back is from the turbo back to the mufflers. the header (called manifolds in the diagram below) is fine, but you'll want to consider changing out the up pipe that is between the manifold and the turbo. check out this diagram to make more sense of what we mean: http://legacygt.com/forums/attachment.php?attachmentid=62001&d=1231172289 here is more information on turbo failure and banjo / oil return line answers: http://legacygt.com/forums/showthread.php/turbo-failure-wiki-173358.html and: http://legacygt.com/forums/showthread.php/2-5gt-turbo-oil-supply-banjo-bolt-filter-removal-61689.html Link to comment Share on other sites More sharing options...
ZACHARYSBEADLE Posted April 19, 2016 Author Share Posted April 19, 2016 no... turbo back is from the turbo back to the mufflers. the header (called manifolds in the diagram below) is fine, but you'll want to consider changing out the up pipe that is between the manifold and the turbo. check out this diagram to make more sense of what we mean: http://legacygt.com/forums/attachment.php?attachmentid=62001&d=1231172289 here is more information on turbo failure and banjo / oil return line answers: http://legacygt.com/forums/showthread.php/turbo-failure-wiki-173358.html and: http://legacygt.com/forums/showthread.php/2-5gt-turbo-oil-supply-banjo-bolt-filter-removal-61689.html So up-pipe & turbo back is what i'd want to free up the car? Link to comment Share on other sites More sharing options...
Rhitter Posted April 19, 2016 Share Posted April 19, 2016 http://legacygt.com/forums/showthread.php/begin-modifications-your-legacy-gt-19037.html Have you read this thread? My OBXT build Link to comment Share on other sites More sharing options...
Merc6 Posted April 20, 2016 Share Posted April 20, 2016 So up-pipe & turbo back is what i'd want to free up the car? Up pipe and banjo free up the possibility of epic failure. People overuse epic but this isn't one of those times. Epic failure usually cost about $4k bare minimum to un ***k yourself. ^ no tune needed for that Turbo back will free up but downpipe you really need a tune for. Besides that, you should still be knee deep in 10 years of 4 gen posts. I skimmed though until epic failure happened. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Max Capacity Posted April 20, 2016 Share Posted April 20, 2016 I got my oil return from the dealer. But you can also use a high temp oil resistant hose from the auto parts store. When you see the old hose you'll understand why we say to replace it. It will be hard and close to cracking. Take a look through my click here link. Here's the service manuals. In the back of it there are flow charts on things work. http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tuning Alliance Posted April 21, 2016 Share Posted April 21, 2016 Replace your up pipe with a catless, and replace banjo bolts. Send us a PM and we can help you out on parts/tuning! -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
