thatlgt Posted March 24, 2016 Share Posted March 24, 2016 Sooooo I fucked up the sensor directly in front of the turbo on the tgv motor and I found a guy on eBay who is selling just the sensors alone... I was wondering if this is even possible because I was always under the impression that I would need to change the entire motor because I know the sensor is spring loaded and I didn't know they were sold separately. Does anyone have any idea if this guy is trying to rip people off or if the sensors alone will work and I could just replace it alone. Please help Link to comment Share on other sites More sharing options...
solidxsnake Posted March 29, 2016 Share Posted March 29, 2016 Not entirely sure, but I believe the complete sensor/motor assy is an '07+ thing. I believe the '05-06 model years have separate sensors and motors. Source: http://www.romraider.com/forum/viewtopic.php?f=40&t=3386 Link to comment Share on other sites More sharing options...
rang0 Posted March 30, 2016 Share Posted March 30, 2016 Have you looked into doing TGV deletes? I have an 05 LGT wagon. I had the same issue when I put in the VF52, the turbo was closer to that TGV sensor and I kept getting CELs that the TGV sensor circuit was running high. I decided to just have a local Subaru shop do TGV deletes, which entails removing the motors, sensors, and machining out the valves. No CEL. MOAR air. When I had that done they said I didn't need to be tuned for that, but I had my car tuned anyway (mainly due to the new VF52 though.) Link to comment Share on other sites More sharing options...
