Troll Boy Posted February 27, 2016 Share Posted February 27, 2016 I was hoping to get some help on a few engine issues. About 2 weeks ago my 2005 Subaru legacy 2.5 GT started showing a P0302 misfire code http://forums.nasioc.com/forums/images/smilies/mad.gif every 3-4 days or so, given it was my daily I hardly get on the throttle. Well i confirmed the cylinder is blown and have to rebuild the motor. Seeing as it is my daily with only a turbo back and a tune I was planing on just replacing the stock short block and getting the heads checked and machined and throw it back on. The main questions is does the STI short block bolt right up and have the same tune as the 2005 legacy/intake manifold/ and all other bits. Or if i get an sti short block will there be some other parts I need. I found a short block for 2,000 and was wondering if that is cheaper then getting a shop to rebuild the motor with stock parts? Second main questions is today my girlfriend was driving her 2005 Subaru Legacy 2.5 GT and hasn't been checking the oil, looks like the car shut off when driving so I suspected the motor seized. I throw a breaker bar on the main crack and tried to turn it once we got it home and it wont budge. Can her motor even be rebuilt? I'm assuming due to metal expansion that the short block is toast but I should be able to reuse her heads? Since I have both of our car broken atm I'm looking for the fastest, and cheapest method to get them back on the road and us to work. Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 27, 2016 Share Posted February 27, 2016 Both need at least short blocks. Your first question: The EJ257 bolts in place with everything from your EJ255. You should have the tune checked but if your tune was made when your engine was healthy, it should be quite close. Do the same on both cars. Link to comment Share on other sites More sharing options...
Troll Boy Posted February 28, 2016 Author Share Posted February 28, 2016 anyone else? Link to comment Share on other sites More sharing options...
Lafta Posted February 28, 2016 Share Posted February 28, 2016 Is this a troll? No? Ok. Listen to what JmP said, and do note there is no "fast and cheap method". Sorry. If it makes you feel better, you're not the only one. Link to comment Share on other sites More sharing options...
seanyb505 Posted February 28, 2016 Share Posted February 28, 2016 Honestly the faster and cheapest method is to buy two $2000 daily drivers for you and your gf. Because that is what it will cost to get one of your lgt's running if you go the short block route. Main question:Yes. STi short block will bolt up just fine. You can get one delivered for ~1800 from Heuberger Subaru (Colorado dealership that does online sales). In my quick calculations for what work I was comfortable with, I could piece a block together for ~1500. Up to you to determine if the savings are worth it. It definitely adds complexity to your new driveway paper weight project. Who did your tune? Call them up and ask what they would recommend if you use X block. (You'll need to have that figured out already) Second question: Make sure heads are okay. There had to be quite the oil leak or some serious neglect going on to run it dry of oil. If so, new short block. See above for compatibility and sourcing of new block. Take heads to Subaru capable shop, explain quite the oil leak/serious neglect, and ask for their opinion on rebuilding and reusing the heads. At the end of the day, both cars could end up costing 4000-5000 each just to get them back on the road. Fastest and cheapest way to get to work is to buy two $2000 daily drivers for you and your gf. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 28, 2016 Share Posted February 28, 2016 Read my click here link. I put a ej257 in my 05 wagon. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08 LGT Posted February 29, 2016 Share Posted February 29, 2016 It's only "cheap" if you're financially very well off. A rebuild costs $5000-6000 if you're paying for someone else to do it. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 2, 2016 Moderators Share Posted March 2, 2016 Quick point: you say you "found a short block for $2k." Not sure what that means, but you can get a brand new shortblock for less than that... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
nightmonkeygt Posted March 2, 2016 Share Posted March 2, 2016 Sorry to hear about your troubles with both LGTs buddy. I'd listen to what everyone has already said. There really is no cheap way of getting these cars back on the road. I mean, you could put a low mileage engine in it and call it a day. You'll save maybe a couple grand but it could end up costing much more in the long run if that motor fails too. Link to comment Share on other sites More sharing options...
Sgt.Gator Posted March 4, 2016 Share Posted March 4, 2016 The fastest and the cheapest is an engine from the wrecking yard. I just checked my local folks, they have 6 of 2005-2006 Legacy GT engines available from $2350 to $2700. Then you can take your time with the engines that are blown and go thru them rebuild one nice one. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
Troll Boy Posted March 4, 2016 Author Share Posted March 4, 2016 Decided to sell them both due to the time needed and other projects I'm currently doing around the house, thanks a lot for everyone's input. If I had the time I would have definitely rebuilt them. Link to comment Share on other sites More sharing options...
Sgt.Gator Posted March 5, 2016 Share Posted March 5, 2016 Decided to sell them both due to the time needed and other projects I'm currently doing around the house, thanks a lot for everyone's input. If I had the time I would have definitely rebuilt them. I'm curious how much you got for two LGTs with blown engines? Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
