Tehnation Posted February 20, 2016 Share Posted February 20, 2016 This is the only picture i could find http://www.ebay.com/itm/04-07-Subaru-impreza-WRX-STI-Crankshaft-sprocket-timing-gear-sprocket-/252280206154 its the timing sprocket that goes on crankshaft for timing belt, in front of oil pump. Mine is missing a couple teeth, anyone know if it will that effect the crank position sensor? I'm also looking for a silicone hose kit for my coolant lines and all the other hoses for intake. Does anyone have a complete set? Link to comment Share on other sites More sharing options...
MTBwrench Posted February 20, 2016 Share Posted February 20, 2016 It shouldn't have an effect on the crank sensor, as I believe that reads based off of a notch cut into the crank behind that gear. Someone correct me if I'm wrong. But, I would be real concerned about that gear missing teeth! If it was me, I'd just go to a junkyard and snag one, depending on how easy they are to get off. For silicone vacuum line: siliconeintakes.com m sprank had some venair ancilary hose kits at one time, not sure if he has any left. MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
Tehnation Posted February 20, 2016 Author Share Posted February 20, 2016 sorry forgot there's 2 sets of teeth, not the gears for the timing belt, those tiny narrow little teeth behind it! other than for the cps, i can't imagine what they are for! Link to comment Share on other sites More sharing options...
Tehnation Posted February 20, 2016 Author Share Posted February 20, 2016 siliconeintakes.com, seems like the way to go. I can replace most of the hoses on the engine for under 60 bucks. Most if not all of the hoses seem to be consistent sizes anyway. Time to get out my ruler. Anyone know what the back row of teeth that is actually touching the wooden table is for? Link to comment Share on other sites More sharing options...
Harsho1 Posted February 20, 2016 Share Posted February 20, 2016 Those teeth are the triggers for the crankshaft position sensor, VERY important to have all of them in the right places! missing or bent teeth could cause all kinds of problems from no start, to CEL to misfires, and so on. Link to comment Share on other sites More sharing options...
WahooNo2 Posted February 20, 2016 Share Posted February 20, 2016 mishimoto makes a good intercooler to throttle body hose and other silicone hoses too http://www.mishimoto.com/subaru-silicone-hose-kit-radiator.html Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 20, 2016 Moderators Share Posted February 20, 2016 I have a new crankshaft sprocket to go on. If you want my old one I'll sell it off cheap. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
TheMonaLisa Posted February 20, 2016 Share Posted February 20, 2016 If you have money to spend, Samco makes some really high quality hoses. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Tehnation Posted February 20, 2016 Author Share Posted February 20, 2016 Found it!! Subaru Part Number 13021AA141 http://www.heubergersubaruparts.com/Subaru-Part-Number-13021AA141-p/13021aa141.htm $25 is lowest price dealership would sell. Link to comment Share on other sites More sharing options...
Tehnation Posted February 20, 2016 Author Share Posted February 20, 2016 If you have money to spend, Samco makes some really high quality hoses. Sent from my iPhone using Tapatalk http://www.siliconeintakes.com/silicone-boost_vacuum-hose/?osCsid=48be7769015e3fa33375e1d8f9977859 "Temperature Compatibility: -65F to 350F Maximum Working Pressure: 65 PSI Burst Pressure: 300 PSI" The radiator hoses look up to the task and then some, a hose is a hose imo. As long as I have no kinks in the line. I'm rebuilding my block atm and spending 200-300 on hose kits, when I have this option around, its a done deal. I can get new valve springs with the money I save from doing it this way. Link to comment Share on other sites More sharing options...
