Junn0626 Posted February 13, 2016 Share Posted February 13, 2016 Hey everyone. First of, I have 08 LGT 5eat with Cobb catless downpipe and Friend of mine told me not to install the intake before I buy the AP, but just decided to install the Cobb Sf intake since it's been laying around for months collecting dust.. However I was wondering if you guys can give me any suggestions on what to do next, What I should consider doing next.. Because it's my first car and first time doing anything with A car.... I need some guidance. Your help would be deeply appreciated! Thanks in advance!! Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 13, 2016 Share Posted February 13, 2016 You need a tune with that intake and downpipe yesterday. If you are going to buy an AP get it now and have it overnight shipped and DO NOT drive your car until you have the AP and have flashed the stage 2 with sf intake map. Also Cobb does not make a catless downpipe so you must have a cobb high flow catted or you have another brand downpipe. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
BrianEarlSpilner Posted February 13, 2016 Share Posted February 13, 2016 ^this listen to this! The ecu's on these cars are really only designed to work with stock parts. They have to be tuned for literally every change. Read up, save up, and do all your engine mods/tune at the same time. Link to comment Share on other sites More sharing options...
Junn0626 Posted February 13, 2016 Author Share Posted February 13, 2016 Thanks again for the replies guys! But... Aww f....After I installed the intake last night, I've been driving it around and I have to take the car out tomorrow! BTw, speaking of DP... the previous owner had the Cobb DP installed and told me it was catted. However after I brought it back home, the check engine light went on. And all the mechanics that i had visited in the past, told me there was no cat. So I figured I have catless DP. Then, the last mechanic I went to stated under description that the "module software corrupted" and "found DP improperly constructed 02 sensor bung in wrong place, cut out "Cat" and bung and invert to correct problem." I asked him so do I have a cat or not and he said no..... I'm confused.. After driving 70miles or so, the check engine light came back on. Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 13, 2016 Share Posted February 13, 2016 Post some pictures of your exhaust and we will be able to tell if you have a cobb downpipe and if it has had the cat deleted or not. It would be in your best interest to at least put the stock intake back on and do your best to stay out of boost while driving if this is your only car. Where are you located? You haven't filled out your profile entirely but if you are local to some other members they may be able to help you out with some open source tuning rather than accessport tuning while you wait for an accessport to ship and arrive to you. I know cryotune offers the accessport with a custom tune for your car for a very reasonable price as well as other vendors/tuners on this forum. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Junn0626 Posted February 14, 2016 Author Share Posted February 14, 2016 Link to comment Share on other sites More sharing options...
magnusonsubie Posted February 14, 2016 Share Posted February 14, 2016 The cat in Cobb DP's is in the lower section I believe. Not sure what I am listening for in the video you posted 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
08 LGT Posted February 16, 2016 Share Posted February 16, 2016 The cat in Cobb DP's is in the lower section I believe. Not sure what I am listening for in the video you posted I think he has the key on the accessory position, and the noise is that electrical humming. My car doesn't sound like that, but it's also hard to tell from a cell phone video since those microphones aren't that great. Link to comment Share on other sites More sharing options...
apexi Posted February 16, 2016 Share Posted February 16, 2016 The buzzing sound is normal, it's the drive by wire throttle body. You can hear the sound at 2:22 in the video below Link to comment Share on other sites More sharing options...
Junn0626 Posted February 16, 2016 Author Share Posted February 16, 2016 Yes, that's the sound that I was I referring to. And thankss! Link to comment Share on other sites More sharing options...
POWERPRO Posted February 16, 2016 Share Posted February 16, 2016 Sorry to inform you that there is no OTS map for 08-09 model year w/ intake. I found out the hard way as well. Never installed my intake though. Link to comment Share on other sites More sharing options...
ragman Posted February 17, 2016 Share Posted February 17, 2016 My advice would be to put the stock intake back on, and sell the Cobb Intake. And get a stage 2 tune asap. In the meantime, keep off the throttle 95%. Link to comment Share on other sites More sharing options...
Junn0626 Posted February 17, 2016 Author Share Posted February 17, 2016 Oh..my..god.... Then I have to go ahead and buy stock intake?! When I purchased the car the previous owner had knN.. That needed to be replaced Link to comment Share on other sites More sharing options...
POWERPRO Posted February 17, 2016 Share Posted February 17, 2016 Yes, I would recommend locating a stock intake and using an OEM style filter. You can use the intake, but you would need to source a custom tune @ $200+. Do some searching on this forum, intakes and tuning have been discussed many times before. This is not the type of car you can just throw parts at, do some reading. Link to comment Share on other sites More sharing options...
ShadowImg Posted February 19, 2016 Share Posted February 19, 2016 Stock means stock. Otherwise you need to take the car to a tuner and have an appropriate tune done. Listen to the advice given, your motor will fail, and soon. Cobb DID in fact make a catless downpipe, you could have a very old catless one, you'd need to climb under the car and check. Regardless, you need a tune for that car, or your motor is done. Every time you drive it like this you're playing russian roulette, except you've only got 4 cylinders. Link to comment Share on other sites More sharing options...
Fasemelta Posted February 19, 2016 Share Posted February 19, 2016 From that link you provided " For your convenience, the SF Intake system is compatible with The Cobb Stage 1 and Cobb Stage 2 OTS (off the shelf mapping) provided with the Cobb AccessPORT ECU device." You have to buy an Accessport to use their tune and as powerpro stated earlier the ots map they provide is not for your model year. Bottom line - that intake requires a custom tune. Go stock.... Link to comment Share on other sites More sharing options...
ShadowImg Posted February 19, 2016 Share Posted February 19, 2016 You should maybe contact AZP, they used to be a vendor on here, not sure if they still are. AZP Mike I think it was? They can probably sort you out. http://azpinstalls.com/web/ Link to comment Share on other sites More sharing options...
coldsoda Posted February 20, 2016 Share Posted February 20, 2016 I'll only be repeating like a broken record... but you really should just return the cobb intake, and get a stock intake. even if you do get tuned for the intake, you aren't gaining anything but a little extra noise. Thats fine if thats what you want, just don't expect that to add any real power. The stock intake system on the car is actually pretty good and not the first bottleneck you will run in to. A custom tune will be worth the investment after you get the cobb AP. Link to comment Share on other sites More sharing options...
Junn0626 Posted February 20, 2016 Author Share Posted February 20, 2016 Thanks guys for all the advices. I went ahead and bought the AP and received it last night. And have decided to stick with stock intake. If you guys can post some links for the website where I can buy the stock intake, that'd be greattt Link to comment Share on other sites More sharing options...
GTTuner Posted February 20, 2016 Share Posted February 20, 2016 Drama Queens......technically you can drive it just don't get into any boost. Link to comment Share on other sites More sharing options...
ragman Posted February 20, 2016 Share Posted February 20, 2016 Thanks guys for all the advices. I went ahead and bought the AP and received it last night. And have decided to stick with stock intake. If you guys can post some links for the website where I can buy the stock intake, that'd be greattt http://legacygt.com/forums/forumdisplay.php/member-classifieds-2005-2009-30.html Link to comment Share on other sites More sharing options...
