rzgibbs Posted January 19, 2016 Share Posted January 19, 2016 Hey guys relatively new to the forums, lurking for a few months. I have a 5eat 05 gt with a recently rebuilt motor that had a cell die on the battery over florida vacation. After replacing the battery the car had a noticeable loss in power, so I did some troubleshooting. I bought a GS TMIC, a new BPV, and a new samco bpv hose (due to what appears to be leaks in all three), as well as ziptied and checked many of the vacuum hoses after a homemade boost test. None of this affected the loss in power. I did some data logs of acceleration and it seems my MAP only makes it to atmospheric pressure, and I hear no turbo spooling, though I'm not sure how loud it will be as it is the stock turbo. My max MAF reading has been 72 g/s Any thoughts? could my wastegate be stuck open?accelmap.csv Link to comment Share on other sites More sharing options...
rzgibbs Posted January 20, 2016 Author Share Posted January 20, 2016 bump. any suggestions? Link to comment Share on other sites More sharing options...
covertrussian Posted January 20, 2016 Share Posted January 20, 2016 What's your IAM/DAM at? If you replace the battery ECU is reset and stays at 0.500, which will result in loss of power until it goes back to 1.000 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
rzgibbs Posted January 20, 2016 Author Share Posted January 20, 2016 I have a bluetooth obdII for this car that doesn't have IAM/DAM. What you see in the data log is all I am capable of doing at the moment.I do have the ross-tech cable for my 2.7tt, but I think that takes some tweaking that I don't want to get into at the moment, since I'll buy an AP at some point. That being said, I don't believe the learning would be preventing boost completely, like these logs suggest, but I confess a certain newbie ignorance to subarus. Link to comment Share on other sites More sharing options...
rzgibbs Posted February 3, 2016 Author Share Posted February 3, 2016 Bought a tactrix cable and the ensuing logs confirmed it as most likely a boost leak. Used a fog machine, then took the inlet hose off and this is what I found. http://i.imgur.com/L8Qc0nP.jpg?1 Link to comment Share on other sites More sharing options...
rzgibbs Posted February 25, 2016 Author Share Posted February 25, 2016 For an interesting end to this problem (it didn't end up just being the inlet hose) please see my other thread on RomRaider. http://romraider.com/forum/viewtopic.php?f=15&t=12493&p=117744#p117744 Link to comment Share on other sites More sharing options...
2005_gli Posted February 26, 2016 Share Posted February 26, 2016 and I hear no turbo spooling, though I'm not sure how loud it will be as it is the stock turbo ive always been curious on this. can you hear the stock turbo, with stock intake, stock intercooler, and stock turbo back exhaust? im having some issues with lack of power as well, i dont have a boost gauge installed yet. noticed i couldnt hear the turbo spooling (which i can hear on every other turbo car ive owned). its a new turbo, so i shouldnt be too worried. unless i have clogged cats causing the issue, and thats causing the lack of power and back pressure keeping it from spooling? its possible to have clogged cats and not throw a code isnt it? Link to comment Share on other sites More sharing options...
covertrussian Posted February 29, 2016 Share Posted February 29, 2016 These cares are very quiet stock (they are catered to the grown up who don't want to hear the cars), I don't remember hearing my turbo stock either. Why was the turbo replaced? There is a good chance that your banjo filters are clogged and are starving the new turbo. If you have an OBD2 reader like Tactrix or cheap ebay one, you can use romraider to see what boost your hitting without a boost gauge. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
RckyMtnGT Posted March 1, 2016 Share Posted March 1, 2016 Wow, pieces of cat stuck in the turbo? No bueno! Get that up-pipe cat out of there, or at least whats left of it. If that was the extent of the issues, then I'd count myself pretty lucky. Hope the rest of it didn't harm anything. Props for sticking it out and figuring that one out. How's it running now? Link to comment Share on other sites More sharing options...
2005_gli Posted March 1, 2016 Share Posted March 1, 2016 These cares are very quiet stock (they are catered to the grown up who don't want to hear the cars), I don't remember hearing my turbo stock either. Why was the turbo replaced? There is a good chance that your banjo filters are clogged and are starving the new turbo. If you have an OBD2 reader like Tactrix or cheap ebay one, you can use romraider to see what boost your hitting without a boost gauge. When I bought the car, it has a knock. Thought it was timing belt tensioner but still heard it...sounded like it was coming from cold side of turbo, so I pulled the turbo. It has some slight shaft play, and thrust play so I replaced it (removed filters at that point) with an oem vf40. Still hear knocking, but that's a diff story lol. But yeah, just wondering if the spool was noticeable. Link to comment Share on other sites More sharing options...
rzgibbs Posted March 2, 2016 Author Share Posted March 2, 2016 Yeah rocky, I got really lucky that i didnt damage the turbo,(albeit cat pieces breaking off are unlucky to begin with) I spent a few hours knocking out the substrate in the uppipe and put a new (larger) turbo in and a GS bcs. Set wgdc to 0 and my first wot pull was 289 g/s with no knock on otherwise stock ROM. Have to dial in the wgdc for ramp up and probably tune the boost a point or two higher on the top end, since the new turbo isn't capable of making 10 psi @ 5800 (bare minimum @ 0 wgdc is 12.5) Link to comment Share on other sites More sharing options...
