BryceBSM Posted January 12, 2016 Share Posted January 12, 2016 Hey everyone been a while since I posted. My buddy and I for the life of us cannot diagnose this problem. I have a 2.5i legacy 2006 manual. After dropping my son off at my parents place today I went to start the car again and it wouldn't start? But all signs pointed to I must have not pushed the clutch in all the way so I retried and nothing. For some reason I decided to put it in reverse and then try.... and it started no problem [emoji58] Ran a few errands thinking it was all in my head and to my surprise when I went to start it again It behaved the same!!!! So again.... I put it in reverse and low and behold it starts. [emoji56] I have only one CEL for a bad o2 other than that the car has 319xxxkm with a full engine rebuild at 289xxxkm . Appreciate any help or insight! Cheers Sent from my SM-N910W8 using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted January 12, 2016 Share Posted January 12, 2016 Guessing something to do with a bad neutral switch or clutch switch. Not sure if there is a neutral switch on the MT trans or not, as far as I know, there is only a reverse switch. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
fedaykin Posted January 13, 2016 Share Posted January 13, 2016 Well my 5th gen seems to only care about the clutch switch... Maybe some weird thing is happening to your clutch switch signal, which putting in reverse fixes? WHUT? Link to comment Share on other sites More sharing options...
NORULZleggy Posted January 13, 2016 Share Posted January 13, 2016 I am not sure about this, but the switch I would replace. From Subaru it not that much. I had one done on my 04 STI and had a similar problem. My STI would not start often. I replaced the switch, and the cruise control one cause my cruise control would just stop working also. try that, in the mean time put it in reverse to start it and keep going till you narrow it down. Link to comment Share on other sites More sharing options...
DonnyJagaru Posted January 15, 2016 Share Posted January 15, 2016 Does the starter engage when in Reverse and your foot not on the clutch? Link to comment Share on other sites More sharing options...
GEE-OTTO Posted January 16, 2016 Share Posted January 16, 2016 Your clutch switch is under the kick panel remove the access panel to that area use a light and see if anything is obstructing it. It is a cheap replacement/test to see if the OEM one is in fact foul. Link to comment Share on other sites More sharing options...
