Kolbyk2k8 Posted January 5, 2016 Share Posted January 5, 2016 I have a question and not sure if this is the right place. I have a magnaflow catback with an invidia catless uppipe and a catless downpipe. I want to get my car louder with more of a rumble. I'm not very knowledgable when it comes to headers so is that my next step? Link to comment Share on other sites More sharing options...
Holla Posted January 5, 2016 Share Posted January 5, 2016 Try disconnecting the mufflers before you spend any more money. I'm not sure what your lgt knowledge is but I'd highly recommend reading up on the preventive maintenance before being too concerned about the way the cars sounds. There's some good info floating around about headers too. Link to comment Share on other sites More sharing options...
Kolbyk2k8 Posted January 6, 2016 Author Share Posted January 6, 2016 Thank you! Link to comment Share on other sites More sharing options...
coldsoda Posted January 6, 2016 Share Posted January 6, 2016 I would not recommend headers... that will not change volume as much as you would want. You will want to find a louder catback system if more sound/rumble is what you are looking for. find a large open can design and that should do the trick. Link to comment Share on other sites More sharing options...
Kolbyk2k8 Posted January 13, 2016 Author Share Posted January 13, 2016 I would not recommend headers... that will not change volume as much as you would want. You will want to find a louder catback system if more sound/rumble is what you are looking for. find a large open can design and that should do the trick. Thanks! Link to comment Share on other sites More sharing options...
KRM Posted January 13, 2016 Share Posted January 13, 2016 Nameless muffler deletes? Link to comment Share on other sites More sharing options...
KRM Posted January 13, 2016 Share Posted January 13, 2016 Please delete. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 13, 2016 Share Posted January 13, 2016 Are you sure you want it louder ? Do you want every Cop to hear you coming ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
