1-3-2-4 Posted September 21, 2015 Share Posted September 21, 2015 So the current one I have on the car is this AVO one but I want to switch for one is the metal part is missing for the BPV.. but my biggest question is how does the MAF and airfilter connect because the last owner seemed to just cut with a hacksaw and stuck the plastic part in the filter and it causes a issue with the hood stay in which I have to lay it over the intake manifold. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 4, 2015 Author Share Posted October 4, 2015 bump Link to comment Share on other sites More sharing options...
whitrzac Posted October 4, 2015 Share Posted October 4, 2015 Is that a stock airbox that's been modified for use with a cone filter? I would suggest replacing it with a non ghetto intake first. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 4, 2015 Author Share Posted October 4, 2015 yeah the last owner hacked it up to fit with the AVO but since I'm getting the perrin what do I need to make it work with the stock MAF and filter? Link to comment Share on other sites More sharing options...
whitrzac Posted October 4, 2015 Share Posted October 4, 2015 So your getting a different FMIC/TMIC and want to run the stock airbox. Correct? You need a stock airbox + snorkel + post maf hose(silicone ebay ones are ~$30) + hardware if you don't have anything laying around. If your going TMIC you will need a few additional parts as well, brakcets, TB hose, etc. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 4, 2015 Author Share Posted October 4, 2015 Not sure where I said anything about my intercooler.. I dont want to run the stock box I'm just asking how it connects to the end of the inlet for the perrin Link to comment Share on other sites More sharing options...
Covious Posted October 4, 2015 Share Posted October 4, 2015 stock box uses a rubber "S" hose that clamps onto the plastic stock inlet Perrin inlet has a metal ring that you clamp the inlet and the "S" hose to In your situation, seems like you would be using the same method as with the AVO above, clamping the inlet over the plastic end. If you end up with an aftermarket intake that uses a metal or hard plastic tube, it will come with a silicone coupler that you would clamp one end onto the intake ,and the other onto the metal ring that the inlet is clamped to. I think your fitment issue comes from the fact that tube the maf is in is much further over that it's supposed to be, as the "S" tube has essentially been deleted. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 4, 2015 Author Share Posted October 4, 2015 yep and that causes me not to put the hood stay in the right spot.. I just want to know if I get this I have what I need to have it set right. Link to comment Share on other sites More sharing options...
traildogck Posted October 4, 2015 Share Posted October 4, 2015 Perrin hooks up like this....the SPT "S" is just like the stock rubber one...right after the MAF tube in the stack air box. CKE SSP product information and sales : chris.ckessp@gmail.com Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 5, 2015 Author Share Posted October 5, 2015 Where can I get that SPT part from? Link to comment Share on other sites More sharing options...
traildogck Posted October 5, 2015 Share Posted October 5, 2015 Just the MAF tube? Best to get a used SPT intake off ebay or something. http://www.ebay.com/bhp/spt-intake I don't see any used ones right now. CKE SSP product information and sales : chris.ckessp@gmail.com Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 10, 2015 Author Share Posted October 10, 2015 I don't mind buying new Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Covious Posted October 10, 2015 Share Posted October 10, 2015 I mean, i personally would go for the new GS intake but heres a new spt one https://www.flatironstuning.com/p-1078-spt-high-flow-air-intake-system-for-the-2005-legacy-gt-and-outback-xt.aspx Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 11, 2015 Author Share Posted October 11, 2015 I mean, i personally would go for the new GS intake but heres a new spt one https://www.flatironstuning.com/p-1078-spt-high-flow-air-intake-system-for-the-2005-legacy-gt-and-outback-xt.aspx Which GS intake are you seeing? Link to comment Share on other sites More sharing options...
Rester5350 Posted October 11, 2015 Share Posted October 11, 2015 Here is a link to the group buy. http://legacygt.com/forums/showthread.php?t=245937 Link to comment Share on other sites More sharing options...
traildogck Posted October 11, 2015 Share Posted October 11, 2015 I would agree that the GS intake is very top quality. Everything they do is. I am very happy with every GS piece on Frank. I have a SPT (Subaru) and the MAF sensor is closer to the filter as well...just like the stock panel system. This GS GB is a good one. Jump if you are wanting to go in the new CIA direction. CKE SSP product information and sales : chris.ckessp@gmail.com Link to comment Share on other sites More sharing options...
