2005 subaru Posted August 26, 2015 Share Posted August 26, 2015 Just bought a 2005 Subaru Legacy GT. I dislike it and I want to sell it as soon as I find another Subaru that is more suitable for me. I feel every bump in the road and it's rattling my whole body frame. My mechanic says that the suspension does not need fixing - it has sport suspension and was designed that way. He recommended an outback for a smoother ride because the tires are about 3” higher. I’m looking for a 2005-2009 sedan version of an outback (nothing turbo). Do they exist? Impreza or Legacy is fine. I'd like to avoid SUVs.The only outbacks I’m finding are long wagons or sport wagons. I owned a sport wagon for 10 years and the ride was also bumpy. I would greatly appreciate the info. Thanks very much. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 26, 2015 Share Posted August 26, 2015 There are Outback sedans out there. Check on cars.com or autotrader or even on craigslist and see what you can find. You can easily change your suspension on the LGT though and make it ride as you would want it to. There is much information about suspension on these forums. Begin searching through google and it will bring up applicable threads on here that you can look at and find what could be the best combination for you. Good luck. Link to comment Share on other sites More sharing options...
08 LGT Posted August 26, 2015 Share Posted August 26, 2015 There are Outback sedans out there. Check on cars.com or autotrader or even on craigslist and see what you can find. You can easily change your suspension on the LGT though and make it ride as you would want it to. There is much information about suspension on these forums. Begin searching through google and it will bring up applicable threads on here that you can look at and find what could be the best combination for you. Good luck. The sedan outbacks were only made during the first or second generation, not the 2005-2009s. Link to comment Share on other sites More sharing options...
derp Posted August 26, 2015 Share Posted August 26, 2015 Sounds like you need a Buick or a Lincoln I could suck start a snow blower. Link to comment Share on other sites More sharing options...
Merc6 Posted August 26, 2015 Share Posted August 26, 2015 The sedan outbacks were only made during the first or second generation, not the 2005-2009s. I'm lost, are we saying this is a Unicorn in the wild? http://www.monumentmotors.com/wp-content/uploads/2011/03/05bloa148.jpg http://imganuncios.mitula.net/2005_subaru_outback_3_0_r_frederick_md_521273201875037.jpg http://www.subarucolors.info/wp-content/uploads/2011/05/2007-Subaru-Outback-3.0-R-L.L.-Bean-Edition-Sedan-1.jpg Sounds like you need a Buick or a Lincoln Older ones before like 03, the new Buicks are for the younger youthful crowd with super stiff suspension and rock hard leather seats. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
rmoore5 Posted August 26, 2015 Share Posted August 26, 2015 4th gen outback sedans might of all been 6 cylinders...maybe. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 26, 2015 Share Posted August 26, 2015 OP look into having the shocks replaced with something like stock replacement parts. It may have stiffer shocks. My wagon had a nice ride when new and for many years. I have my Koni's set on almost firmest setting, with Conti DWS tires it wasn't to bad. With the Pole Positions on it now, its a bit firmer. Tires will make big difference. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Holla Posted August 27, 2015 Share Posted August 27, 2015 You could also look into a 2.5i if you want a softer ride. It would be easier to find and probably less expensive than an outback sedan. Link to comment Share on other sites More sharing options...
2005 subaru Posted August 27, 2015 Author Share Posted August 27, 2015 I am not car savvy. Can you be more specific? What do I need specifically for a smoother ride? Tires? Springs? Struts? Shocks? Thank you in advance. Link to comment Share on other sites More sharing options...
Merc6 Posted August 27, 2015 Share Posted August 27, 2015 The 17's on the GT and 18's on the Shrek B make the ride harsh for those who complain like yourself. Smaller wheels and appropriate tire size in H rating to make the speedo correct will give you some softness. I'm running H rating tires on my GT but only because I was putting 2000 miles a month on it and oem tires wasn't lasting long. I kinda wish I had the 6 cyl truthfully at this point. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Trips Posted August 27, 2015 Share Posted August 27, 2015 My 2014 Liberty is the 3.6x version. It has 50mm (about 2") more ground clearance than the standard 3.6R. I don't know if these are an Australian only thing. Sent from my LG-H815 using Tapatalk Link to comment Share on other sites More sharing options...
