GEE-OTTO Posted August 25, 2015 Share Posted August 25, 2015 That bung may be too low :eek:or you overfilled the sump. It doesnt flow a ton of oil so drainage shouldnt be an issues once the pump is running and pulling oil into the engine when stopped it could back up into the line and maybe the journals. Link to comment Share on other sites More sharing options...
aigochamaloh Posted August 25, 2015 Author Share Posted August 25, 2015 That bung is in an annoying spot. I may tap my original pan and swap the pans again. It's almost impossible to run the line with the exhaust manifold right there. I dunno how the previous owner ran it like that. So I've been stuck on that, plus work. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 26, 2015 Share Posted August 26, 2015 He didn't he probably just had the bung tapped on the bench and never installed or realized after installation and have up You should loosely mount the manifold and hey a good mock up for where the bung should go. Link to comment Share on other sites More sharing options...
aigochamaloh Posted August 28, 2015 Author Share Posted August 28, 2015 Well, I see how the past owner ran his lines. The used return line had a crunched and slightly braised section in it. It was where he ran it right past the motor mount and the exhaust manifold. I did the same thing. Dropped the up-pipe and exhaust manifold again, ran the oil line, then put everything back. I reused the same header wrap thing that AVO gives, but I'm using a brand new stainless steel braided line so I won't have to worry about it being right next to the exhaust. Bolted everything together, but the two 13mm bolts in the back of the up-pipe are a bear. My hand/wrench is too big to get in there to tighten it. Took off the alternator to get to the oil pressure sensor, it sits right next to the EJ25 stamping (GEE-OTTO, this is what you were asking for earlier). Just a couple things left and I can fire it up soon I hope. Need to put the intercooler on, run the turbo oil and coolant lines, then the other misc stuff I took off for everything. Almost there! http://i207.photobucket.com/albums/bb227/aigochamaloh/Legacy%20Turbo/0828150921b_zpsaogunb2w.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/Legacy%20Turbo/0828150921c_zpsucdu8ek2.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/Legacy%20Turbo/0828150921_zpsn0z4ixti.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/Legacy%20Turbo/0828150921a_zps5xhbn9vv.jpg Link to comment Share on other sites More sharing options...
GEE-OTTO Posted August 28, 2015 Share Posted August 28, 2015 Ahh so you use the port for the oil pressure sending unit. Link to comment Share on other sites More sharing options...
aigochamaloh Posted August 28, 2015 Author Share Posted August 28, 2015 Well, I hooked up the oil supply line, as well as the coolant lines, and then cranked the car over a couple times with a video camera to watch the turbo. First 3 cranks, it's perfect and the turbo spins. Last crank, oil seeps out of the supply line. Looks like there's a kink in it and it failed. Will take the line off and get another one made at the local hose supply store. Anyway, here are pictures of the oil and coolant line routing. http://i207.photobucket.com/albums/bb227/aigochamaloh/0828151332_zpseclka591.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/0828151332a_zpsclv1j4yn.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/0828151332b_zpsjv0kwmel.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/0828151332c_zpscmzep5ap.jpg Link to comment Share on other sites More sharing options...
aigochamaloh Posted September 1, 2015 Author Share Posted September 1, 2015 Had a new oil supply line made and installed it today. Also took off the bumper beam and sat the intercooler behind. Just need to figure out the piping now. http://i207.photobucket.com/albums/bb227/aigochamaloh/Legacy%20Turbo/0901150805_zps8jxyhlhn.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/Legacy%20Turbo/0901151050_HDR_zpsd8mbl6sa.jpg Link to comment Share on other sites More sharing options...
Tommy Di Cat Posted September 2, 2015 Share Posted September 2, 2015 Any teflon tape or high temp thread sealant on those lines? Just wondering I have a spotty past lol. Link to comment Share on other sites More sharing options...
dgoodhue Posted September 2, 2015 Share Posted September 2, 2015 Any teflon tape or high temp thread sealant on those lines? Just wondering I have a spotty past lol. Those are -AN fittings and should NOT need teflon tape. Link to comment Share on other sites More sharing options...
1stick3pedals Posted September 2, 2015 Share Posted September 2, 2015 You finally went through with it haha. Good luck! I'm hoping to tidy up some things on my car this winter. I'm in the middle of swapping my outback right now so I don't know if I'll have the energy until next Spring. Let me know if you have any questions. I'll try and check in here once in a while! Idk if you did already but you might want to pull your ROM and get it defined at Romraider. They're pretty quick it seems these days. Link to comment Share on other sites More sharing options...
aigochamaloh Posted September 2, 2015 Author Share Posted September 2, 2015 Any teflon tape or high temp thread sealant on those lines? Just wondering I have a spotty past lol. Those are -AN fittings and should NOT need teflon tape. I did use Teflon tape anyway. The new line I had made is Teflon lined too. You finally went through with it haha. Good luck! I'm hoping to tidy up some things on my car this winter. I'm in the middle of swapping my outback right now so I don't know if I'll have the energy until next Spring. Let me know if you have any questions. I'll try and check in here once in a while! Idk if you did already but you might want to pull your ROM and get it defined at Romraider. They're pretty quick it seems these days. Yea man! Just trying to figure out intercooler piping. Sent my rom to AVO already, it's been defined already on RR. Link to comment Share on other sites More sharing options...
dgoodhue Posted September 3, 2015 Share Posted September 3, 2015 I did use Teflon tape anyway. The new line I had made is Teflon lined too. You really should not use Teflon tape on -an fittings. I would remove the Teflon tape and as is only going to hinder the sealing ability of the fitting. The Teflon may not allow for the fitting to fully seat (and seal) especially if you used a lot of it. Likely be fitting that those fitting connect to have a -AN to NPT adapter. Here is an example http://www.jegs.com/i/Aeroquip/023/FCM2008/10002/-1 The NPT thread on the right needs Teflon tape to seal. The -an thread on the left does not. At my last job we had pressure test tools, 99% of the time of the system was bleeding air pressure down, it was because someone used Teflon tape on the -AN fitting. The manufacturing assemblers used Teflon tape on the NPT fittings, so they made the assumption that the -AN fittings. Despite multiple training from the manufacturer manager and myself they continued to do it. I suspect they never understood the difference between the fittings. They used NPT threads on a daily basis while -AN thread fittings were used maybe once a month. Many of the engineers made the same mistake. Link to comment Share on other sites More sharing options...
gonzoman10 Posted September 17, 2015 Share Posted September 17, 2015 Really glad I found this post.. Was thinking about doing this to my 08! Could you put a parts total and stuff when the build is complete? I'm new to tuning so I want to see exactly what it takes. Link to comment Share on other sites More sharing options...
gonzoman10 Posted September 17, 2015 Share Posted September 17, 2015 Great to see another owner doing this project! Do you have a log of yours? Or part list? This would be a cool project for my 08 Legacy 2.5i Special Edition ej253 Link to comment Share on other sites More sharing options...
aigochamaloh Posted September 21, 2015 Author Share Posted September 21, 2015 Sorry, couple things on hold due to work hours and home shopping. Still gathering intercooler piping parts. Link to comment Share on other sites More sharing options...
aigochamaloh Posted September 28, 2015 Author Share Posted September 28, 2015 Surprisingly, things may be turning a different way. May be selling the Legacy to a friend and trading in the CVT WRX for a 6 speed to downsize my two cars to one so I can get a bigger car for our family later. Wifey's idea, love her. I'll be removing the turbo kit and putting it back for sale I suppose. Link to comment Share on other sites More sharing options...
vagabond Posted September 29, 2015 Share Posted September 29, 2015 Hmm Link to comment Share on other sites More sharing options...
aigochamaloh Posted September 29, 2015 Author Share Posted September 29, 2015 Hmm Hmm? Link to comment Share on other sites More sharing options...
vagabond Posted September 29, 2015 Share Posted September 29, 2015 Indeed Link to comment Share on other sites More sharing options...
aigochamaloh Posted September 30, 2015 Author Share Posted September 30, 2015 Yup, done deal. Picked up my 2016 WRX in Lapis Blue. Turbo being taken out of the Legacy and going back for sale. May try selling the Legacy here or on CL. In addition to the kit I got second hand, I will be adding the MAF adapter I bought, as well as an oil pressure and temp gauge. Also had the injectors cleaned at WitchHunter so I'll factor that in as well, but it will probably stay close to the original price I bought it from despite the additions. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted October 2, 2015 Share Posted October 2, 2015 Yup, done deal. Picked up my 2016 WRX in Lapis Blue. Turbo being taken out of the Legacy and going back for sale. May try selling the Legacy here or on CL. In addition to the kit I got second hand, I will be adding the MAF adapter I bought, as well as an oil pressure and temp gauge. Also had the injectors cleaned at WitchHunter so I'll factor that in as well, but it will probably stay close to the original price I bought it from despite the additions. That is a great replacement/upgrade vehicle I too like the 15+ WRX, enjoy. Also you should be able to sell your 2.5i on here but a lot of times folks are looking for LGTs same on NASIOC except they will try to trade you a grenade WRX for for 2.5i b/c "they want better MPG" Link to comment Share on other sites More sharing options...
aigochamaloh Posted October 3, 2015 Author Share Posted October 3, 2015 That is a great replacement/upgrade vehicle I too like the 15+ WRX, enjoy. Also you should be able to sell your 2.5i on here but a lot of times folks are looking for LGTs same on NASIOC except they will try to trade you a grenade WRX for for 2.5i b/c "they want better MPG" Haha well I drove the 15 WRX CVT for 40k miles in one year so I got raped on the trade a bit. Not as bad as expected though. Bought the cvt under invoice last year and go 22k on the trade. Got the new wrx for well under invoice though. We just thought about it and it seemed better to take the hit now rather than trade the auto wrx for a new van later and then buy myself another toy car since the legacy would still suck compared to a new wrx. Now I have to decide whether to put the legacy completely to stock and sell the racecomp tarmac on the side and what not. Turbo and everything came off today, swapped the oil pan again, should be up and running in a couple days when I get some time off. Then I suppose it's picture time. Sorry to disappoint those following the thread haha. Link to comment Share on other sites More sharing options...
aigochamaloh Posted October 5, 2015 Author Share Posted October 5, 2015 Well, kit is up for sale now with my new additions. http://legacygt.com/forums/showthread.php/socal-avo-turbo-kit-2-5i-many-extras-245943.html The two cars http://i207.photobucket.com/albums/bb227/aigochamaloh/Subaru%20Legacy/1005151132_zpsmr9mxgev.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/Subaru%20Legacy/1005151131_zpsxhsomrvy.jpg http://i207.photobucket.com/albums/bb227/aigochamaloh/Subaru%20Legacy/1005151132_HDR_zps5efh6btw.jpg Link to comment Share on other sites More sharing options...
aigochamaloh Posted October 13, 2015 Author Share Posted October 13, 2015 Anyone here interested in the kit? Link to comment Share on other sites More sharing options...
josuefranky Posted October 15, 2015 Share Posted October 15, 2015 Anyone here interested in the kit? how much u want for it im looking to turbo my 04 outback Sent from my HTC One_M8 using Tapatalk Link to comment Share on other sites More sharing options...
