Scruit Posted June 9, 2015 Share Posted June 9, 2015 Got the engine out of my car. Noticed that there's TP50 flywheel bolts and holes in the flywheel for reaching through to get at the bolts - but they don't line up. Is there a trick to getting them to line up - or is this an indication of a problem? Looks like I can lock the FW in place then turn the crank pulley - only need about 10 degrees. Link to comment Share on other sites More sharing options...
Underdog Posted June 9, 2015 Share Posted June 9, 2015 Still on the original DMFW? Lock the ring gear portion and rotate the friction portion back in to place. The Crimson Dynamo Link to comment Share on other sites More sharing options...
Scruit Posted June 9, 2015 Author Share Posted June 9, 2015 Still on original, yes. Will do that, thanks. Link to comment Share on other sites More sharing options...
FJuan Posted June 9, 2015 Share Posted June 9, 2015 Correct, you'll need to rotate the outter part of the FW to align the holes. I just use a big screwdriver and stick it through one of the holes to rotate the outer FW. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 10, 2015 Share Posted June 10, 2015 Your getting a SMFW from Underdog aren't you ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Scruit Posted June 10, 2015 Author Share Posted June 10, 2015 Nope. Sticking with the DMFW. It's in good shape. No need to spend the money. Link to comment Share on other sites More sharing options...
Scruit Posted June 10, 2015 Author Share Posted June 10, 2015 What is the advantage versus cost? Link to comment Share on other sites More sharing options...
FJuan Posted June 10, 2015 Share Posted June 10, 2015 Aftet 9 yrs I finally switch to the smfw. So much better and so much smoother. I. wished i did this 5 yrs ago. Go on car-parts.com and find one for less then $100, That's what I did. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Underdog Posted June 11, 2015 Share Posted June 11, 2015 What is the advantage versus cost? Lighter, more direct engagement "feel", can be resurfaced. Use the money you save from buying a used one like F1 recommended to have your new clutch and FW balanced as an assembly. I have seen some clutches out of balance by as much as 40g, when <1g is the typical recommended spec. The Crimson Dynamo Link to comment Share on other sites More sharing options...
