eckoblazer Posted November 5, 2015 Share Posted November 5, 2015 I know it's an older thread but curious if you disabled your DRLs? Also how have they held up of the last few months? Link to comment Share on other sites More sharing options...
amm203 Posted November 6, 2015 Author Share Posted November 6, 2015 I did not disable my DRLs - still using the halogens in the high-beam lens. The bulbs are still holding up great. No loss in lumens as far as I can tell and both are still working fine. Link to comment Share on other sites More sharing options...
legacyshawn Posted November 9, 2015 Share Posted November 9, 2015 this is great! would you be able to do a side by side comparison of the light shinning on a dark road and on a wall 30 feet away? I want to see how it throws. That would be awesome!!! Link to comment Share on other sites More sharing options...
Shogun506 Posted November 18, 2015 Share Posted November 18, 2015 I just bought and installed these after reading this thread a few months ago since a ballast on my HIDs crapped out the other day. I love them! Much brighter than my HIDs in my opinion and they turn on immediately. The light output is definitely brighter than halogens both right in front of the car and down the road. I had the Xenon Experts Volt HID kit which is not a cheap kit. Vs. Halogens - they light up a slightly longer distance and do so much brighter. You still need your highbeams to see really far down the road but that's what they're for. Vs. HIDs - they light up the same amount of area but brighter in my opinion. You don't have to worry about them not firing when you turn on your car and they turn on immediately rather than warming up. HIDs don't light up any further down the road than these anyway. I'm going to upload a video showing a comparison. Link to comment Share on other sites More sharing options...
Dispatch20 Posted November 18, 2015 Share Posted November 18, 2015 I just bought and installed these after reading this thread a few months ago since a ballast on my HIDs crapped out the other day. I love them! Much brighter than my HIDs in my opinion and they turn on immediately. The light output is definitely brighter than halogens both right in front of the car and down the road. I had the Xenon Experts Volt HID kit which is not a cheap kit. Vs. Halogens - they light up a slightly longer distance and do so much brighter. You still need your highbeams to see really far down the road but that's what they're for. Vs. HIDs - they light up the same amount of area but brighter in my opinion. You don't have to worry about them not firing when you turn on your car and they turn on immediately rather than warming up. HIDs don't light up any further down the road than these anyway. I'm going to upload a video showing a comparison. We're you using a HID bulb in a halogen projector? Link to comment Share on other sites More sharing options...
Shogun506 Posted November 18, 2015 Share Posted November 18, 2015 We're you using a HID bulb in a halogen projector? Yeah I was but that's the comparison I'm trying to make here. If you're only going to change the bulbs then changing to LEDs will give you more than changing to HIDs. If you're going to do a full retrofit then that's another level of work and of cost. edit: I guess I probably should have clarified that. I wonder what these lights would look like in an HID housing though. Link to comment Share on other sites More sharing options...
Shogun506 Posted November 18, 2015 Share Posted November 18, 2015 this is great! would you be able to do a side by side comparison of the light shinning on a dark road and on a wall 30 feet away? I want to see how it throws. That would be awesome!!! The light is actually whiter than the bluish colour you see in this picture. My best description is that it shines more intense in the area that it covers and also goes slightly further down the road and definitely further laterally. That's a screenshot from this video Link to comment Share on other sites More sharing options...
fedaykin Posted November 19, 2015 Share Posted November 19, 2015 Got any wall shots? That actually looks quite good. What temperature? Looks 6,000K+. Link to comment Share on other sites More sharing options...
ScherbS Posted February 12, 2016 Share Posted February 12, 2016 More free-time at work... Drilled the holes per OPT7's recommendation. They should really help get some fresh air into the enclosure to keep heat down. http://i304.photobucket.com/albums/nn164/amm203/image3_zpsz5wedjhv.jpg Couldn't a gore-Tex patch keep moisture out but still allow for it to breath? I'm probably way off base gore Tex lets air out and not in. Link to comment Share on other sites More sharing options...
mikek753 Posted July 24, 2016 Share Posted July 24, 2016 How would you compare this to HID converting? Would you go LED again or go HID? Sent from my SM-G900T using Tapatalk Link to comment Share on other sites More sharing options...
amm203 Posted July 25, 2016 Author Share Posted July 25, 2016 Unfortunately, I cannot compare to HID - maybe some others can chime in with their impressions. From the images I've seen on here of HID setups these are not quite as bright. However, they are still going strong since I've bought them. No drop in light output and no regrets in purchasing them. Link to comment Share on other sites More sharing options...
CTGT Posted October 1, 2016 Share Posted October 1, 2016 OP, I was wondering how these held up in the snow and rain visibility wise? Link to comment Share on other sites More sharing options...
RooTBeeR Posted October 12, 2016 Share Posted October 12, 2016 Mmmmm, leds Sent from my XT1650 using Tapatalk "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
mestizoracer310 Posted November 17, 2016 Share Posted November 17, 2016 ok, so you've had these for about a year.... update? I'm debating on ripping out my 55W HIDs but wavering toward Auxbeams.....8,000 lumens...and I can get LEDs for my lows AND highs for less than the cost of one set of OPT7's.. auxbeam has been getting really good reviews on amazon.... Link to comment Share on other sites More sharing options...
amm203 Posted November 17, 2016 Author Share Posted November 17, 2016 They're still going! They are still as bright and staying put. However, I'm thinking of experimenting with these soon. They're pricier and bulkier but they are super bright (9,600 Lumens vs 7,000) and can be had at 5000K as well as 6000K. They are also more adjustable and have great reviews. The 8,000 Lumens for those auxbeams sounds great but I wish they came in a cooler temperature. Link to comment Share on other sites More sharing options...
mestizoracer310 Posted November 18, 2016 Share Posted November 18, 2016 wow, 9,600 lumens from LEDs? I think for the price point i'll try the auxbeams... if they suck, it's not a big hit and I can reinstall my HIDs... but I think I wanna go LED since I can't think of a way to disable flash to pass (from an all lights off stand point) and retain use of using the OE combo switch to do FTP... Link to comment Share on other sites More sharing options...
mestizoracer310 Posted November 18, 2016 Share Posted November 18, 2016 SNGL is saying their 6000k bulbs (combined) produce 10,400 lumens....? whoa... Link to comment Share on other sites More sharing options...
fedaykin Posted November 21, 2016 Share Posted November 21, 2016 Yeah Chinese lumens woooo! Link to comment Share on other sites More sharing options...
huey9876 Posted June 14, 2017 Share Posted June 14, 2017 I have a 2017 Subaru Legacy and it has the new headlights. I love them and they put out the bright white light. My question is has anyone changed the fog lights to a new bulb? When I turn on the fog lights you they are washed out by the head lights. It would have been nice if Subaru had matched the bulbs in the fog lights to be the same as the headlights Link to comment Share on other sites More sharing options...
fedaykin Posted June 15, 2017 Share Posted June 15, 2017 https://www.theretrofitsource.com/assemblies/fog-light-assemblies/subaru-morimoto-xb-led.html Seen those? Lots of other manufacturers have been making good fogs for a while now, seems like Subaru are just being lazy/cheap. Link to comment Share on other sites More sharing options...
amm203 Posted June 15, 2017 Author Share Posted June 15, 2017 2nd fedaykin's post. I got the same ones that fit 08-09 legacies and the output is exceptional. Link to comment Share on other sites More sharing options...
ryanlucas13 Posted June 21, 2017 Share Posted June 21, 2017 I didnt have luck with my LED bulbs. I had some bad hotspotting. When I contacted the vendor, they said the bulbs don't do well with projector headlights and that HID was the way to go. So they swapped out the LED for HID to try. I haven't received them yet, but I am hoping for the best. Link to comment Share on other sites More sharing options...
