brycelevet Posted April 21, 2015 Share Posted April 21, 2015 I've been searching for about an hour and have had no luck finding anything; my apologies. Does anyone have a tutorial or a brief description of how to remove the instrument cluster on the dashboard in order to replace the lights? Note - I do have experience removing the shift knob, trim, radio/ac unit and cubby pocket, but I haven't tried removing the instrument cluster (speedometer, etc.). Am I basically a step away? Link to comment Share on other sites More sharing options...
solidxsnake Posted April 22, 2015 Share Posted April 22, 2015 This should do it. On a semi-related note, have you seen these awesome vacation pictures? Link to comment Share on other sites More sharing options...
Leviman Posted April 22, 2015 Share Posted April 22, 2015 Kind of a confusing diagram they have there, but yes, top screw, and then two along the bottom of the cluster. To get to the bottom two, use a longer screw driver, and first remove the plastics from under the steering column, and possibly the reinforcement as well. Link to comment Share on other sites More sharing options...
brycelevet Posted April 22, 2015 Author Share Posted April 22, 2015 How do you remove the plastics from under the steering wheel? I assume there's just screws or it just pops off? Link to comment Share on other sites More sharing options...
solidxsnake Posted April 22, 2015 Share Posted April 22, 2015 How do you remove the plastics from under the steering wheel? I assume there's just screws or it just pops off? Yup, there's three clips. On my '07, there's two phillips-head clips on either side, and the middle one just pries off. Link to comment Share on other sites More sharing options...
