1970something Posted March 7, 2015 Share Posted March 7, 2015 Looking for some advice for my 2005 GT wagon. I bought it with BC BR coilovers about a year ago - car has 80k miles and coils now have ~50k miles on them. The car sits a bit too low for me: Front - 25.00" ground-to-fender (13.25" hub-to-fender) Rear - 25.25" ground-to-fender (13.50" hub-to-fender) I'd like to raise it at least 0.50", if not 0.75". The car is daily driven and I'm looking primarily for ride comfort. My questions are: - After 50k miles, should I expect the dampers on the BRs to be worn out? I've read varying reports on how long these things last. Also, is there a good way to tell if they are dead? - Does anyone know the maximum height that the BRs can go? I've looked around a bit on this forum and can't find any hard numbers. - I also have the stock springs and shocks that came with the car (taken off at 30k miles). Thoughts on installing the stock springs with a new set of KYB GR2 shocks and mounts? Any advice is appreciated. Link to comment Share on other sites More sharing options...
ssbtech Posted March 9, 2015 Share Posted March 9, 2015 Koni cut-a-strut front inserts/rear shocks and Swift springs. Link to comment Share on other sites More sharing options...
whitetiger Posted March 9, 2015 Share Posted March 9, 2015 yes, do the konis and sell the coilovers. BC BR's are garbage anyways. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted March 9, 2015 Moderators Share Posted March 9, 2015 You won't want swift springs with the primary goal of ride comfort. Go with Konis and stock springs. I think that you will be really happy with that setup. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Dujo Posted March 9, 2015 Share Posted March 9, 2015 Agree that swifts are too low. +1 for Koni. Link to comment Share on other sites More sharing options...
ssbtech Posted March 9, 2015 Share Posted March 9, 2015 There you go. I was just going by what I heard. Bilstein HDs and Spec B wagon pinks for me. Definitely not a comfort setup Link to comment Share on other sites More sharing options...
bluesuby Posted March 9, 2015 Share Posted March 9, 2015 You won't want swift springs with the primary goal of ride comfort. Go with Konis and stock springs. I think that you will be really happy with that setup. I did and I am. All that floating in the rear end is cured. Link to comment Share on other sites More sharing options...
GTEASER Posted March 9, 2015 Share Posted March 9, 2015 Koni cut-a-strut front inserts I hope to God you're not in marketing. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
1970something Posted March 10, 2015 Author Share Posted March 10, 2015 Thanks for the help, guys. Are the konis infinitely adjustable or do they have discrete clicks between the softest and the hardest setting? Link to comment Share on other sites More sharing options...
GTEASER Posted March 10, 2015 Share Posted March 10, 2015 2 full revolutions of the knob from full soft to full firm. No clicks. Typically people adjust them in 1/2 turn intervals. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
boxkita Posted March 13, 2015 Share Posted March 13, 2015 YOu can replace the cartridges in the BC Racing for $75/corner, maybe a bit more now. Then raise it up. A good corner balance will fix the lowness as well as ride, however, it was will always be more harsh than others. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
ssbtech Posted March 13, 2015 Share Posted March 13, 2015 I hope to God you're not in marketing. Why? Link to comment Share on other sites More sharing options...
GTEASER Posted March 13, 2015 Share Posted March 13, 2015 the cut-a-strut reference was just hilariously cheap sounding. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ssbtech Posted March 13, 2015 Share Posted March 13, 2015 Hey, if Koni uses the phrase... Link to comment Share on other sites More sharing options...
GTEASER Posted March 13, 2015 Share Posted March 13, 2015 I have never seen Koni use that phrase. I always see them referred to as "inserts". GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
solo413 Posted March 13, 2015 Share Posted March 13, 2015 I went h&r springs for a slight drop and kyb struts n shocks! Very smooth ride with out any compromise Link to comment Share on other sites More sharing options...
solo413 Posted March 13, 2015 Share Posted March 13, 2015 Here is a pic as she sits on factory rims with snow tires http://tapatalk.imageshack.com/v2/15/03/13/0564c587a82887529cc5599743c8b6de.jpg Link to comment Share on other sites More sharing options...
ssbtech Posted March 13, 2015 Share Posted March 13, 2015 I have never seen Koni use that phrase. I always see them referred to as "inserts". You learn something new every day Link to comment Share on other sites More sharing options...
GTEASER Posted March 13, 2015 Share Posted March 13, 2015 You learn something new every day Hahaha! Thanks for that! There's Saabaru on the lift in the background. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Shello007 Posted March 26, 2015 Share Posted March 26, 2015 Here is a pic as she sits on factory rims with snow tires http://tapatalk.imageshack.com/v2/15/03/13/0564c587a82887529cc5599743c8b6de.jpg Been thinking about going H&R. Which series did you go with? Not seeing much of a drop. Link to comment Share on other sites More sharing options...
Rhitter Posted March 26, 2015 Share Posted March 26, 2015 Here is a pic as she sits on factory rims with snow tires http://tapatalk.imageshack.com/v2/15/03/13/0564c587a82887529cc5599743c8b6de.jpg That looks like a good functional drop. Curious what ride comfort is like I bought H&R springs and Bilsteins for my Mustang about a decade ago. Ride was super stuff and not really comfy. My OBXT build Link to comment Share on other sites More sharing options...
1970something Posted March 27, 2015 Author Share Posted March 27, 2015 YOu can replace the cartridges in the BC Racing for $75/corner, maybe a bit more now. Then raise it up. A good corner balance will fix the lowness as well as ride, however, it was will always be more harsh than others. How do you go about doing this? Does BC sell the cartridges separately? Link to comment Share on other sites More sharing options...
boxkita Posted March 27, 2015 Share Posted March 27, 2015 How do you go about doing this? Does BC sell the cartridges separately? Instructions, as BC Racing site is woefully deficient, http://www.iwsti.com/forums/gd-suspension-handling-and-stiffening/171309-bc-coilover-owners-anyone-replace-shock-cartridge-insert.html Contact BC Racing - http://www.bcracing-na.com/contact-us/ Either BC Racing directly will do it, or you contact a vendor to get the cartridges Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
whitetiger Posted March 27, 2015 Share Posted March 27, 2015 FWIW, $75 a cartridge shows you just how crappy the dampers really are. Link to comment Share on other sites More sharing options...
