1-3-2-4 Posted February 25, 2015 Share Posted February 25, 2015 The one behind the head maybe I'm wrong but some said it's on super tight? While I don't have any filters in the AVCS OCV's I don't know about the one behind the head. What is it 10 mm? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 25, 2015 Share Posted February 25, 2015 I believe the banjo bolt on the back of the head is a 10mm banjo. Ask someone like "underdog" he might know for sure. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AMileHighLGT Posted February 25, 2015 Share Posted February 25, 2015 The banjo bolt on the backside of the cylinder head is a 17mm, same size as the ocv banjo bolt. The banjo bolt on the turbo is a 10mm. Link to comment Share on other sites More sharing options...
doobaruGT Posted February 25, 2015 Share Posted February 25, 2015 I thought it was 14mm. I bought a ratcheting wrench for this, or so I thought. 10mm is pretty small for a banjo, no? Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
Max Capacity Posted February 25, 2015 Share Posted February 25, 2015 I'm talking thread size, not wrench size. I seem to recall the turbo banjo is a 14mm hex ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AMileHighLGT Posted February 25, 2015 Share Posted February 25, 2015 I'm talking thread size, not wrench size. I seem to recall the turbo banjo is a 14mm hex ? Doh. You're correct. 14 for turbo I thought it was 14mm. I bought a ratcheting wrench for this, or so I thought. 10mm is pretty small for a banjo, no? Link to comment Share on other sites More sharing options...
doobaruGT Posted February 25, 2015 Share Posted February 25, 2015 The banjo bolt on the backside of the cylinder head is a 17mm, same size as the ocv banjo bolt. The banjo bolt on the turbo is a 10mm. Ah there ya go. It's all coming back to me now... Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
doobaruGT Posted February 25, 2015 Share Posted February 25, 2015 I'm talking thread size, not wrench size. I seem to recall the turbo banjo is a 14mm hex ? That would make a lot more sense. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
CloudSeed777 Posted February 25, 2015 Share Posted February 25, 2015 They're all the same (14mm) with the exception of the oil-feed banjo on the turbo (10mm) as you can see here: http://legacygt.com/forums/showthread.php/2005-outback-xt-rebuild-chronicles-233261p7.html?highlight=chronicles Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 25, 2015 Author Share Posted February 25, 2015 So will I have to cuss at it to loosen it? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 25, 2015 Share Posted February 25, 2015 Yea, I may have to agree the banjos on the heads may be 12mm, I have been thinking that. That would explain the 17mm hex head on them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AMileHighLGT Posted February 25, 2015 Share Posted February 25, 2015 Pretty sure I had an oldman brainfart. Not sure if the op wants the thread size. Probably looking for head size Link to comment Share on other sites More sharing options...
CloudSeed777 Posted February 25, 2015 Share Posted February 25, 2015 So will I have to cuss at it to loosen it? I don't recall mine being particularly bad. Just make sure you're square on the bolt head and you shouldn't have too much a problem. I used a cheater bar several times on my build, but can't remember if I needed it on the banjos. I just checked on the car - heads on larger banjos are indeed 17mm socket, not 14mm. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 4, 2015 Author Share Posted March 4, 2015 The bolt on the head was easy as pie to get out.. and indeed the one behind the head had a filter in it! I took a picture of it (on my phone) from what I understand it's the inside of the filter that's where it can build up? I left the filter out. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 4, 2015 Author Share Posted March 4, 2015 http://tapatalk.imageshack.com/v2/15/03/04/8edea6171a0445ee4b60fc8770f10413.jpghttp://tapatalk.imageshack.com/v2/15/03/04/a8035216a7d666b72679f611a9eb651d.jpg Link to comment Share on other sites More sharing options...
doobaruGT Posted March 4, 2015 Share Posted March 4, 2015 The bolt on the head was easy as pie to get out.. and indeed the one behind the head had a filter in it! I took a picture of it (on my phone) from what I understand it's the inside of the filter that's where it can build up? I left the filter out. Well done, sir. Hopefully this is a confidence builder for the dragons down the road Sent from my iPhone using Tapatalk Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 4, 2015 Author Share Posted March 4, 2015 Well done, sir. Hopefully this is a confidence builder for the dragons down the road Sent from my iPhone using Tapatalk My only thing was forgetting to take it out the first time I changed the turbo. Link to comment Share on other sites More sharing options...
doobaruGT Posted March 4, 2015 Share Posted March 4, 2015 My only thing was forgetting to take it out the first time I changed the turbo. Meh, I left mine in after I upgraded. My banjo was clean as could be. I could be playing with fire but my OCV logs are good and I tend to my OCI's like a Roman to confession. Seems to be a crap-shoot but I'm willing to bet maintenance plays a critical role. Sent from my iPhone using Tapatalk Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 4, 2015 Author Share Posted March 4, 2015 Meh, I left mine in after I upgraded. My banjo was clean as could be. I could be playing with fire but my OCV logs are good and I tend to my OCI's like a Roman to confession. Seems to be a crap-shoot but I'm willing to bet maintenance plays a critical role. Sent from my iPhone using Tapatalk I can't really say mine is clean or dirty since I don't see too many what a dirty one looks like. Link to comment Share on other sites More sharing options...
SleeperScoob Posted March 5, 2015 Share Posted March 5, 2015 Doesn't look too clean to me, good thing you pulled it out. Though, there is still a lot of oil on it in the pic. Mine were clean as a whistle, but they still came out. I could see almost no buildup after drying them off. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted March 5, 2015 Author Share Posted March 5, 2015 I looked at it it's pretty dirty if you ask me Link to comment Share on other sites More sharing options...
