1-3-2-4 Posted January 31, 2015 Share Posted January 31, 2015 I was on the highway and I noticed the car felt very unstable it was rocking side to side then the abs light came on.. pulled over when I could and jacked on each corner to check for any play in the wheels and I found none. .. Anyone know or had this happen before? Link to comment Share on other sites More sharing options...
Max Capacity Posted January 31, 2015 Share Posted January 31, 2015 I think you figured it out by your post in the rear wheel bearing thread. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 31, 2015 Author Share Posted January 31, 2015 I think you figured it out by your post in the rear wheel bearing thread. Yep but I don't know is the abs a magnetic ring? I did not find much info when I got in last night.. from what it seems it's not hard to change but I need to know what other tools I need to make it go smooth.. I have a gear puller but my impact wrench my battery is in another location so I will have to get it later. I ordered the timken bearing Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 1, 2015 Share Posted February 1, 2015 Magnetic polse ring(trigger ring is not magnetic but causes pulses between the teeth in the ring and the pickups) and magnetic abs pickup sensors Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 1, 2015 Author Share Posted February 1, 2015 Yep found that out Link to comment Share on other sites More sharing options...
