Max Capacity Posted January 22, 2015 Share Posted January 22, 2015 How much does one save buying the short block vs the long block? read my click here link to see the right way to do it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xtea Posted January 22, 2015 Share Posted January 22, 2015 read my click here link to see the right way to do it. How much does one save by buying the short block over the long block? I searched your thread for the the word long block and did not see and cost comparison in the posts that came up. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 22, 2015 Share Posted January 22, 2015 Unless your heads are toast, you don't need a long block. Are yours toast ? I think the long block is very expensive, more then a $1000. You should be able to find the price on one of the Vendors Link on the blue bar up top. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xtea Posted January 22, 2015 Share Posted January 22, 2015 Unless your heads are toast, you don't need a long block. Are yours toast ? I think the long block is very expensive, more then a $1000. You should be able to find the price on one of the Vendors Link on the blue bar up top. I dont need a rebuild yet that I know of. Just thinking about it. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 22, 2015 Share Posted January 22, 2015 You should be fine with your heads. They are easy for the machine shop to rebuild. I see your new here, listen to the sound your turbo makes. If that sound ever changes, shut the car off. The cars came with throw away turbos. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted January 22, 2015 Share Posted January 22, 2015 You should be fine with your heads. They are easy for the machine shop to rebuild. I see your new here, listen to the sound your turbo makes. If that sound ever changes, shut the car off. The cars came with throw away turbos. He has a JmP turbo. He's gonna be just fine. Link to comment Share on other sites More sharing options...
JJr Posted January 22, 2015 Share Posted January 22, 2015 JmP niceness! Link to comment Share on other sites More sharing options...
