Dyno results from STI intake swap and DB 20g install
mycotopian
I'll add more details when I get a chance but heres the charts.
I'll try to remember all the mods but there's alot
STI Intake Manifold
Spearco TMIC
Custom aluminum Turbo inlet
Custom CAI
Deadbolt STI TD06h-20g w/ super duty bearings, clipped compressor wheels, Ported internal wastegate and 15lb actuator.
Perrin Modified injectors
Walbro 255
Cobb Catted DP with the taper removed
Greddy SP2 Catback
XS-Engineering Powerpack II Ignition
Oh and non power related mods are JIC Coilovers ,Perrin swaybars/end links, Exedy lightweight flywheel and clutch.
http://i4.photobucket.com/albums/y119/mycotopian/TorqueChart.jpg
http://i4.photobucket.com/albums/y119/mycotopian/PowerChart.jpg
http://i4.photobucket.com/albums/y119/mycotopian/BoostMap.jpg
the plot thickens. interesting to compare to boxerpwr's experiences. this is on 91, correct? doesn't seem lag is too much of a problem with the 20g.
what are your fuel mods again?
stock STi TMIC?
what was the baseline setup?
what kind of dyno?
keep that info coming!
getting out of the legacy game :cool:
My 20g vs. his 20g,..355hp vs only 326,...
BAH!! Who cares,...Those are freaking AWESOME!!!
I dont know how you roll being able to pump out more hp and tooling with a perfectly "new-ish" car so soon and not worry about reliability,...Wish I had a "roll" to pimp my car out,..Of course I plopped my $26k (actually wire transferred) and do not have to worry about payments,..hee hee,...but this took about 5 yrs savings and the right timing,..
My previous car, I had to wait a few years after dealer warranty and wearing out oem parts before making a turbo/fmic/fuel mods,...
Full exhaust and AP for now will suit me fine for now and dream about how much potential I could have like the rest of you guys,...
Like Aerosmith says,..DREAM ON!! DREAM ON!!!
and it says these are 4th gear pulls.....interesting. I thought all 5-speeds are done in 3rd gear pulls on dynos.
what would be the affect of comparing the same car with a 3rd gear pull vs. a 4th gear pull?
4th gear pulls are slightly slower and give you more data to look at.
Usually I do 3rd gear for broad tuning and 4th if i want to do more fine tuning.
thanks for unlocking the puzzle.
so for us English-only dweebs, the effective PSI conversion is
125 kPa = 4 PSI
200 kPa = 14.5 PSI
250 kPa = 21.75 PSI
so that does mean the final runs were hovering just below 22 PSI. pretty aggressive boost. but it sure seems to be holding nicely without creeping!
cause its 20G for STi... been out for a while.. works very well. Nice power with 91 octane. Higher than most Ive seen but he's also running more boost than most I've seen too.
Frankly, I expect both STi setup and Legacy setup to prove to be similar.
Just like I expect 280 or so from a Protune on 91 octane and a VF39 STi swap on a Legacy with TBE.
the KPA is absolute pressure.. with starts at vaccum... 0 psi is 100kpa absolute.. like stated above.
"some say, his arms are made of coiled adamantium fibers. And that he tops his cereal with nuts and bolts. All we know is, he's called the Jose."
STI Intake Manifold
Spearco TMIC
Custom CAI
Greddy SP2 Catback
Oh and non power related mods are JIC Coilovers and Perrin swaybars/end links
