JamesJaikissoon Posted April 27, 2016 Share Posted April 27, 2016 anyone has any idea about the center speaker on the dash? mine is 2.5 premium. What could i do anything with that empty space? and of course no kidding drug in there . Thanks whats in the center spot anyway ? have you seen what can go in there thou ? Link to comment Share on other sites More sharing options...
JamesJaikissoon Posted April 27, 2016 Share Posted April 27, 2016 Are people with 6-speaker on Premium Trim happy enough just replacing the door speakers and not replacing dash speakers? Wondering if it's worth replacing them. I'm looking at the Kickers for the doors. Crutchfield doesn't show anything compatible for the dash speakers. I saw in the other thread someone used pipe clamps to mount small tweaters. I'm wondering if this is too complicated to have Best Buy install? I've done self install before but don't want to risk messing something up on my brand new car. My old car was a 1997 Legacy so didn't care too much if I ruined a door fastener or two im installing 4 speakers and 2 tweeters. geek squad said they will make a custom mount for the twetters that go on the dash. i but the k Series Kickers that go for $229.00 Link to comment Share on other sites More sharing options...
jMeG Posted April 28, 2016 Share Posted April 28, 2016 im installing 4 speakers and 2 tweeters. geek squad said they will make a custom mount for the twetters that go on the dash. i but the k Series Kickers that go for $229.00 Please follow up with photos and what you think of the speakers. Link to comment Share on other sites More sharing options...
JamesJaikissoon Posted April 28, 2016 Share Posted April 28, 2016 Please follow up with photos and what you think of the speakers. Sure will Sent from my Nexus 6P using Tapatalk Link to comment Share on other sites More sharing options...
JamesJaikissoon Posted April 28, 2016 Share Posted April 28, 2016 I'm installing them on May 6 Sent from my Nexus 6P using Tapatalk Link to comment Share on other sites More sharing options...
JamesJaikissoon Posted May 10, 2016 Share Posted May 10, 2016 OK. I really woundnt know how to put it or describe the sound but its a big upgrade from the stock speakers. it just sounds glorious. a sub would be a really good add for bass but the bass on this isnt bad at all. i just bought the pioneer avh-4200nex. im going to install that next. and let yall know whats up Link to comment Share on other sites More sharing options...
rmkrm Posted February 16, 2017 Share Posted February 16, 2017 Sorry if the question makes no sense. What would you guys and gals say about installing a 2-way (no crossover) in the front door without changing the stock tweeters on a premium? I ask because I am not sure if I have the skill to re-wire if I choose to go with a crossover based speaker system for the fronts Link to comment Share on other sites More sharing options...
TylorJockin Posted February 17, 2017 Share Posted February 17, 2017 I just really need help with removing the door panels. Anyone? Link to comment Share on other sites More sharing options...
andrew_l_s Posted February 17, 2017 Share Posted February 17, 2017 I just really need help with removing the door panels. Anyone? Use a preferably plastic pry tool and get between the door panel and metal at the bottom. Pry out enough to get your fingers underneath and start pulling. Don't be too gentle, if you are you'll screw up the clips. Quick firm pulls work best for releasing them. Also don't forget the screws, one in where the door handle is and the other in the pocket you use to pull it closed. Lighting Mods: $10 Footwell Illumination | Tail as Turn | Fog as DRL Diode Dynamics C-Lights | RX350 Bi-Xenon Retrofit Link to comment Share on other sites More sharing options...
Squandy Posted June 28, 2017 Share Posted June 28, 2017 Use a preferably plastic pry tool and get between the door panel and metal at the bottom. I used a plastic snow scraper to pry underneath, but later found it was quicker and easier to just grab underneath the plastic near the door hinge. I've taken my doors apart this way several times while adding sound dampening. Speakers should be in tomorrow. Going to run off factory HU until I decide whether to add an amp for the doors or just for a Sub. JBL GTO609 Component Speakers for front (need to mount tweeters) https://www.amazon.com/dp/B00ANI3LAK/ref=cm_sw_r_cp_dp_T2_25WuzbZW8QE82 JBL GTO629 for rears https://www.amazon.com/dp/B00ANIECRQ/ref=cm_sw_r_cp_dp_T2_W5WuzbG2CS99E Link to comment Share on other sites More sharing options...
JRu17 Posted June 14, 2018 Share Posted June 14, 2018 I'm looking at the JL Audio C2-350x for the dash, C2-690tx front door, and C2-650x rear doors. I really just started looking and I'm not planning on going all out like Focal or MB Quart. Link to comment Share on other sites More sharing options...
