Guest *Jedimaster* Posted September 9, 2005 Share Posted September 9, 2005 I have the JDM rearsway with AVO endlinks and Whiteline bushings. It's been fine since the install, but now I'm getting a squeak that seems to be coming from it as well as a bumping sound over rougher surfaces. It doesn't look like anything is hitting under there- and the endlinks are adjusted to the stock length and show no signs of having bumped anything. I'm thinking of taking the bushings out and reapplying the grease to them to quiet things down- I used the entire contents of the grease that came with the bushings to make sure there was no noise- is it possible it's kind of washed away or something under there? Link to comment Share on other sites More sharing options...
jim1969 Posted September 9, 2005 Share Posted September 9, 2005 some guys wrap it with teflon tape and then grease. wow, jedi needs more lubrication. Link to comment Share on other sites More sharing options...
andrew.anderson Posted September 9, 2005 Share Posted September 9, 2005 Does is squeak all the time or only on bumps? Does it squeak when you turn? Link to comment Share on other sites More sharing options...
wukindada Posted September 9, 2005 Share Posted September 9, 2005 Try the tape..I applied it to my perrin bars and to this date I have had no squeaks. I also used EXTRA white grease, once it was on for a week I wiped off the excess;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
PGT Posted September 9, 2005 Share Posted September 9, 2005 Jedi - swap back to stock endlinks and see if it improves. Unless you lower the car signifcantly, you won't need them anyways. I had noise issues for a long time....turns out one of the AVO endlinks was bad. They made a running change in the design and I got a bad one....they will swap it out for you if that's the issue. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 9, 2005 Share Posted September 9, 2005 Hmm- good suggestions- thanks guys- I'll try the teflon tape first and if it doesn't fix the problem I'll switch to stock endlinks and contact AVO. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 9, 2005 Share Posted September 9, 2005 Thanks again guys- went out at lunch and got teflon tape and some more of that white goo- gonna wrap the bar near the bushings in the tape and slather some more goo on- wish me luck! Link to comment Share on other sites More sharing options...
jim1969 Posted September 9, 2005 Share Posted September 9, 2005 go lube your bar. Link to comment Share on other sites More sharing options...
rony Posted September 9, 2005 Share Posted September 9, 2005 go lube your bar. Eek! My Car vBGarage Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 9, 2005 Share Posted September 9, 2005 go lube your bar. Will do- and I'll be thinking of you Link to comment Share on other sites More sharing options...
PGT Posted September 9, 2005 Share Posted September 9, 2005 hehe. You said 'goo'. Makes me think of Stewart's mom on MadTV...the skit where he gets lost in the mall and the security guys take him to the office. Link to comment Share on other sites More sharing options...
andrew.anderson Posted September 9, 2005 Share Posted September 9, 2005 go lube your bar. HA HA That is hillharious. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 9, 2005 Share Posted September 9, 2005 hehe. You said 'goo'. Makes me think of Stewart's mom on MadTV...the skit where he gets lost in the mall and the security guys take him to the office. Jim1969 is trying to go into my Danger Zone Link to comment Share on other sites More sharing options...
ProjectS15 Posted September 10, 2005 Share Posted September 10, 2005 just run some telfon tape on the bushing.bar part or use some heavy duty greese sand/dirt from the road can get stuck to the greese or lube weighting it down the rain can then wash it away cuz of the weight of it so maybe thats what happen Link to comment Share on other sites More sharing options...
PGT Posted September 12, 2005 Share Posted September 12, 2005 so....??? No more squeaks?? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted September 13, 2005 Share Posted September 13, 2005 Haven't had time to mess with it yet, but it's on my mind. Was gonna do it tomorrow night but have a 3 hour mandatory meeting form 6-9. I'll post up when I get under there. Link to comment Share on other sites More sharing options...
jerseyglock Posted September 13, 2005 Share Posted September 13, 2005 Its all temporary fix with grease, white grease, anti-size grease or teflon tapes. Manufactor will need to replace bushings with teflon. Just like old days on Chevy Cavaliers (squeak over bump), we had to replace all of the front sway bar bushings with newer bushing with teflon. And, all labor cover under warranty with Chevy... Link to comment Share on other sites More sharing options...
