Scooby Fan Posted October 8, 2014 Share Posted October 8, 2014 Here you go.....I did the independent fog light mod right after I got my 3.6R in March ....there is lots of discussion in here about other ways, BUT the way I did it works and is easy to achieve...Enjoy!! http://legacygt.com/forums/showthrea...od-223969.html Link to comment Share on other sites More sharing options...
TTG Posted October 9, 2014 Share Posted October 9, 2014 Here you go.....I did the independent fog light mod right after I got my 3.6R in March ....there is lots of discussion in here about other ways, BUT the way I did it works and is easy to achieve...Enjoy!! http://legacygt.com/forums/showthrea...od-223969.html I am pretty darn sure the wiring is different on 6th gen, just as it was different from 4th to 5th gen. I have done what you have done to your car on my 2012 couple of months after delivery in 2011. (can't ever turn the fog lights off unless you add another switch) There was a much easier way to do this on 4th gens (by disconnecting one wire) and I am looking for a similar solution. Link to comment Share on other sites More sharing options...
Scooby Fan Posted October 9, 2014 Share Posted October 9, 2014 What I have shown you there will work on any car, any gen.........all you are doing is triggering the fog light relay from a different power source (You can choose whatever one you want)...the best part of this is it by-passes the BIU so no risk of an expensive mistake. If you want to look for another way...help yourself...this is easy and it works....your fogs work with DRL,low beam and high beam and you can shut them off at any time by flipping the switch on the dash. I have used this method on all 6 of my Subarus (2002 to present) and many other makes as well. Link to comment Share on other sites More sharing options...
Picky1 Posted October 9, 2014 Share Posted October 9, 2014 Still waiting for the LED bulbs Amazon.com : Docooler Super Bright 80W H11 Osram LED Car Light Fog Light Lamp Bulb : Car Electronics In the meanwhile, here are couple of pictures of the end result: Looking forward to seeing how those LED Fogs look with the OEM headlights. I I am trying to find an LED bulb that matches the color of the headlights.....5000k or 6000k? Link to comment Share on other sites More sharing options...
Cuttlefish Posted October 9, 2014 Author Share Posted October 9, 2014 Looking forward to seeing how those LED Fogs look with the OEM headlights. I I am trying to find an LED bulb that matches the color of the headlights.....5000k or 6000k? So I've received a pair of the LED bulbs. One of the bulbs won't fit! (Update: I trimmed all the latches to fit in socket). Here are some pictures of the LED fog lights. It scatters a lot of light. Probably good if those bulbs are in project fog lamps. Link to comment Share on other sites More sharing options...
Rick-Colo Posted October 11, 2014 Share Posted October 11, 2014 Can you list the light bulbs you used and how you trimmed them? I'm looking to go to amber instead of stock white. Thanks, Rick Link to comment Share on other sites More sharing options...
GarciaMo Posted October 23, 2014 Share Posted October 23, 2014 Thanks for posting! I'm thinking about putting these same fog lights in my Premium. Does the dashboard switch look stock, and did it fit into one of the holes to the left of the steering wheel? Would you be able to post a picture? Thanks, MG Link to comment Share on other sites More sharing options...
Yoda_One Posted October 23, 2014 Share Posted October 23, 2014 I glad you're young and ambitious I am too old to even think about trying something like that. That is why I buy I always buy the top of the line this case 3.6r limited with the bells and whistles so I just enjoy the ride. Laughing at Oneself and with Other is good for the Soul Link to comment Share on other sites More sharing options...
Cuttlefish Posted October 23, 2014 Author Share Posted October 23, 2014 Thanks for posting! I'm thinking about putting these same fog lights in my Premium. Does the dashboard switch look stock, and did it fit into one of the holes to the left of the steering wheel? Would you be able to post a picture? Thanks, MG The switch is OEM so it's stock. See switch in picture. Link to comment Share on other sites More sharing options...
EMTB815 Posted November 12, 2014 Share Posted November 12, 2014 The switch is OEM so it's stock. See switch in picture. With the OEM switch, where did you plug the wiring into in the dash? This is the only part I'm confused about with the install.... Link to comment Share on other sites More sharing options...
Cuttlefish Posted November 13, 2014 Author Share Posted November 13, 2014 With the OEM switch, where did you plug the wiring into in the dash? This is the only part I'm confused about with the install.... Hmm? The fog light wiring is connected to a dummy button by default. Unplug the wire from the dummy button then plug it into the fog light button. Link to comment Share on other sites More sharing options...
Guest rayms69 Posted November 13, 2014 Share Posted November 13, 2014 sorry to but in, i hate the blank buttons Link to comment Share on other sites More sharing options...
Cuttlefish Posted November 13, 2014 Author Share Posted November 13, 2014 sorry to but in, i hate the blank buttons Ohh.. then you must love the 13 Audi A3 2.0T with mid options. It has tons of blank buttons on the dashboard! 5 blank ones, 3 working ones. Wonder what those buttons do on German cars. Link to comment Share on other sites More sharing options...
Guest rayms69 Posted November 13, 2014 Share Posted November 13, 2014 Blank buttons on an audi would b a thumbs down, i sacrificed the a6 plan for subaru because it was way cheaper. Commuter car anyways, so I will let it slide.couldnt see driving the a6 100 miles a day, every rock chip would drive nuts Link to comment Share on other sites More sharing options...
Nad834 Posted September 28, 2015 Share Posted September 28, 2015 So I'm confused. The diagram in the manual says H16 for non steering responsive. Then cuttlefish said they are h11. Which one are they? I have a premium with regular WITHOUT steering responsive lights. Most LEDs online show h16 as 5202?. Cuttlefish can u verify what size? Thanks Link to comment Share on other sites More sharing options...
securityguy Posted September 28, 2015 Share Posted September 28, 2015 H16 is 19W output and H11 is 55W output. Same bulb design and are interchangeable. I went with 55W in my fogs as I like the extra brightness. Link to comment Share on other sites More sharing options...
Nad834 Posted September 28, 2015 Share Posted September 28, 2015 I have H11, my local shop said they don't fit Without trimming the metal tabs. Try again I guess. I can't seem to find H16 LEDs, most are listed as 5202 which looks like a different socket. Link to comment Share on other sites More sharing options...
securityguy Posted September 28, 2015 Share Posted September 28, 2015 http://www.xenondepot.com Link to comment Share on other sites More sharing options...
im2c0ol Posted September 29, 2015 Share Posted September 29, 2015 Morimoto XB Type T fog for the win if you already has OEM fog light. 16' Legacy Mods: 55w HID + XB35 5500k, LEDS upgrades, XB Type T Fog, 20mm SB. Custom Footwell Illiminate Kit; http://legacygt.com/forums/showthread.php/15-legacy-outback-footwell-illumination-kit-237567.html Link to comment Share on other sites More sharing options...
TTG Posted September 29, 2015 Share Posted September 29, 2015 Morimoto XB Type T fog for the win if you already has OEM fog light. +1, The best solution out there. Period! Link to comment Share on other sites More sharing options...
securityguy Posted September 30, 2015 Share Posted September 30, 2015 Agree to disagree Link to comment Share on other sites More sharing options...
1692 Posted October 2, 2015 Share Posted October 2, 2015 Done some searching and haven't found anything through the forums... but has anyone had the LED fogs when it's been snowing out? I have always gone with halogen since the bulb will get warm enough to prevent any snow buildup on the lens and keep the decent visibility (at least as decent as it can get when it's snowing!). Do the various LED options get warm enough to keep the snow melted? Or does the snow build up and cause visibility issues? (kind of curious with LED's in the headlights too if there may be the same issue) It's the last upgrade for lighting that I'm considering at this time, but wanted to get some feedback from anyone that has had experience with this. Link to comment Share on other sites More sharing options...
securityguy Posted October 2, 2015 Share Posted October 2, 2015 Actually never felt the lens after my fogs have been running. I'll have to check next time I drive. Link to comment Share on other sites More sharing options...
andrew_l_s Posted October 4, 2015 Share Posted October 4, 2015 LEDs do get warm, hence the need for fans or heat sinks to dissipate the heat, so I would assume they'd keep the lens above 32 degrees. I've felt the base of the bulbs before after they've been on for a while, definitely warm enough to keep you from holding your hand there too long. Just remembered I have an infrared thermometer that I could measure surface temperature of the lens with...if I remember I'll do this and post up some numbers (emphasis on that IF ) Lighting Mods: $10 Footwell Illumination | Tail as Turn | Fog as DRL Diode Dynamics C-Lights | RX350 Bi-Xenon Retrofit Link to comment Share on other sites More sharing options...
Nad834 Posted October 7, 2015 Share Posted October 7, 2015 Ok. I just put in xenon depot 30w Cree LED bulbs(6k). I had the 5k in my last car, they were to yellow. I used H11. I Had to file the biggest metal tab almost all the way down with the concentration on the southeast corner of the tab. First one took a half hour with trial and error, second one ten seconds once I knew where to trim. Lol Link to comment Share on other sites More sharing options...
