chaz517 Posted August 12, 2014 Share Posted August 12, 2014 Can I go from stock injectors to 1000cc for a 1.7 mile ride to my tuner? Keeping rpms under 3000 and in I mode? E85 time! Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 12, 2014 Moderators Share Posted August 12, 2014 Can you just get a base map to load with the new injectors? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Gex Posted August 12, 2014 Share Posted August 12, 2014 Tuner can't send you a limp in map? 550-1000cc is a huge jump. It will idle like shi+ for sure. Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 Apparently I gave too short notice for a base map as they are booked solid every single day. Lesson learned there. I mean I could have aaa tow it for free, but that's a last resort. I have the proper taxtrix cable but no clue what I would be doing to scale properly. Link to comment Share on other sites More sharing options...
Connor Posted August 12, 2014 Share Posted August 12, 2014 My vote is to tow it. My car wouldn't even start on 850's without the base map. Even with the base map idle wasn't great. Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 Damn, really. Well, shit Link to comment Share on other sites More sharing options...
MrTris Posted August 12, 2014 Share Posted August 12, 2014 Damn, really. Well, shit You could try, but again, I'd be surprised if it ran (and didn't drown) with those big ol' things. Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 Wtf. Shop just called and said they couldn't get them in. That they wouldn't seat right n fuel was leaking out the side. Do these I'D 1000 need any modifications? Link to comment Share on other sites More sharing options...
MrTris Posted August 12, 2014 Share Posted August 12, 2014 Wtf. Shop just called and said they couldn't get them in. That they wouldn't seat right n fuel was leaking out the side. Do these I'D 1000 need any modifications? Did they put the o-rings and the gaskets in the right places? You ARE running an aftermarket fuel rail, too, right? Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 No I am not. Stock fuel rail. I thought these could be modified to be put in Link to comment Share on other sites More sharing options...
700watts Posted August 12, 2014 Share Posted August 12, 2014 you do need an aftermarket fuel rail...they're really isn't much to it. Link to comment Share on other sites More sharing options...
MrTris Posted August 12, 2014 Share Posted August 12, 2014 No I am not. Stock fuel rail. I thought these could be modified to be put in you do need an aftermarket fuel rail...they're really isn't much to it. This. I'm honestly surprised they'd even attempt to install them otherwise. Why didn't they know to make time for a tune immediately after the install? Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 Well shame on me for not doing proper research. I had spoken with a vendor too and told this was all I needed. How much is a fuel rail? Link to comment Share on other sites More sharing options...
MrTris Posted August 12, 2014 Share Posted August 12, 2014 Well shame on me for not doing proper research. I had spoken with a vendor too and told this was all I needed. How much is a fuel rail? SCASEYS has an ID1000 kit, or at least the fuel rails.. $650? Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 $650 more for another rail? wtf why did I think all I needed was a pump and injectors. Guess ill just return everything Link to comment Share on other sites More sharing options...
MrTris Posted August 12, 2014 Share Posted August 12, 2014 $650 more for another rail? wtf why did I think all I needed was a pump and injectors. Guess ill just return everything I know hindsight is 20/20, but, you're nearly doubling your injector size, and, I suppose converting to topfeed? Again, since you're clearly not doing your own work, who did this for you and why didn't they know what you were missing/what was needed to complete the job? Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 I already am top feed, that is why I thought this was direct fit, it was what i was told. The shop doing the work is not the same place it is being tuned at. Or was being tuned at lol. I just bought the parts n brought it to them. Thanks man Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 12, 2014 Moderators Share Posted August 12, 2014 Pretty sure that jsut swapping to ID1000s with a setup that is already topfeed shouldn't require aftermarket rails... The rails are definitley required for an 05/06 swapping to topfeeds, but should be required for an 07+ "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 According to my research, this was correct, but now I am not sure. Maybe I got the wrong injectors. They were for a wrx I know that, that could be it, but pretty sure I am not THAT dumb and researched enough to order the right ones? Link to comment Share on other sites More sharing options...
chaz517 Posted August 12, 2014 Author Share Posted August 12, 2014 Part# 1000.48.11.wrx.4 http://www.rallysportdirect.com/Injector-Dynamics-1000-48-11-WRX-4-Fuel-Injectors-Top-Feed-1000cc This shows confirmed fitment with my car. Link to comment Share on other sites More sharing options...
Gex Posted August 13, 2014 Share Posted August 13, 2014 I would think they would fit no problem. 07-09 injectors should be the same as the 08+ wrx and sti. Pm Underdog,m.sprank,or mike at azp?installs I'm sure one of them can confirm or deny fitment. Link to comment Share on other sites More sharing options...
firehawk618 Posted August 13, 2014 Share Posted August 13, 2014 I will vote that the car wouldn't even make it there. If it does start it'll be sooo rich it'll foul out the plugs and stall. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
evildriver Posted August 13, 2014 Share Posted August 13, 2014 Part# 1000.48.11.wrx.4 http://www.rallysportdirect.com/Injector-Dynamics-1000-48-11-WRX-4-Fuel-Injectors-Top-Feed-1000cc This shows confirmed fitment with my car. Those are the exact injectors I just installed... No fitment problems here. I wasn't sure if the top of the injectors needed to be seated more in the rails at first but once you torque the rail down its fine. Just gotta make sure the o-rings are in there and lubed up. I also agree with needing a base map before being able to start up or drive anywhere. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 13, 2014 Moderators Share Posted August 13, 2014 Sounds like your shop is incompetent. Sorry. Or better yet, the tech working on the car just hasn't done the install before. Swapping injectors should be straight forward. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
chaz517 Posted August 13, 2014 Author Share Posted August 13, 2014 Sounds like your shop is incompetent. Sorry. Or better yet, the tech working on the car just hasn't done the install before. Swapping injectors should be straight forward. Agreed, tried to save a few bucks by not taking it to the shop who does my other work and tuning. Lesson learned. It is currently at the tuning shop for new injectors and E85 Link to comment Share on other sites More sharing options...
