MrTris Posted August 11, 2014 Share Posted August 11, 2014 But I changed the entire pcv assembly, http://www.infamousperformance.net/servlet/the-632/Subaru-05-dsh-06-Legacy-GT/Detail Unless the stem that mounts onto is the culprit. I can't seem to find any diagrams or pictures of what that pcv assembly actually mounts to. Because my clutch seems to have gone prematurely and I was thinking oil got in the mix. That stem is literally a hole in the block. But it's also close to the bellhousing plug, which, if your clutch is leaking oil, then, yes, it could spit it out of that plug. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 27, 2014 Share Posted December 27, 2014 I think I got the issue with the hoses as well.. I had to remove the hoses to take the ocv off.. well I did not know they pop up and need a clamp so I have oil sitting on top of the block which will explain the heavy white smoke. Link to comment Share on other sites More sharing options...
Lafta Posted December 28, 2014 Share Posted December 28, 2014 Oh fer puck sakes! This just makes me want to sell....again I changed my pcv, but not the assembly. Must one? Link to comment Share on other sites More sharing options...
kzr750r1 Posted December 28, 2014 Share Posted December 28, 2014 How did you change the PCV without changing the assembly? If you didn't crack the manifold then good on you... Some have been able to do it. Link to comment Share on other sites More sharing options...
Lafta Posted December 28, 2014 Share Posted December 28, 2014 ^^^Ah, ok. I should reiterate...My mechanic changed my pcv. That's me....still learning. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted December 28, 2014 Share Posted December 28, 2014 I need to get that pool of oil up sitting on the heads near the intake manifold area Link to comment Share on other sites More sharing options...
