scontivt Posted August 12, 2014 Share Posted August 12, 2014 See if the dealership will charge you for inspecting the turbo. Maybe consider having them do it anyway, as you might be able to get that replaced under your warranty too. Also, from my understanding, standard procedure on a head gasket job usually requires a timing job (at least a re-timing after re-assembly of the engine, as the timing components do come off), don't know why you couldn't just supply them with the timing parts if Honda won't cover them. Congrats on the warranty work, I squeezed over $4000 out of my Dealership warranty (Tires, brakes, calipers, and rotors, driver's side mirror, and a few other things). Link to comment Share on other sites More sharing options...
Max Capacity Posted August 12, 2014 Share Posted August 12, 2014 Pretty much what he said ^. The timing belt kit should be the cost of the parts only. The turbo is laying ona table somewhere see if they can show it to you. Tell them you've never seen one and would like too. Then grab the shaft and check for up/down and in/out play in the shaft. See if they'll replace the banjo filters or remove them from both heads. You really don't want them in there. Your exhaust rattle is most lilkely a heat shield. I removed mine years ago, the big one behind the tranny. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 12, 2014 Author Share Posted August 12, 2014 I called back subaru and you guys were right all the way... They will only charge me the parts for the timing and they will call me when all the parts will be removed so I can inspect them. Thanks for the tips... I'll ask them to remove the banjo bolts filters then. Jeff Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2014 Share Posted August 13, 2014 Good to hear. Hey see if they'll install a catless up pipe too. Is your's a 05-06 ? To do that you'll need a 2.2k ohm resistor in the EGT connector to delete it from the system. Radio Shack has them. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 13, 2014 Author Share Posted August 13, 2014 05 lgt wagon indeed. I was planning on gutting the cat from the oem up-pipe myself, bolting up the egt sensor hole and putting the 2.2kohm resistor mod to avoid CEL. http://webpages.charter.net/baraboo_halls/auto/wrx/up/uppipe_fix.html I'm just not sure I will have enough time to do it before the dealer rebuild the engine. I might also look for a used one at a scrap yard or some place selling used. Jeff Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2014 Share Posted August 13, 2014 Whatever you can do or find. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 13, 2014 Share Posted August 13, 2014 I have a perrin up i'm not using. No EGT bung PM me if interested. Good luck. Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 13, 2014 Author Share Posted August 13, 2014 Found a guy locally that has both a OEM 02 wrx up pipe and an aftermarket one for sale. He said he wanted something like 30$ for the oem and I don't know how much for the aftermarket one. Taking any of them will give me enough time to make sure my up pipe is catless. I'll pick it up tonight. Jeff Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 13, 2014 Share Posted August 13, 2014 Score! Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 13, 2014 Author Share Posted August 13, 2014 Bought a godspeed up pipe, brand spankin new for 25$. Lol.... No studs tough. Will have to buy a bolt for the egt bung. Can i put bolts instead of the studs ? Or put bolts then cut the heads... Jeff Link to comment Share on other sites More sharing options...
Max Capacity Posted August 13, 2014 Share Posted August 13, 2014 I guess your new here so, here I bolted my turbo on years ago, its much easier to line up everything. Hey may be get a new oil return line too. http://i185.photobucket.com/albums/x40/92Si/DSCN4782.jpg Those bolts came from the dealer, they are the ones that hold the up pipe bracket to the block. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 14, 2014 Author Share Posted August 14, 2014 Ok so I don't need bolts or studs then. I'll return those 5 long bolts I found. Thanks for all your tips and time, its really apreciated. Here's the new uppipe I just got for 25$. Jeff Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 14, 2014 Share Posted August 14, 2014 Have a hard time trusting flex pipes... Great deal, but just gonna say keep an eye on it. Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 14, 2014 Author Share Posted August 14, 2014 Yep, and if it starts to leak i'll have my gutted oem up pipe waiting. I had the same fear, but for 25$ I tought what the hell... And seeing all those high end after market uppipes with flex is kind of reassuring. Link to comment Share on other sites More sharing options...
Gex Posted August 14, 2014 Share Posted August 14, 2014 Cheap shit is cheap shit. It will fail and you will be replacing it in my guess under 5,000 miles. I would rather pay $50-75 for a sti uppipe I know won't fail so I don't have to climb under the car and reinstall. Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 15, 2014 Share Posted August 15, 2014 Gutted up would be my preference over doing the job twice. It's not hard but need some perseverance to muscle through it and clean it up well after. Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 15, 2014 Author Share Posted August 15, 2014 Yeah the thing is I won't have time to do the job... the original up pipe is still attached to the exhaust and I can only take a look. The dealer agreed to install another up pipe but I don't have time to gut the oem one... I'll check if i have the weekend to do the job, then it will be another story. The one I bought isn't that cheap neither, its 14 gauge stainless steel, polished all over with stainless flex braided both inside and outside. http://www.ebay.ca/itm/GODSPEED-02-07-WRX-STI-GDA-GDB-EJ20-EJ25-TURBO-2-5-STAINLESS-UPPIPE-UP-PIPE-JDM-/390558272305?pt=Motors_Car_Truck_Parts_Accessories&hash=item5aef164b31&vxp=mtr&_uhb=1 jeff Link to comment Share on other sites More sharing options...
Max Capacity Posted August 15, 2014 Share Posted August 15, 2014 I think you'll be fine with the flex pipe one. Go ahead and have them install it. It should last a few years at least. It may also gave you a little more flexability when installing the tmic. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 15, 2014 Share Posted August 15, 2014 Just don't loose momentum and prep yours so it's ready when needed. Good luck. Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 15, 2014 Author Share Posted August 15, 2014 Called the seller back and i took the oem from a 02 wrx instead. Some gutting to do before monday. The flex already had loose metal parts stuck in it... Not reassuring for feeding a turbine. Jeff Link to comment Share on other sites More sharing options...
Max Capacity Posted August 15, 2014 Share Posted August 15, 2014 Good choice. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 16, 2014 Author Share Posted August 16, 2014 The heatshield was loose on the old oem up pipe so I removed it using a wheel saw. The flex on the oem was broken. Garbage... How much is a OEM STI or WRX up pipe from the dealer ? Jeff Link to comment Share on other sites More sharing options...
Th3crack3r Posted August 19, 2014 Author Share Posted August 19, 2014 Went berserk on my original up pipe, 1h later it is all free and shinny. Can I plug the egt bung with the old sensor( broken flush inside) or should I put a bolt in there ? Jeff Link to comment Share on other sites More sharing options...
Gex Posted August 19, 2014 Share Posted August 19, 2014 Put a bolt in the bung. Half a busted sensor can still potentially break and go into the turbo. Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 19, 2014 Share Posted August 19, 2014 Anybody know the thread dimensions of that booger? Link to comment Share on other sites More sharing options...
