imprezkid Posted June 7, 2014 Share Posted June 7, 2014 Car: 2008 Subaru Outback XT w/ AT ( more activity here) Backstory: Drove home from work last night, parked car. Went to start this morning and no crank on start attempt. Thoughts: Had a fuel leak under the manifold, thought maybe wasn't pressuring up so fixed the leaks and nothing changed. What it's doing: I go to start, gauges sweep like normal, fuel pump primes. Turn key, fuel pump kicks in but no clicks or cranks or anything. No codes unless I hold it for a while then the cruise will flash and crankshaft and Camshaft codes will though I believe p0345,340,350 codes. This only happens if I continue to hold the key in the start position. Checked: fuses, starting in both drive & neutral, brake pedal depressed of course. Fuel leaks, harnesses, disabled the security system per cars101. Any help/thoughts would be great! Thanks in advance Link to comment Share on other sites More sharing options...
12sechatch Posted June 7, 2014 Share Posted June 7, 2014 Check the battery terminals. Loosen them, move them around a bit, then re-tighten. Sounds simple I know...but do it. report back. Link to comment Share on other sites More sharing options...
imprezkid Posted June 7, 2014 Author Share Posted June 7, 2014 Had them both off and reinstalled, no corrosion, nothing out of ordinary. Tightened back up Link to comment Share on other sites More sharing options...
12sechatch Posted June 7, 2014 Share Posted June 7, 2014 No clicks or anything says to me the starter might not be acting correctly. Link to comment Share on other sites More sharing options...
imprezkid Posted June 7, 2014 Author Share Posted June 7, 2014 The fuel pump kicking on makes me think that everything is ready for start but the starter isn't kicking over. It's never made a bad noise, problem starting before? Any ideas on starter fuses/relays I should be looking for? Link to comment Share on other sites More sharing options...
Max Capacity Posted June 8, 2014 Share Posted June 8, 2014 Dose the battery have 12+ volts in it ? How old is the battery ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
imprezkid Posted June 9, 2014 Author Share Posted June 9, 2014 Ended up being a pretty embarrassing fix, somehow the negative lead fell off the starter solenoid. Anyhow fixed bad thanks for the help Link to comment Share on other sites More sharing options...
Max Capacity Posted June 9, 2014 Share Posted June 9, 2014 Gee, who put that on last time....? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
