700watts Posted November 15, 2012 Share Posted November 15, 2012 I'm in, with the pool on the passenger floor Link to comment Share on other sites More sharing options...
Sideways the Seven Posted July 18, 2013 Share Posted July 18, 2013 Just noticed the other day that I have this issue. Going to try clearing the debris as it's too hot here (90*+) to run without A/C until I can get to the dealer. -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Dragon-Wagon Posted August 5, 2013 Share Posted August 5, 2013 I recently removed the carpet in my 02 LGT only to find a small swimming pool under the padding on the passenger side. I've been looking for weeks for an answer to what could cause this and just came across this thread. I'll be giving the ol' drain hose a thorough reaming tomorrow morning. Thanks for all the good info! Link to comment Share on other sites More sharing options...
Sideways the Seven Posted August 5, 2013 Share Posted August 5, 2013 I tried to DIY it, but I kept having an issue, it's draining in the footwell and out of the drain hose. It's at the dealer now getting checked out. -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Blink Posted September 20, 2013 Share Posted September 20, 2013 Tried the compressed air bit twice, but issue would resurface 3-4 months later. Disconnected the drain hose from the condenser drip tray and could see it had lots of crud inside. Now nice & clean! Link to comment Share on other sites More sharing options...
Sideways the Seven Posted September 20, 2013 Share Posted September 20, 2013 Finally got mine fixed, the evaporator wasn't sealed against the casing and was leaking around the sides. Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
goneskiian Posted April 28, 2014 Share Posted April 28, 2014 Add mine to the list. Are the AC condenser drain and other drains in that area connected? I don't run the AC much at all and I noticed mine was flooded after a particularly heavy night of rainfall last week. Left the house in the am and noticed a few blocks later that there was a nice puddle in the passenger side WeatherTech liner. Too bad it didin't catch it ALL! Anyway, soaked up what I could with the microfiber cloth I keep for dusting and window finger print cleaning then cranked the passenger side temp to max. I'll check that condenser tray drain and hope that's connected somehow to the other drains. It is an outdoor only car so it's likely full of pollen and other crap. Thanks! Link to comment Share on other sites More sharing options...
ShadowImg Posted April 28, 2014 Share Posted April 28, 2014 Hm, I don't think it is - at least I did clean my moonroof drain tray tubes and they are separate. However, the AC runs with the heat as well, and still produces condensation in there, defroster/etc. Maybe that's what got you? Link to comment Share on other sites More sharing options...
700watts Posted April 29, 2014 Share Posted April 29, 2014 it's either your sunroof or AC.... clean both Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 30, 2014 Share Posted April 30, 2014 Where does the sunroof drain to? I'm not in the habit of opening mine during a downpour but the same can't be said of other drivers. Link to comment Share on other sites More sharing options...
700watts Posted April 30, 2014 Share Posted April 30, 2014 when it not down poring... check your seals and drain holes..ill give you exact location when I go check mine again Link to comment Share on other sites More sharing options...
Claw Posted September 30, 2014 Share Posted September 30, 2014 Spilled a whole bottle of Windex into my passenger side footwell.. how to best clean it? Guess it dripped out during the whole day.. Link to comment Share on other sites More sharing options...
ShadowImg Posted September 30, 2014 Share Posted September 30, 2014 I would say use a vehicle carpet shampoo machine. You need to really saturate it with water and vacuum that water out several times. Link to comment Share on other sites More sharing options...
