SubyDude81 Posted April 6, 2014 Share Posted April 6, 2014 I need a little info on finishing up my Brembo Upgrade on my 13' 2.5i Here's my current parts list but need some info on what else I need. Front Brembos off 04' STI Rear Brembos off 04' STI 5x100 front rotors I know I need 04' STI pads front and rear I have upgraded stainless steel brake lines on my 2.5i now but are they compatible with the STI calipers? I know I need the KNS version 2 adapter and the 08+ STI dual drilled 5x100/5x114 rotors but will my current parking brake work? Link to comment Share on other sites More sharing options...
minuccims Posted April 6, 2014 Share Posted April 6, 2014 (edited) OK, so here is what you are looking for: Front Calipers: 2004+ STI - direct bolt on Rears have two options. First is way way better. Rear Calipers Option1: 2008+ STI - direct bolt on Rears Caliper Option2" 2004-2007 STI with KNS V2 rear bracket Rotors: DBA makes dual drilled 5x114 and 5x100 rotors. KNS Brakes, OAKOS and Infamous are vendors here and will be more than happy to make sure you get the right parts. There are more dual drilled options for the Fronts than the backs. Pad options include Carbotech, Hawk, Stoptech and a few OEM type pads. Decide how aggressive you will be with the car. AutoX and occasional track day will push the pad type. This is an area where you can spend a little or spend a lot and never get the benefits of the pads. SS lines are 100% compatible. EDIT: You need a 5th gen kit; Brembo and OEM mate up to the same SS fixture. Use quality fluid that boils at higher temps. ATE 200 and Motul are two good ones. Edit: one more thing. GTEASER pay attention: I have gone though the screeching brakes from hell. Low speeds in populated areas is when it happens. I blamed the pads, but it is where you lube the pads, and with WHAT. Gone through 3-4 different lubes (or some all it brake grease). First DO NOT use anti-seize. The temps make this hard. Use Permatex 24125. http://ecx.images-amazon.com/images/I/51nzdNAmQ8L.jpg Edited April 8, 2014 by minuccims Link to comment Share on other sites More sharing options...
SubyDude81 Posted April 6, 2014 Author Share Posted April 6, 2014 thanks for the info Will my parking brake work? Link to comment Share on other sites More sharing options...
faded-a-fool Posted April 6, 2014 Share Posted April 6, 2014 thanks for the info Will my parking brake work? Yes Link to comment Share on other sites More sharing options...
Hepy117 Posted April 6, 2014 Share Posted April 6, 2014 Are the 08+ fronts direct bolt on? Link to comment Share on other sites More sharing options...
GTEASER Posted April 6, 2014 Share Posted April 6, 2014 Yes, 04-13 fronts are direct bolt on. 08-13 rears are direct bolt on. 04-07 rears need the bracket from KNS because the parking brake drum was smaller than ours for those years. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
minuccims Posted April 6, 2014 Share Posted April 6, 2014 Yes, 04-13 fronts are direct bolt on. 08-13 rears are direct bolt on. 04-07 rears need the bracket from KNS because the parking brake drum was smaller than ours for those years. In the past, I may have perpetuated the statement that the 04-07 e-brake drum size is 170mm. But they are 190mm just like 2008+. The bracket is needed on the 04-07 to adapt to the bolts for our platform, the same as 08+ STI. WRX and 4th gens use a different 5x100 rear rotor so the 170mm drum works with thier e-brake. So it's critical to make sure you get the correct dual drilled rear rotor that has the 190mm drum. Link to comment Share on other sites More sharing options...
dodgyozzy Posted April 7, 2014 Share Posted April 7, 2014 This is a timely thread for me. I'm picking up a set of 08+ Sti Brembos with pads. They said they might have rotors as well but I want to be sure what it is I need. All their parts are off STi's so will 08+ rotors fit on our cars? I was under the assumption that they wouldn't but maybe they are dual drilled? Also will the SS break lines from an STI fit or do I need to buy ones specifically for our car. Thanks Link to comment Share on other sites More sharing options...
Rutchard Posted April 7, 2014 Share Posted April 7, 2014 You need brake lines for the 5th gen LGT, STi ones won't work. The rotors probably aren't going to fit unless they're aftermarket ones that are dual drilled 5x100-5x114.3 Link to comment Share on other sites More sharing options...
acumenhokie Posted April 7, 2014 Share Posted April 7, 2014 Also will the SS break lines from an STI fit or do I need to buy ones specifically for our car. Thanks I'm guessing the fronts will fit but rear will not (or maybe I'm backwards). I know one or the other requires a unique 2-piece vs. 1-piece fitment. Probably better off just buying a 5th gen specific kit. Link to comment Share on other sites More sharing options...
Syndicate Posted April 8, 2014 Share Posted April 8, 2014 ...not to hijack this thread, but I've been back and forth about the Brembo upgrade. Is the upgrade really worth it if the car isn't being tracked (it's my understanding that larger calipers improve fade resistance not stopping distance)? Link to comment Share on other sites More sharing options...
Drift Motion Posted April 8, 2014 Share Posted April 8, 2014 ...not to hijack this thread, but I've been back and forth about the Brembo upgrade. Is the upgrade really worth it if the car isn't being tracked (it's my understanding that larger calipers improve fade resistance not stopping distance)? if you are not tracking, get good pads, stainless steel lines, and good fluids Link to comment Share on other sites More sharing options...
minuccims Posted April 8, 2014 Share Posted April 8, 2014 ...not to hijack this thread, but I've been back and forth about the Brembo upgrade. Is the upgrade really worth it if the car isn't being tracked (it's my understanding that larger calipers improve fade resistance not stopping distance)? Going on the 4th year with Brembos. On of the best mods done and would get them again. Sure, it's a little extra cost. Brembos weigh less than OEM. Everyone always bitches about how much wheels weight and the need to reduce unsprung weight. Well, here's you're chance. I experienced OEM brake fade early in my LGT experience. Once was enough to go straight to Brembos. Peace of mind all the time. Have used $40 pads on the fronts that kicked ass relative to the OEM setup. Those pads performed the same from new to end of life. Can't say that for OEM setup. If you just spend a bunch on your new wheels and are putting more rubber on the road, if you are driving aggressively, the rotors will heat up, possibly above what the street pads can take. Brake modulation - check. It's kind of like having no throttle control until after a pro-tune. Finally new wheels with less spokes + OEM calipers = epic fail. Eyes go right past those sweet wheels and fixate on those ugly calipers. The rears will look way to small. Lowered your ride? Well, check out that ridiculous gap from the rotors to the inside of the rim. Embarrassment. So BBKs are performance peace of mind and bling support. If you do mods to go fast, why not have a mod plan to stop? Link to comment Share on other sites More sharing options...
minuccims Posted April 8, 2014 Share Posted April 8, 2014 (edited) I'm guessing the fronts will fit but rear will not (or maybe I'm backwards). I know one or the other requires a unique 2-piece vs. 1-piece fitment. Probably better off just buying a 5th gen specific kit. Buy a 5th gen kit. In the original post I state 100% compatible in that the Brembo and OEM calipers interface to the same fixure on the Legacy OEM brake lines and the SS lines in the kit. WRX rears are too short. 4th Gen Legacy are two pieces rather than one. 4th gen fronts fit, not sure about WRX fronts. Edited April 8, 2014 by minuccims Link to comment Share on other sites More sharing options...
minuccims Posted April 8, 2014 Share Posted April 8, 2014 Be careful about only modding the front with BBKs. Read up on brake bias. If you only add front BBK with better pads, more weight shifts forward. Plan to get some aggressive pads for the back to limit too much forward bias. This is a timely thread for me. I'm picking up a set of 08+ Sti Brembos with pads. They said they might have rotors as well but I want to be sure what it is I need. All their parts are off STi's so will 08+ rotors fit on our cars? I was under the assumption that they wouldn't but maybe they are dual drilled? Also will the SS break lines from an STI fit or do I need to buy ones specifically for our car. Thanks Link to comment Share on other sites More sharing options...
dodgyozzy Posted April 8, 2014 Share Posted April 8, 2014 Thanks for the info guys, big help for a first timer like myself. Link to comment Share on other sites More sharing options...
DeltaSniper Posted April 11, 2015 Share Posted April 11, 2015 OK, been planning for a Brembo upgrade, I have been trying to compile a parts list... Please tell me if I am on the right track. 2008+ F/R STI Brembo Calipers 2008+ F/R Dual Drilled Rotor Package with Stoptech Pads https://www.knsbrakes.com/c/car-series/762_2005+Subaru+Impreza+WRX+STI/239_KNS+4K+Rotors+and+Stoptech+Street+Peformance+Brake+Pads Do I have to make sure to ask for the 190mm rear parking brake rotor? Am I on the right track here? Link to comment Share on other sites More sharing options...
GTEASER Posted April 13, 2015 Share Posted April 13, 2015 You also need to make sure you have the Brembo caliper bolts. They are a different thread pitch than the bolts for the stock calipers. I got mine at www.oakos.com. You don't have to specifically ask KNS for the 190mm drum rotor, as long as the rotors you are getting are 2008+ STi drilled to 5x100. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
BBPeik Posted April 14, 2015 Share Posted April 14, 2015 What is a ballpark price on the rotors. Just trying to decide if I really want to do this. Also does the abs system need to be recalibrated after the install or is it ok with the upgraded system. Thanks in advance Brendan My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted April 14, 2015 Share Posted April 14, 2015 Never mind on the parts prices. Just found them, but the abs question still applies. Thanks My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
amidroc Posted April 16, 2015 Share Posted April 16, 2015 Subbed -amidroc Link to comment Share on other sites More sharing options...
Because Racecar Posted May 7, 2015 Share Posted May 7, 2015 Where do you all source the calipers? Is there a vendor that has a kit for the LGT? Link to comment Share on other sites More sharing options...
GTEASER Posted May 7, 2015 Share Posted May 7, 2015 (edited) Keep an eye out for used 2008+ STi Brembo calipers on NASIOC, IWSTI, etc. Otherwise they are about $650 each new front and $550 each new rear from Subaru. Used ones in good condition usually get snapped up pretty quick. If you want the old goldies and are willing to rebuild the pistons and have them powdercoated, you can usually get them pretty cheap on EBay, but watch for stripped threads. Edited May 7, 2015 by GTEASER GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Because Racecar Posted May 7, 2015 Share Posted May 7, 2015 Anyone else want to watch NASIOC for me? Hehe Link to comment Share on other sites More sharing options...
Zee199969 Posted May 8, 2015 Share Posted May 8, 2015 http://forums.nasioc.com/forums/showthread.php?t=2719543 My "Build" Link to comment Share on other sites More sharing options...
