itzed Posted March 8, 2014 Share Posted March 8, 2014 Replacing a front bearing on my 2006 2.5i with 172K. I've removed the bolts holding the hub on, but it's completely frozen. The axle is loose, but it's frozen to the steering knuckle. I hit the darn thing so hard that the bearing actually came apart. Any ideas how I can get this thing off? Link to comment Share on other sites More sharing options...
12sechatch Posted March 8, 2014 Share Posted March 8, 2014 Keep hitting it. You're not going to damage the bearing any more. Link to comment Share on other sites More sharing options...
underpowerd Posted March 8, 2014 Share Posted March 8, 2014 looks like you've got a good soak on it -- using pb blaster & letting it sit for a while? (not liquid wrench/wd -- BIG difference for that job) Link to comment Share on other sites More sharing options...
Gex Posted March 8, 2014 Share Posted March 8, 2014 Bigger hammer. Maybe some heat. Link to comment Share on other sites More sharing options...
bigleben Posted March 8, 2014 Share Posted March 8, 2014 Hit it with a chisel where the red arrow is and around. Worked for me. Link to comment Share on other sites More sharing options...
lovedr79 Posted March 10, 2014 Share Posted March 10, 2014 what about using an air chisel where the red arrow is? Link to comment Share on other sites More sharing options...
lingling1337 Posted March 11, 2014 Share Posted March 11, 2014 excessive cussing and a bigger hammer is what it took for me. Link to comment Share on other sites More sharing options...
JmP6889928 Posted March 11, 2014 Share Posted March 11, 2014 You don't have that off yet? Seriously? Smack the four corners of the hub directly over the holes with a BFH-straight into the knuckle. Go around from hole to hole about 2-3 times and then smack it right on the side of the bearing housing and it should come loose easily. Link to comment Share on other sites More sharing options...
