stealitall Posted February 15, 2014 Share Posted February 15, 2014 Just got a Q?. Would it hurt or Help if I get Whiteline KCA409 with AVO Subaru Legacy GT + 0.50 Lower Arm Bushing Kit. Non track but heavy foot and Love to corner... Link to comment Share on other sites More sharing options...
Gex Posted February 15, 2014 Share Posted February 15, 2014 Yes LCA's are a great upgrade to the LGT and really help with front end lift in corners. I went with the whiteline kca 334 which I think is similar to the AVO setup. Not sure if the top hats will make much difference though... Link to comment Share on other sites More sharing options...
covertrussian Posted February 20, 2014 Share Posted February 20, 2014 Are you ever going to consider upgrading your struts and springs? If you are, you might better off getting coilovers. Most coilovers come with adjustable top mounts. I know $1k is a lot to cough up, but when you do the math, it becomes cheaper in the long run. $200 for KCA409 $300 for drop in springs $500+ for new struts because stock ones will blow with lowered springs 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
robmat Posted April 19, 2014 Share Posted April 19, 2014 Bump. Also interested to know... Link to comment Share on other sites More sharing options...
Underdog Posted April 19, 2014 Share Posted April 19, 2014 I recommend the KCA409 and Whiteline LCA ALK (KCA334) as mentioned above. Great combo that yields and additional ~1* extra caster and .5* negative camber. Buying $1000 coilovers for the camber plates is the worst possible approach in my opinion (no offense covertrussian). You would be better off spending the money on Konis and keeping stock springs. Of course all of this is moot if you aren't running the best possible tire you can get (or afford) for your application. The Crimson Dynamo Link to comment Share on other sites More sharing options...
covertrussian Posted April 20, 2014 Share Posted April 20, 2014 Buying $1000 coilovers for the camber plates is the worst possible approach in my opinion (no offense covertrussian). You would be better off spending the money on Konis and keeping stock springs. Agreed, all depends on what your looking for out of the car. On my previous car I spent almost 1.5x the cost of BC's on different shock and spring combos, trying to find a setup that would handle well and was comfortable, ended up with coilovers at the end of the day. At the end of the day, get what ever is cheapest that you like. Sadly for me it's either stock springs or coilovers. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
