Stang70Fastback Posted January 29, 2014 Share Posted January 29, 2014 So we all know that there are various upgrade options with regards to the rear wipers on our cars. Does anyone know if there are any newer, sleeker arms for the FRONT wipers that we can slap on? Would be an interesting upgrade if so... Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted January 29, 2014 Share Posted January 29, 2014 I can't say I've seen different arms, but I have experimented with different springs to help pull the arms down. An old mechanix illustrated I've got suggests 1 oz of pull for each inch of blade. It's not a visible change, just a functional one. Link to comment Share on other sites More sharing options...
PtPixel Posted January 29, 2014 Share Posted January 29, 2014 I can't say I've seen different arms, but I have experimented with different springs to help pull the arms down. An old mechanix illustrated I've got suggests 1 oz of pull for each inch of blade. It's not a visible change, just a functional one. Did you change the springs and did you see any difference in function? Link to comment Share on other sites More sharing options...
Zues Marine Posted January 29, 2014 Share Posted January 29, 2014 there is the OEM wind deflector attachment that is beyond effective, albeit hard to find Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 29, 2014 Author Share Posted January 29, 2014 I already have that. Definitely helps. Link to comment Share on other sites More sharing options...
Zues Marine Posted January 29, 2014 Share Posted January 29, 2014 I'll send you my shipping address right away! Link to comment Share on other sites More sharing options...
Wheelbuilder_25 Posted January 29, 2014 Share Posted January 29, 2014 I definitely saw a difference on the rear wipers I've changed the springs in. I think it helps more on wipers that are worn, and arms that have tired pivot points. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted January 29, 2014 Share Posted January 29, 2014 Trick Onyx blades. Best things I've ever used. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 29, 2014 Author Share Posted January 29, 2014 Trick Onyx blades. Best things I've ever used. Yeah, I have Bosch Icons. I wasn't referring to the blade, though. I was referring to the wiper arms themselves. Like how on the rear we can put a nice, sleek-looking blade from a newer Tribeca or an '07 Honda Pilot. I was thinking surely there must be ONE vehicle with a similar windshield size that we could steal the wiper arms from. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted January 29, 2014 Share Posted January 29, 2014 ahhhhhh nope, I've got nothing Link to comment Share on other sites More sharing options...
Bassnectar Posted January 29, 2014 Share Posted January 29, 2014 Is itPossible to put heated wipers from a 3rd gen on our cars? Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
98 OB RNV Posted January 29, 2014 Share Posted January 29, 2014 Im going back to the Subaru wrecker to do some measurements. I modified a 05 GT wagon rear wiper to fit on my 97 Outback. A little Dremel work and it works awesome. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 29, 2014 Author Share Posted January 29, 2014 Is itPossible to put heated wipers from a 3rd gen on our cars? Sent from my SGH-I337M units g Tapatalk Heated wipers were an option on the 2nd Gen as welthe wipers them. It's not the wipers themselves that are heated. It's the windshield itself that had a heating filament on the bottom where the wipers sit. Link to comment Share on other sites More sharing options...
Bassnectar Posted January 30, 2014 Share Posted January 30, 2014 Interesting what's the retrofit for our vehicles? Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 30, 2014 Author Share Posted January 30, 2014 Like I said, you need to replace the windshield with a heated model, which has heated filaments much like your rear window would, just all clustered at the base. It's a more expensive windshield (obviously). Other than that you just need the switch. You might already have the wiring in the car. It was part of the cold weather package (heated mirrors and seats) but I dunno what wires are left on the car regardless of the options. The switch sits on the center console just ahead of the armrest. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted January 31, 2014 Share Posted January 31, 2014 Where do you guys find the spring that fits the rear wiper arm? mine misses about a huge 5 inch spot in the middle and only wipes about a total 3 inch area on the glass. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 31, 2014 Author Share Posted January 31, 2014 Yeah. Mine does the same thing. I think I put too curvy of a blade on it and it's lifting up the middle too much. Link to comment Share on other sites More sharing options...
spooln30 Posted February 1, 2014 Share Posted February 1, 2014 For the best results and longer wiper life I use the windshield washer fluid with Rain X and a good set of blades. The set I have on my LGT now are about a year and a half old and still work great. This has been a bad winter here in WI and they still are great. I'd bet I'll get another 6-12 months for sure. I've found over the years that using the Rain X washer fluid or actually putting Rain X on the windshield helps prolong the wiper blades life and its a practice I've started my whole family on. Another trick I do is about every 3 months I'll take a paper towel with some rubbing alcohol and clean the rubber of the wiper. Link to comment Share on other sites More sharing options...
spooln30 Posted February 1, 2014 Share Posted February 1, 2014 Forgot, if you have a set of those wiper blades that form to the windshield and you notice the right blade seems like its not forming to the glass on the leading edge next time buy a wiper blade that is one inch shorter. It helps. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted February 1, 2014 Share Posted February 1, 2014 Yeah. Mine does the same thing. I think I put too curvy of a blade on it and it's lifting up the middle too much. mines not that issue, long story short 2 years ago I picked up a brand new rear wiper for my other legacy and forgot to take it off when the car was totaled, so when I got my other legacy I was back again to an old wiper. So I ask again for those that replaced the spring which spring did you use for the wipers? Link to comment Share on other sites More sharing options...
