Stevo F Posted January 28, 2014 Share Posted January 28, 2014 I saw this before and reread it again. Looks like the wiring is the same wire for wire, but you have to turn the MSD unit around so the harness is on the drivers side (it's on the passenger's side on the stock coil. However, the photo above in this thread shows the harness on the passengers side for the MSD... so still a little confused on which direction the MSD goes... Link to comment Share on other sites More sharing options...
pleaidestar Posted January 28, 2014 Share Posted January 28, 2014 Negative, though it doesn't really matter my coil was positioned the same as stock I just turned the harness up and tape it or be fancy and get a plastic loom. Link to comment Share on other sites More sharing options...
twisty Posted January 28, 2014 Share Posted January 28, 2014 That would be a great idea!- especially we can make this thread into a sticky. theres already a link to an extremely detailed MSD thread in the stickies ya, his link in that other thread (http://www.sl-i.net/FORUM/viewtopic.php?f=39&t=11704l) is what i used to wire mine. its very detailed and has good pics in it. as for not ruining the coil, mine was bad anyway, so i wasnt going backwards either way. i also picked up a new one at the pick n pull with brand new plug wires for 12 bucks, as well as a neon coil. i have spares, i paid less for the harness and two coils with new plugs than you can get the OEM coil for lol. Link to comment Share on other sites More sharing options...
Zues Marine Posted January 28, 2014 Share Posted January 28, 2014 are you talking normal neon coilpack or the MSD one twisty? Link to comment Share on other sites More sharing options...
twisty Posted January 29, 2014 Share Posted January 29, 2014 i put the MSD in my wagon. after that, i was in a different yard and came across a neon with the coil on it, tested it and grabbed it for a few bucks. i also found a 97 impreza 2.2 with brand new plug wires and coil, so i grabbed those as well. so, now i have the MSD on my wagon with almost new oem plug wires, a good stock coil and a good neon coil sitting on the bench just in case. i may put the neon coil in the GT to see how different it runs, then upgrade to the MSD to see the change as well. im kind of curious. i got both coils and the plug wires for about 25 bucks, so it wasnt much of a waste to have extra parts to mess with. Link to comment Share on other sites More sharing options...
Stevo F Posted January 29, 2014 Share Posted January 29, 2014 Is there a significant upgrade between the stock Subaru OEM coil and an OEM Neon coil? Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted January 29, 2014 Share Posted January 29, 2014 Is there a significant upgrade between the stock Subaru OEM coil and an OEM Neon coil? Yes. Stock Subaru coil puts out 22kv. Dodge Neon coil puts out 28 or 32kv (can't remember at the moment). MSD 8239 coil puts out 34kv. Link to comment Share on other sites More sharing options...
kurtis9813 Posted February 3, 2014 Author Share Posted February 3, 2014 Installed the coilpack the other day along with new ngk plugs and wires and have noticed a constant 3-4 mpg increase along with a better idle, a slight power increase and better throttle response. Next week im installing group n motor and transmission mounts. Can't wait to see what that'l do as well. Link to comment Share on other sites More sharing options...
Stevo F Posted February 3, 2014 Share Posted February 3, 2014 Installed the coilpack the other day along with new ngk plugs and wires and have noticed a constant 3-4 mpg increase along with a better idle, a slight power increase and better throttle response. Next week im installing group n motor and transmission mounts. Can't wait to see what that'l do as well. That sounds sweet- just what I need for my EJ22! I put NGK plugs and wires in last summer but idle was still rough and has gotten a bit rougher recently. Also, MPG's dropped from 27 down to 24 since Fall but I'm thinking a lot of that is because it's winter. Will order mine soon- might wait until we're down with bad weather to put mine in however. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted February 4, 2014 Share Posted February 4, 2014 Installed the coilpack the other day along with new ngk plugs and wires and have noticed a constant 3-4 mpg increase along with a better idle, a slight power increase and better throttle response. Next week im installing group n motor and transmission mounts. Can't wait to see what that'l do as well. Have you replaced your air & fuel filters? These will help nicely if you haven't. More people need to start doing this mod. It makes me sad to see all even all of the highly modified Subarus without these coils underneath their hoods. Link to comment Share on other sites More sharing options...
DGR81 Posted February 5, 2014 Share Posted February 5, 2014 I found this and I was wondering what the difference is besides the pins and would it still work with the Subie http://images.streetsideauto.com/images/bccx/image/8239_frm29224.pdf Link to comment Share on other sites More sharing options...
twisty Posted February 5, 2014 Share Posted February 5, 2014 the 8239 is the same one we all use, it has the flat blade connectors. you could use either of those i suspect, you would just have to find the harness off of an older mitsubishi instead of an older neon. Link to comment Share on other sites More sharing options...
DGR81 Posted February 5, 2014 Share Posted February 5, 2014 Well I got it along with the wire connector from the engine. ^_^ Link to comment Share on other sites More sharing options...
Stevo F Posted February 11, 2014 Share Posted February 11, 2014 OK- almost set. Neon coil wire connector received from Rock Auto, just picked up the correct bolts and assorted heat shrink connectors from Lowes, MSD coil arrives tomorrow. I'm tempted to put it on right away (sick of my idle rattling the windows- well almost), but if something were to go wrong with the install I don't want to be without my Leggy for the snowstorm coming Thursday. Link to comment Share on other sites More sharing options...
pleaidestar Posted February 13, 2014 Share Posted February 13, 2014 Ule be alright, it takes five minutes to switch out one if you are the first person ever to have problems with this mod. Link to comment Share on other sites More sharing options...
Stevo F Posted February 13, 2014 Share Posted February 13, 2014 Yep got all the pieces I need for the mod now. As long as there's no chance of frying something, might do it since I'm snowed in tomorrow. Link to comment Share on other sites More sharing options...
SockMonkey Posted June 21, 2014 Share Posted June 21, 2014 I know this thread is a bit old but I need to know what wires to order. I purchased an MSD coil and NGK plugs second hand, but they were all new. Anyway, I never bothered to ask what engine the wires were for. They were for a 2.2, not the 25 in my 97 GT. They were far to short. My dads car needed wires and they fit fine for him, so it wasn't a total loss Anyway, what year wires do I need to order to fir the engine in my 97 2.5GT? I thought I remember reading that wires for 99 fit, but I can't find that again and just want to be 100% sure. Link to comment Share on other sites More sharing options...
DOHCEJ22E1 Posted June 21, 2014 Share Posted June 21, 2014 You need to order the EJ25D wiring for the MSD 8239 coil. Link to comment Share on other sites More sharing options...
Stevo F Posted June 21, 2014 Share Posted June 21, 2014 The wiring harness needs to be a Dodge plug in order to fit the MSD coil (I believe pick a year between 1996- 2004 and they all should be the same). I believe there is a difference in wiring up a 2.2 vs, 2.5 but the wiring pattern for the new plug should go on the same as the old Subaru wiring you are cutting off. Link to comment Share on other sites More sharing options...
SockMonkey Posted June 22, 2014 Share Posted June 22, 2014 I've got the wiring done no problem. Just the plug wires I originally had were way to short (they fit the 2.2). And the early 2.5 wires don't have the right end on them to fit into the coil. I have to get 98 and newer wires. Link to comment Share on other sites More sharing options...
joshmikesad Posted October 20, 2014 Share Posted October 20, 2014 I just got an MSD 8239 and clipped a harness out of a Neon at Pull A Part for $1.75. Going to try to install today/tonight Link to comment Share on other sites More sharing options...
joshmikesad Posted October 22, 2014 Share Posted October 22, 2014 ^^^ Well until I realized I had the old stil shor fat plus on the wires that connect to the coil. Got a new set of wires on the way and new spark plugs. Might as well do it all since it's old, bought used, and dont know previous owner. Link to comment Share on other sites More sharing options...
joshmikesad Posted November 8, 2014 Share Posted November 8, 2014 Also, still trying to figure out the wiring. some people have the coilpack mounted with the connector on the right and some people have the coil pack connector on the left. So which is which? Wouldnt the outer two wires need to be swapped if rotating the coil pack one way versus the other? Any help greatly appreciated as Im trying to install this today. Edit: What would happen if the outer two wires wwere wrong and the car was cranked? Link to comment Share on other sites More sharing options...
Stevo F Posted November 10, 2014 Share Posted November 10, 2014 Also, still trying to figure out the wiring. some people have the coilpack mounted with the connector on the right and some people have the coil pack connector on the left. So which is which? Wouldnt the outer two wires need to be swapped if rotating the coil pack one way versus the other? Any help greatly appreciated as Im trying to install this today. Edit: What would happen if the outer two wires were wrong and the car was cranked? I believe you are right about swapping the two outside wires on the wiring harness if you switch the orientation of the coil around. And I did figure this out by putting those two wires in the wrong location. The car just didn't start, so I switched them around and it fired right up. Link to comment Share on other sites More sharing options...
joshmikesad Posted November 10, 2014 Share Posted November 10, 2014 ok, ill just wire nut the harnesses' wires first to test. then solder and shrinkwrap once confirmed. unless someoone can confirm the colors that need to be matched in advance Link to comment Share on other sites More sharing options...
