Shello007 Posted January 16, 2014 Share Posted January 16, 2014 Anyone familiar with this? Cheap knock off? just asking...seems pretty similar to Grimm's http://www.ebay.com/itm/S2-Industries-AIR-OIL-Separator-Subaru-WRX-STI-VERSION-AOS-/151207715731?pt=Motors_Car_Truck_Parts_Accessories&hash=item2334aea393&vxp=mtr#ht_890wt_1224 Link to comment Share on other sites More sharing options...
KRM Posted January 16, 2014 Share Posted January 16, 2014 It works the same as grimms. China knock off. Plenty of reviews on nastysock about it Link to comment Share on other sites More sharing options...
Max Capacity Posted January 16, 2014 Share Posted January 16, 2014 Mine is a different brand, not sure I'd do it again. Mine has two ports. Got it from a GB on NASIOC, I believe ours are different then STI's. http://i185.photobucket.com/albums/x40/92Si/DSCN4776.jpghttp://i185.photobucket.com/albums/x40/92Si/DSCN4779.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Shello007 Posted January 16, 2014 Author Share Posted January 16, 2014 Gotcha. May take the chance with the Grimm then. Don't want that to be my weakest link. Thanks Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2014 Moderators Share Posted January 16, 2014 Grimmspeed AOS has show to be a bit of a faulty design, just FYI. This is going on for one more day: http://forums.nasioc.com/forums/showthread.php?t=2576662 "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Shello007 Posted January 16, 2014 Author Share Posted January 16, 2014 Grimmspeed AOS has show to be a bit of a faulty design, just FYI. Was doing quite a bit of research and on Nasioc they were going back and forth debating which is best. Thanks Barmanbean... Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 16, 2014 Moderators Share Posted January 16, 2014 As far as I know, there's not too much of a debate anymore--under certain conditions (mostly track conditions) the GS unit seems to kill motors. You could argue for a lot of folks who don't track their cars that it's really a non issue, but why take the chance especially if you are looking at the current group buy that makes the prices pretty close to the same. I'm also leaning towards the Crawford myself because it removes the PCV setup--I think the GS setup leaves it in place. I figure removing it is one less thing that can fail down the road. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
chato Posted January 16, 2014 Share Posted January 16, 2014 done a ton of reading on this. I think you can also build a really great system with a two $30 ebay catch cans. There plenty of good DIY on how to turn those ebay cans into useful catches with the addition of steel mesh. The two can system and its logic is explained well here (eventually) as well as how the crawford AOS works: http://www.iwsti.com/forums/2-5-liter-litre-factory-motor/146699-official-sti-engine-venting-o-separators-catch-cans-thread.html Link to comment Share on other sites More sharing options...
rob-2 Posted January 16, 2014 Share Posted January 16, 2014 When I was debating needing this product it was because I had lost compression. If you have a lot of blow by this isn't a fix. Find the case. I would avoid it personally. Even at $150 I think it's a rip off. Link to comment Share on other sites More sharing options...
