idontknow Posted December 19, 2013 Share Posted December 19, 2013 I've got an 06 leggy gt with 120k miles and suddenly its started losing oil at an alarming rate of about a quart every 1000 miles! There are no signs of oil leaks in the engine bay or driveway, no loss of power, no smoke from the tailpipes, and compression is fine. I'm at a loss here! Where the heck could that much oil be going without leaving some sign of trouble? Any ideas? Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
Moddiction Posted December 19, 2013 Share Posted December 19, 2013 How do you know no smoke from tailpipes? If not leaking then it's definitely burning it. WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
idontknow Posted December 19, 2013 Author Share Posted December 19, 2013 Followed the wife around town for a 20 min drive. Local shop that did the compression check confirmed it. Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
Gex Posted December 19, 2013 Share Posted December 19, 2013 Leak down numbers? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 19, 2013 Share Posted December 19, 2013 PCV could be plugged up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
idontknow Posted December 19, 2013 Author Share Posted December 19, 2013 What are "leak down numbers"? Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
Moddiction Posted December 19, 2013 Share Posted December 19, 2013 It's a leak down test. Shows better info compared to a compression test to show where if at all compression is leaking. WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
DonnyJagaru Posted December 19, 2013 Share Posted December 19, 2013 I put no-name brand motor oil in a 1979 Oldsmobile I drove from Toronto to Miami one time and it drank it up fast. I added a quart in Ohio and another in Georgia. I changed the oil in Miami before driving back home with the cheaper Mobil and didn't need to add anything. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 19, 2013 Share Posted December 19, 2013 79 oldsmobile....I'm sorry 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
KCwagon Posted December 20, 2013 Share Posted December 20, 2013 I put no-name brand motor oil in a 1979 Oldsmobile I drove from Toronto to Miami one time and it drank it up fast. I added a quart in Ohio and another in Georgia. I changed the oil in Miami before driving back home with the cheaper Mobil and didn't need to add anything. Great story Link to comment Share on other sites More sharing options...
idontknow Posted December 20, 2013 Author Share Posted December 20, 2013 I put no-name brand motor oil in a 1979 Oldsmobile I drove from Toronto to Miami one time and it drank it up fast. I added a quart in Ohio and another in Georgia. I changed the oil in Miami before driving back home with the cheaper Mobil and didn't need to add anything. Did you use the same weight of oil? Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 20, 2013 Share Posted December 20, 2013 79 oldsmobile....I'm sorry Dude....you are such a shit.... Link to comment Share on other sites More sharing options...
DonnyJagaru Posted December 20, 2013 Share Posted December 20, 2013 Haha! I've seen the light and own Subaru now. I just mentioned the story 'cuz it illustrates what a difference brand of oil makes, even on purportedly "easy" highway miles. Link to comment Share on other sites More sharing options...
