Rob05GT Posted December 11, 2013 Share Posted December 11, 2013 So I've noticed oil on the bottom of the timing belt cover. (Both Sides) And right above the oil cooler. And what looks like trace amounts of oil in my coolant reservoir. No lose in power yet, but I think its close. I've got a compression/leak down test tomorrow. If this takes a turn, I'll be looking for a short block.(Hint Hint, I've been thinking about a motor build as a side project.) The dealership said $2700.00 (New timing belt, idler, valve gaskets, the whole deal) They said because I work at a auto parts store I can source my own parts (20% off Cost) and just pay labor. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 11, 2013 Share Posted December 11, 2013 So your saying $2700 for a rebuilt short block and heads with the other stuff you have listed ? See my click here link for my rebuild. There are other things to think about... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rob05GT Posted December 11, 2013 Author Share Posted December 11, 2013 The quote was $2700.00 for the head gasket repair, which would include an entire head gasket kit, timing belt kit and all components, fluids, labor. They will inspect the spark plug tube seals as well. The advantage to sourcing the parts is clear. I'd only pay for labor and fluids. Not to mention I could get 10% off fluids. In fact I just read through that thread last night....lol We'll know more tomorrow after the compression test. That will determine what I do. I have never dropped a motor in my life, so that seems as though it may be out of my experience. But I love the idea of doing it myself! Link to comment Share on other sites More sharing options...
Leviman Posted December 11, 2013 Share Posted December 11, 2013 Keep in mind, the head gasket can fail in a way which you don't loose compression but you do get oil going into the coolant. In that case, if you haven't killed any bearings, just replacing the gaskets and possibly resurfacing the head can solve the issue. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 11, 2013 Share Posted December 11, 2013 Make sure the gasket set has all the seals in it, remember the 1/2 moons are not part of the engine gasket set.But the spark plug tube seals are. Check what comes in the Head gasket set. Do you want the heads rebuilt. If the engines coming out...do it right. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rob05GT Posted December 11, 2013 Author Share Posted December 11, 2013 What are the 1/2 moon seals? How do the heads get rebuilt? Do they check the seats and re-machine for the valve seat? There is a member who is local (Th3Franz) who say he has EJ255 long block for sale. He said its missing #3 ring, but the leak down was 15%. So it looks like i might have a good project motor! Waiting on a price and final details. But if the compression/leak down test goes well, I might have some time before the engine completely fails. If there is a leak and it does not show on the compression test, what are some worst case scenarios? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 11, 2013 Share Posted December 11, 2013 See the black 1/2 circle seals at the back of the valve covers. http://i185.photobucket.com/albums/x40/92Si/DSCN4770.jpg The heads will get taken apart, cleaned, valves inspected and replaced as needed, the valve seals get replaced, the seats ground, re-assembled. The overall cost is not much if you don't need valves, valves are expensive. Over time the coolant in the oil will make the main and rod bearings fail. Is the car a 5mt or 5eat ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rob05GT Posted December 11, 2013 Author Share Posted December 11, 2013 The car is a 5mt. That 1/2 moon is its own seal? Why didn't they include it in the valve cover gasket? lol The compression/leak will tell me how severe the leak is correct? But if it shows normal, what if I flush the coolant and put new in. Then see if it turns turd green. What do you think? Link to comment Share on other sites More sharing options...
Rob05GT Posted December 13, 2013 Author Share Posted December 13, 2013 UPDATE: Head Gasket is fine. Compression/leak down test went great! But..... The VF40 is done for....shaft play indicated that the shaft bearings are just about dead. Thank god, they haven't died yet! Oil leak is due to bad valve cover gaskets (both sides) and the radiator has a crack in it. The Solution: New valve cover gaskets New Radiator NEW TURBO BNR Stage 2 (VF40-18g)!!!!!!!!!! I'm glad I have a good reason to upgrade the turbo! Link to comment Share on other sites More sharing options...
Max Capacity Posted December 13, 2013 Share Posted December 13, 2013 You'll need fuel pump, injectors and Tune for that turbo. Do you have the funds for that ? Good news on the HG's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rob05GT Posted December 13, 2013 Author Share Posted December 13, 2013 Yeah you are right on that. So I got real and decided on BNR-16g. Sent from my XT907 using Tapatalk Link to comment Share on other sites More sharing options...
TheBlackPearl Posted December 13, 2013 Share Posted December 13, 2013 I went with the 16g on stock fueling with an etune from Cryo and I am as happy as a Camel on Wednesday. Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
