adot111 Posted November 3, 2013 Share Posted November 3, 2013 I got 05 Subaru legacy. It has 180k on it. Yesterday, I found oil leaking on the passenger side, I can see little slowly dripping when engine is running. I heard Subaru has head gasket issue. Does this cause by head gasket? Thanks advance http://i217.photobucket.com/albums/cc14/adot111/IMG_1554_zps9e36bde2.jpg Link to comment Share on other sites More sharing options...
apexi Posted November 4, 2013 Share Posted November 4, 2013 A bad head gasket could cause oil to leak. There are two large oil return passages that sit at the bottom of the engine. http://www.northwoodgarage.net/6397/subaru-head-gasket-woes/ Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 4, 2013 Share Posted November 4, 2013 Take it to the car wash with your lower tray removed. Bring drive on ramps and put the car on the ramps and blast all of the old crap off of there. THEN you can see where the fresh oil is coming from. Then you'll know where the leak is and you can fix the problem. From what I can see, it looks like it's leaking around where the oil cooler meets the block. Link to comment Share on other sites More sharing options...
zenfamily Posted November 4, 2013 Share Posted November 4, 2013 Agreed with above. I chased an oil leak, and found it to be a couple of sources. Valve cover gasket (especially around the half moon seals) and the oil cooler gasket. For the oil cooler, there is a walkthrough which includes draining the coolant. Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted November 4, 2013 Share Posted November 4, 2013 I have this same problem. Does anyone know the part # to the oil cooler where the oil cooler meets the block? Take it to the car wash with your lower tray removed. Bring drive on ramps and put the car on the ramps and blast all of the old crap off of there. THEN you can see where the fresh oil is coming from. Then you'll know where the leak is and you can fix the problem. From what I can see, it looks like it's leaking around where the oil cooler meets the block. Link to comment Share on other sites More sharing options...
chato Posted November 4, 2013 Share Posted November 4, 2013 this is a good walkthough, with part #. good time to do thermostat too. also check the valve cover gasket for leaks. My VC gasket went around the same time as the cooler gasket. clean the heck out of the area before replacing the cooler gasket. they're impossible to clean if crap gets in em. Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted November 4, 2013 Share Posted November 4, 2013 Ok never mind. I got the part # and the price. Subaru Legacy Oil Cooler - 21311AA051 Subaru dealer wants $281 for the part. eBay has them for $210 Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted November 4, 2013 Share Posted November 4, 2013 By the way does anyone know if there is an equivalent aftermarket part to this for cheaper or is this the only available part? Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
chato Posted November 4, 2013 Share Posted November 4, 2013 you don't need a new cooler, just the gasket. unless your cooler is contaminated. Subaru Oil Cooler Gasket - Part Number: 21370KA001 ($10+/-) You will also need a 15/16 deep well socket to get it off. check out the walkthrough I posted above. Link to comment Share on other sites More sharing options...
GTTuner Posted November 4, 2013 Share Posted November 4, 2013 The motor pictured in the original post does not have an oil cooler. Link to comment Share on other sites More sharing options...
chato Posted November 4, 2013 Share Posted November 4, 2013 The motor pictured in the original post does not have an oil cooler. super solid point. it does not. Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted November 4, 2013 Share Posted November 4, 2013 It's my understanding that only the turbo legacies have an oil cooler attached to the block is that right? Link to comment Share on other sites More sharing options...
GTTuner Posted November 4, 2013 Share Posted November 4, 2013 It's my understanding that only the turbo legacies have an oil cooler attached to the block is that right? Yes Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2013 Share Posted November 4, 2013 GT's normally have a leaking valve cover gasket. Not a head gasket. The passenger side is the one that leaks. Lot's of us have had that issue. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 4, 2013 Share Posted November 4, 2013 The motor pictured in the original post does not have an oil cooler. JmP6889928<Busted! I didn't even look that closely...LOL. I know that the oil cooler gaskets have a tendency to leak after a while, so I ASS-U-MEd that was it. My mistake. Possibly, an oil filter that didn't get tightened all the way. Link to comment Share on other sites More sharing options...
GTTuner Posted November 4, 2013 Share Posted November 4, 2013 JmP6889928<Busted! I didn't even look that closely...LOL. I know that the oil cooler gaskets have a tendency to leak after a while, so I ASS-U-MEd that was it. My mistake. Possibly, an oil filter that didn't get tightened all the way. Happens to me all the time when I ASSume lol. Link to comment Share on other sites More sharing options...
adot111 Posted November 4, 2013 Author Share Posted November 4, 2013 JmP6889928<Busted! I didn't even look that closely...LOL. I know that the oil cooler gaskets have a tendency to leak after a while, so I ASS-U-MEd that was it. My mistake. Possibly, an oil filter that didn't get tightened all the way. I will check the oil filter tonight Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2013 Share Posted November 4, 2013 Oh, now I can see the first picture. Yea oil cooler gasket. Or just remove the oil filter and tighten the stud. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted November 4, 2013 Share Posted November 4, 2013 How difficult is it to replace the oil cooler compare to just replacing the gasket itself? Is it as easy as doing a oil change? Sorry for the dumb question but this particular job is one I never had to do before so I don't know what to expect out of it. And yes I did see the "walk through" but someone tell the level of difficulty. Thanks Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 4, 2013 Share Posted November 4, 2013 How difficult is it to replace the oil cooler compare to just replacing the gasket itself? Is it as easy as doing a oil change? Sorry for the dumb question but this particular job is one I never had to do before so I don't know what to expect out of it. And yes I did see the "walk through" but someone tell the level of difficulty. Thanks You don't have an oil cooler, at least not a Subaru oil cooler, so it's virtually impossible to replace it. You could ADD one if you wanted but there isn't one on there. That still doesn't change the fact that you need to blast the area clean first so you can identify the source of the actual leak. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2013 Share Posted November 4, 2013 http://i185.photobucket.com/albums/x40/92Si/DSCN4734.jpg There's mine removed. I'm guessing, in the car, remove oil filter, use a deep 24mm socket to remove the stud bolt holding the cooler on. Not sure how much room you'll have but the coolant lines should give a little space. Pull the old seal and put the new in. You can also see the leaking VC gasket in the photo. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 4, 2013 Share Posted November 4, 2013 http://i185.photobucket.com/albums/x40/92Si/DSCN4734.jpg There's mine removed. I'm guessing, in the car, remove oil filter, use a deep 24mm socket to remove the stud bolt holding the cooler on. Not sure how much room you'll have but the coolant lines should give a little space. Pull the old seal and put the new in. You can also see the leaking VC gasket in the photo. Dude....Look at the first photo by OP. No oil cooler. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 4, 2013 Share Posted November 4, 2013 Duh...right I'll go back and now. Must be the oil filter or the leak is coming from above, say oil pump, crank shaft seal ? Looking further at the first photo. May be it could be the bottom of the head. But I'd clean the area like you said and get a better look. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LegacyGTurbo Posted November 5, 2013 Share Posted November 5, 2013 Actually, I do have an oil cooler cause I have a turbo in my LGT wagon. I got my car checked out by a Subaru Technician who does side work outside of working for Subaru and he confirmed that it was the oil cooler that was leaking. He didn't say that I needed to replace just the gasket nor was he trying to sell me on the service either. He just stated that my oil cooler needed to be replaced in order to stop the oil leak. Now with that being said, I'm assuming that if I replace the oil cooler, it's gonna come with the gasket as well right? Or does it come separately? You don't have an oil cooler, at least not a Subaru oil cooler, so it's virtually impossible to replace it. You could ADD one if you wanted but there isn't one on there. That still doesn't change the fact that you need to blast the area clean first so you can identify the source of the actual leak. Link to comment Share on other sites More sharing options...
JmP6889928 Posted November 5, 2013 Share Posted November 5, 2013 Actually, I do have an oil cooler cause I have a turbo in my LGT wagon. I got my car checked out by a Subaru Technician who does side work outside of working for Subaru and he confirmed that it was the oil cooler that was leaking. He didn't say that I needed to replace just the gasket nor was he trying to sell me on the service either. He just stated that my oil cooler needed to be replaced in order to stop the oil leak. Now with that being said, I'm assuming that if I replace the oil cooler, it's gonna come with the gasket as well right? Or does it come separately? The picture you posted at the beginning shows an engine with an oil filter and NO oil cooler on it. Is this the engine in your LGT? If so, it's one without the oil cooler. Link to comment Share on other sites More sharing options...
