team23jordan Posted August 19, 2005 Share Posted August 19, 2005 i replaced stock yellow looking bulbs with white LEDs they look nice cuz they are white but they are not BRIGHT AT ALL!!! totally POS Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
Xenonk Posted August 19, 2005 Share Posted August 19, 2005 haha, I could have told you that wire up some http://www.streetglow.com products instead.. they work way better Keefe Keefe Link to comment Share on other sites More sharing options...
eamiller Posted August 19, 2005 Share Posted August 19, 2005 not only that, but they burn up way too easily.. they are not automotive rated parts (or they don't derate the current) I have had 3 of 4 burn out (got them off ebay).. Link to comment Share on other sites More sharing options...
team23jordan Posted August 20, 2005 Author Share Posted August 20, 2005 keefe, where did you get all your crystal ion bulbs?? Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
mvigneau Posted August 20, 2005 Share Posted August 20, 2005 They make bright LEDs. Ones that are like 6000mcd+. You can regulate the current with some resistors and diodes so that they don't burn out as easily... No Silent CD Aux-In Solution Link to comment Share on other sites More sharing options...
Xenonk Posted August 20, 2005 Share Posted August 20, 2005 keefe, where did you get all your crystal ion bulbs?? my sponsor gets them for me, but you can get them here at http://www.eautoworks.com Here are ALL the direct links of the bulbs you need for a GT: http://www.eautoworks.com/html/ORD-1-1-1-21967.cfm http://www.eautoworks.com/html/ORD-1-1-1-23600.cfm http://www.eautoworks.com/html/ORD-1-1-1-906.cfm http://www.eautoworks.com/html/ORD-1-1-1-21964.cfm http://www.eautoworks.com/html/ORD-1-1-1-2626.cfm http://www.eautoworks.com/html/ORD-1-1-1-23846.cfm http://www.eautoworks.com/html/ORD-1-1-1-14387.cfm http://www.eautoworks.com/html/ORD-1-1-1-23933.cfm http://www.eautoworks.com/html/search-1-Legacy~Cars~Horn.htm http://www.eautoworks.com/html/ORD-1-1-1-7045.cfm http://www.eautoworks.com/html/ORD-1-1-1-21984.cfm Keefe Keefe Link to comment Share on other sites More sharing options...
Claw Posted August 20, 2005 Share Posted August 20, 2005 What about these? http://www.streetforceleds.com/index.htm Looks fairly bright! Link to comment Share on other sites More sharing options...
team23jordan Posted August 20, 2005 Author Share Posted August 20, 2005 keefe, shipping seems fairly expensive from eautoworks. i was gonna get 7 DE3175 bulbs and shipping came out $25 bucks.. those bulbs aren't big.. anyways, thanks for your help tho Perrin BIG maf intake Perrin Turbo Inlet HKS SSQV BOV Megan Racing header with UP (ceramic coated) HKS DP (WRX) DMH E-cutout Custom 3" catback UTEC Link to comment Share on other sites More sharing options...
ICE-SS Posted August 20, 2005 Share Posted August 20, 2005 FYI, unless specifically stated, most LEDs are directional...meaning that the light is brightest only directly in front, not to either side. Regular bulbs have the advantage of throwing equal amounts of light in all directions. So it may look as though the LEDs are less bright when in fact they are just not wide angle. Link to comment Share on other sites More sharing options...
Jaesx Posted January 3, 2006 Share Posted January 3, 2006 Then you should check out these LED's that I found... www.v-leds.com The refractor halo lights project their light at 90 degree angles and even behind it, to fill up the light housing's reflectors. Pretty cool and look to be quality items. I ordered some this last week and I am dying to get them in the mail! I'll post pics when installed... After waiting for the snail mail to show up. Gunner- Link to comment Share on other sites More sharing options...
Gire Posted January 4, 2006 Share Posted January 4, 2006 Just get some xenon crystal white replacement bulbs. Don't waste money on LED-interior anything. I have used Toucan's Eurolites in my car(s) for about 8 years now and their xenon white series is very bright and pure white. Their 3022's in the dome light locations work great and using xenon's to replace the interior-door-ajar-safety lights light up the street hugely and always draw stares from people at night. I recommend them. Link to comment Share on other sites More sharing options...
mccorry Posted January 4, 2006 Share Posted January 4, 2006 Guys.... go to Radioshack. Buy some 4000-5000 mcd diodes (they have all kinds of colors). These are SUPER bright. To keep them from dying, you MUST wire in a resistor prior to the LED. No LED's are made to run under 12V. When you buy the LED, it will have some values on the package. Plug these valuse in here: http://www.luxeonstar.com/resistor-calculator.php and it will tell you the type of resistor required. The LED's will outlast your car if you do this correctly. Link to comment Share on other sites More sharing options...
Xenonk Posted January 4, 2006 Share Posted January 4, 2006 I just realized, aren't these tube-fuse type bulbs with LEDs are directional? Meaning you gotta rotate them within the light housing to get them pointed in the correct direction? Keefe Link to comment Share on other sites More sharing options...
mccorry Posted January 4, 2006 Share Posted January 4, 2006 All LED's (Light Emitting DIODE) are directional. If you install them backwards, they will not work. Link to comment Share on other sites More sharing options...
firedawgs Posted January 5, 2006 Share Posted January 5, 2006 Does anyone have comparison pictures of the stock vs. aftermarket bulbs? Updated my vBGarage: Link to comment Share on other sites More sharing options...
Scotty Posted January 5, 2006 Share Posted January 5, 2006 If you want to do some custom LED's. Bivar makes a LED that is 60 lumens. High power flashlights like Surefire will put out about 60 lumens which is bright enough to make you look away when shined in your eyes. Link to comment Share on other sites More sharing options...
Cstoop Posted January 5, 2006 Share Posted January 5, 2006 Jaesx, Let me know how those halo leds work out. They look like they will work great. I was going to order them, but I figured I wait till the weather turns a little nicer & i can clear the headlights too. Link to comment Share on other sites More sharing options...
JAU Posted January 6, 2006 Share Posted January 6, 2006 Just curious, doyou have any photos with the LEDs installed? Link to comment Share on other sites More sharing options...
Nsaglibene Posted January 6, 2006 Share Posted January 6, 2006 I got some Led's I was pritty satisfied. I replaced the dome with a 31mm festoon with 9 leds in it. I like the color, and it doesnt seem as intense but it seems to light up more space. I replaced the side markers in the door with red 6 led festoons. The trunk a 5 led matrix which spreads the light rather than being single directional. And just put red single leds in the glovebox and cubby. Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted January 6, 2006 Share Posted January 6, 2006 I have been wondering if it would be easy or good to install some RED leds in the overhead console when I get my Legacy. I sat in an A4 one afternoon as it was getting dark, and turned the parking lights on, to see the dash light up. There were little red LEDs somewhere out of sight in the headliner or overhead panel, that shone down on the center console. They weren't bright, nor do I think they were supposed to be, but they kind of bathed the console in a low red glow, (think darkroom lighting, or even less...) to see the switches, and things... I think that would be a cool thing to add to the overhead panel of a Legacy, and I think I remember someone mentioning it a long time ago. The 06 even has a nice place for it, under the smoked lens, on the windsheild side, "behind" the passenger airbag display. (why it has a passenger airbag display, I have no idea... information that really makes fairly little difference.) I was looking at http://www.theledlight.com/ the other day, and saw this... It is called the golden dragon, and is set up for 12vdc. If they had some sort of rheostat or something that could adjust the intensity (in case it is too bright...) I think this would work well for that purpose. http://www.theledlight.com/img-LEDclusters/led-board.jpg Link: http://www.theledlight.com/led-clusters.html Bottom of the page. They also have replacement bulbs, and other fun stuff on this site, in addition to fun things on other sites like v-leds.com Link to comment Share on other sites More sharing options...
mccorry Posted January 7, 2006 Share Posted January 7, 2006 If they had some sort of rheostat or something that could adjust the intensity (in case it is too bright...) I think this would work well for that purpose. They do..... http://www.theledlight.com/pdf/controls/4amp_dimmer.pdf Link to comment Share on other sites More sharing options...
Scotty Posted January 7, 2006 Share Posted January 7, 2006 The Audi/Volkswagon have 2 red leds in the rear view mirror. You can probably swap it out for one since the Subaru homelink/autodimming mirror is the same as the Audi/Volkswagon's On-Star mirror. Link to comment Share on other sites More sharing options...
Chappy Posted January 7, 2006 Share Posted January 7, 2006 Id like to upgrade the lighting in my map lights and dome. I remember this thread on NASIOC about doing the same thing on a WRX. Any opinions? http://forums.nasioc.com/forums/showthread.php?t=676466&highlight=led+map+light Link to comment Share on other sites More sharing options...
