jeffmazz Posted October 7, 2013 Share Posted October 7, 2013 I have 46,000 miles on my 13' with no issues so far. Wondering how these things are holding up. How many miles do you have and has anyone had any issues with their CVT? Link to comment Share on other sites More sharing options...
hmmrdwn Posted October 7, 2013 Share Posted October 7, 2013 Got 60k. Just had it inspected for rare shudder when shifting from park to drive. Only happens when hot/hot outside. They checked fluid and test drove. No problems. Other people have reported same. The mechanic said 10-12 the cvt was better built and has had no problems. Do get slight electric buzz through radio but that could be poor electrical shielding. Link to comment Share on other sites More sharing options...
Gborja888 Posted October 8, 2013 Share Posted October 8, 2013 Mine got 85K+ km. No problem so far. I've just change the CVT oil for the 2nd time last 80k scheduled maintenance. Link to comment Share on other sites More sharing options...
DugsSin Posted October 8, 2013 Share Posted October 8, 2013 It's somewhat rare but a few high mileage CVT's are having solenoid problems that makes for an abrupt stall when coming to a stop. Some dealers may not or choose to not be aware of it The one's I've heard of have gotten replacement CVT's under warranty. Link to comment Share on other sites More sharing options...
laz Posted October 8, 2013 Share Posted October 8, 2013 24k+ on my '12. No issues what so ever. As smooth as the first day I drove it. Â I thought the oil in the CVT was lifetime? Â X --- Link to comment Share on other sites More sharing options...
jr105 Posted October 8, 2013 Share Posted October 8, 2013 24k+ on my '12. No issues what so ever. As smooth as the first day I drove it. Â I thought the oil in the CVT was lifetime? Â XÂ That's what my owners manual says. No maintenance required on the CVT. Link to comment Share on other sites More sharing options...
bluesuby Posted October 8, 2013 Share Posted October 8, 2013 No fluid is "lifetime", unless you are looking for a short life. Link to comment Share on other sites More sharing options...
laz Posted October 8, 2013 Share Posted October 8, 2013 Response from a Subaru tech in another forums: Sorry for the delay, missed this post. the info posted above is correct. We have to ask why you are feeling the need to change so often; and what you plan to tow that needs the extra cooler. I have taken the school CVT apart, a amazing unit. Overall, very simple in comparison to a normal Automatic. Subaru now has 2 generations of CVT, both have very little that we are allowed to do to them. Our big worry is contamination of the fluid; this is why there is no fill plug. just putting the incorrect fluid in it could cause the chain assy to fail. The transmission requires a clean room for rebuild--- currently there is no facility in the USA to rebuild a CVT. all we can do is replace the valve body. The fail rate on the cvt is very low; a few minor issues on the early ones and we have one with a failed ft diff in the shop now-waiting to ship it back. If one fails;we must take a bunch of pressure readings before removal,than we can replace the transmission.. a real PITA. I have done one fluid adjustment, you do need the scan tool. We also had a few cars come in where we had to adjust the cvt fluid level--- overfilled at assembly.. Also Note-the fluid is very expensive.. http://www.subaruforester.org/vbulletin/f88/anyone-figure-out-how-do-drain-fill-new-cvt-trans-182825/index2.html#post1936193 This is not your father's CVT. X --- Link to comment Share on other sites More sharing options...
PoManzAWD Posted October 9, 2013 Share Posted October 9, 2013 In 2yrs of following this, I have not read of a single 2010+ Legacy CVT failure. There is a post on an Outback forum where an owner changed the CVT fluid himself and there's been several posts where owners have changed their own front differential oil. The CVT has a separate diff housing that holds gear oil. I'm only at ~36K miles on my 2012 Legacy CVT, but it's been flawless. Link to comment Share on other sites More sharing options...
hmmrdwn Posted October 9, 2013 Share Posted October 9, 2013 Talked to a subaru mechanic last night. They have only had one...to replace and that is being done now. They are replaced as a unit. The mechanic went to school and said the first gen cvt's are amazing. He said the belt and drives are polished like you wouldn't believe. The one they are working on had a noise in the front diff. Both the diff and cvt are on unit. Link to comment Share on other sites More sharing options...
Roadog1aj Posted October 9, 2013 Share Posted October 9, 2013 27,956 miles so far on my '11. No issues what so ever. 2 trips to Florida in the last 6 weeks. Had a blast carving through the mountains each time!! I've performed all of my own maintenance so far, but I will probably take it in for it's 30,000 mile maintenance. Link to comment Share on other sites More sharing options...
glock_19 Posted October 9, 2013 Share Posted October 9, 2013 Got 60k. Just had it inspected for rare shudder when shifting from park to drive. Only happens when hot/hot outside. They checked fluid and test drove. No problems. Other people have reported same. The mechanic said 10-12 the cvt was better built and has had no problems. Do get slight electric buzz through radio but that could be poor electrical shielding. Did he said why/how the first gen CVT is built better? I intentionally waited until the second gen CVT to buy my Subaru because I assumed they wouldn't make the CVT worse. Link to comment Share on other sites More sharing options...
PoManzAWD Posted October 9, 2013 Share Posted October 9, 2013 Did he said why/how the first gen CVT is built better? I intentionally waited until the second gen CVT to buy my Subaru because I assumed they wouldn't make the CVT worse. I wouldn't sweat it glock. The only thing you hear is the newer generation CVTs are "lighter". They're just trying to gain some fuel economy. Link to comment Share on other sites More sharing options...
hmmrdwn Posted October 10, 2013 Share Posted October 10, 2013 Did he said why/how the first gen CVT is built better? I intentionally waited until the second gen CVT to buy my Subaru because I assumed they wouldn't make the CVT worse. He said they really lightened it up and made it smaller. He thought Subaru went overkill to prevent problems. He couldn't believe how well the inside of the first gen was made. Quality materials finished like you wouldn't believe. He said the chain/belt is so smooth its unreal. I didn't get into specs or anything and just talked in general. Link to comment Share on other sites More sharing options...
Oaklyman Posted October 10, 2013 Share Posted October 10, 2013 Do the front and rear differentials on the CVT unit share fluid or are they separate units? Link to comment Share on other sites More sharing options...
rainman Posted October 10, 2013 Share Posted October 10, 2013 5600 on my '13 leggy sport...only thing i have noticed is a clunk/clank on a cold start when it shifts from 1-2 after backing out of the garage... Link to comment Share on other sites More sharing options...
PoManzAWD Posted October 10, 2013 Share Posted October 10, 2013 5600 on my '13 leggy sport...only thing i have noticed is a clunk/clank on a cold start when it shifts from 1-2 after backing out of the garage... Are we talking when you "manually" shift your CVT with the paddles? Link to comment Share on other sites More sharing options...
laz Posted October 10, 2013 Share Posted October 10, 2013 Are we talking when you "manually" shift your CVT with the paddles? +1 because there is no shifting in a CVT. Unless he means going from reverse to forward?  X --- Link to comment Share on other sites More sharing options...
hmmrdwn Posted October 10, 2013 Share Posted October 10, 2013 Do the front and rear differentials on the CVT unit share fluid or are they separate units? Front diff is between cvt and engine. There is a drain plug and overfill plug. On top passenger side is a dipstick with a breather tube. Takes 1.7 75w-90 fluid. Rear diff has drain and fill. Takes .7-.8 75w-90. Separate units.  I guess that could be a valid question since Honda uses fluid from the front to actuate the rear for their fwd based reactive awd. Link to comment Share on other sites More sharing options...
rainman Posted October 17, 2013 Share Posted October 17, 2013 Are we talking when you "manually" shift your CVT with the paddles? nope. simply reverse out of garage, stop, put into drive...it hesitates a split second, then a slight click/clunk when, i am assuming, it shifts from 1st-2nd... Link to comment Share on other sites More sharing options...
ehsnils Posted October 17, 2013 Share Posted October 17, 2013 No such thing on the CVT, just a slight jerk when the lock-up engages. Link to comment Share on other sites More sharing options...
cypher89 Posted October 18, 2013 Share Posted October 18, 2013 95000, no issues. May break down and change fluid when I do the timing belt. Link to comment Share on other sites More sharing options...
Almatti Posted October 20, 2013 Share Posted October 20, 2013 Close to 70K on our 2010 Legacy 2.5i Premium. Changed the CVT fluid for 2nd time - convinced by Dealer to do it. i argued that the Subaru manual indicates that the fluid should be good for 100k (?), I think. But under the circumstances of lots of stop and go traffic, it is recommended to chnage the CVT Tranny fluid every 36K according to my dealer. Not sure if its BS. i also changed all the Diff oils 2 X as well. Â No issues with the CVT at all. After getting used to a CVT, I think it's a Good Thing. Getting an average overall MPG of about 26.5 with plenty of mixed city, suburban and highway driving. My son drives the car primarily, and he's not too soft on the gas pedal....When I fill er up and drive it on occassions, normal commuting runs of 40 miles with 75% highway (with some traffic - Hey it's NY) and 25% Suburban / City driving - I"ll get 31 on the MPG screen. Link to comment Share on other sites More sharing options...
svxy Posted October 20, 2013 Share Posted October 20, 2013 Took my 2010 in for a a shutter on the down shift between 4 and 3. Was in highway construction and did many speed ups and slow downs and I noticed the shutter. Dealer could not replicate, but its on the books in case it gets worse past warranty. 41,000 miles. Recently drove a 2013 and quick observation is that the 2013 was quieter and more responsive. On the down side it felt like a manual transmission as you accelerate it will accelerate better but it also resists like a manual as you decelerate...not as smooth as the 2010. Link to comment Share on other sites More sharing options...
ehsnils Posted October 20, 2013 Share Posted October 20, 2013 Just passed 5000 km on mine. Link to comment Share on other sites More sharing options...
