Redryan98 Posted September 10, 2013 Share Posted September 10, 2013 I've got an 07 LGT and noticed recently that the passenger side sits about 1/4" higher than the driver side (determined by measuring the wheel gab under both fenders). It was like this with both the stock suspension and the JDM Bilsteins I just installed. Is there something else I should be looking at that might cause this? Link to comment Share on other sites More sharing options...
GEORGEROV Posted September 10, 2013 Share Posted September 10, 2013 Quote : " Is there something else I should be looking at that might cause this? " Unquote . The weight of the driver ? . Link to comment Share on other sites More sharing options...
Max Capacity Posted September 10, 2013 Share Posted September 10, 2013 Did you replace the springs with the new shocks ? It's your fat butt that has caused the drivers side springs to sag. Some thing happens with Civic's over the years. The quick fix is put 150lbs of weight on the passenger side floor. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Redryan98 Posted September 10, 2013 Author Share Posted September 10, 2013 Thanks, though I'm not sure driver weight has anything to do with the weight of the driver. The car only has 50k miles on it and both shocks/springs were replaced last weekend with the same result. The driver side does have the battery/washer container on it so there is a tad bit more weight on that side, maybe that is partially to blame. Does anyone else's car do this? Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 10, 2013 Moderators Share Posted September 10, 2013 I definitely know of at least one other car that does this--not sure why though. He has done a complete spec.b swap as well and the issue persists. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Redryan98 Posted September 10, 2013 Author Share Posted September 10, 2013 Also think maybe if the alignment is off it might make a slight difference, or perhaps something in the suspension is tweeked. I'll have to take another look Link to comment Share on other sites More sharing options...
Redryan98 Posted September 10, 2013 Author Share Posted September 10, 2013 I definitely know of at least one other car that does this--not sure why though. He has done a complete spec.b swap as well and the issue persists. Strange. Might just be an excuse to do coilovers so I can even out the ride Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 10, 2013 Share Posted September 10, 2013 Are you sure nothing on the suspension is bent? Are you the original owner or did you buy it used? Maybe ask for the CarFax on it. Link to comment Share on other sites More sharing options...
landark Posted September 10, 2013 Share Posted September 10, 2013 Mine's the same way. I replaced the springs before I noticed it - not that it didn't before. I had hoped new shocks would level it out. It didn't. I eventually stopped caring. Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 10, 2013 Share Posted September 10, 2013 OK...since both of you have the same problem. Is it on both the front and rear wheels? Maybe you could find some used top hats and cut the inside and studs out of them and make a small spacer you could put in above the top hat. Or you could have a shop cut you a piece of 1/4" steel and cut it out to fit the bolt pattern and top hat center hole. There is plenty of stud sticking through that you could still fit the top nuts on. Just an idea. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 10, 2013 Share Posted September 10, 2013 Put more air in the tires on that side. LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitetiger Posted September 10, 2013 Share Posted September 10, 2013 Some cars are like this and it has to do with manufacturing tolerances and the way to unibody is formed. the chassis is level but the body isnt. 1/4" is not too bad. if you are that picky, spacers or coil overs will solve it. Link to comment Share on other sites More sharing options...
Redryan98 Posted September 11, 2013 Author Share Posted September 11, 2013 I appreciate the info! Car was purchased use but had clean carfax, though you never know 100%. Sounds like it happens from time to time. Every car will have their quirks Link to comment Share on other sites More sharing options...
Danteneon Posted September 11, 2013 Share Posted September 11, 2013 I definitely know of at least one other car that does this--not sure why though. He has done a complete spec.b swap as well and the issue persists. That would be me. At first I thought is was just my fat ass causing the issue, but I have been since told no I have yet to measure each side to see the what the difference is, but it is noticeable by eye. No suspension damage on my car either. I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
GEORGEROV Posted September 12, 2013 Share Posted September 12, 2013 Thinking about this again I notice whenever I jack my car up EXACTLY under the front crossmember , that the right hand side is a couple of inches higher than the left at the front sills , relative to the ground . Garage floor is flat and level and both my Outbacks are the same in this respect . Seems that there is more weight on left hand side relative to the centreline of the vehicle . Link to comment Share on other sites More sharing options...
idiot4hire Posted September 12, 2013 Share Posted September 12, 2013 After i set my car down when i jack it up the one side sits higher with my HD's. it looks like a outback until I drive it again. Link to comment Share on other sites More sharing options...
ResidentRedneck Posted September 13, 2013 Share Posted September 13, 2013 mine does the same thing, turns out my lca is slightly bent. Link to comment Share on other sites More sharing options...
