Max Capacity Posted September 5, 2013 Share Posted September 5, 2013 Ok how do I fix this ? Just went to fill the tank, pull up the lever, feel it pull the cable, door won't open. I did a quick search. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SCASEYS Posted September 5, 2013 Share Posted September 5, 2013 butter knife I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
Max Capacity Posted September 5, 2013 Author Share Posted September 5, 2013 Yea, when the GF get's home I'll take the plastic tool and have her pull the lever while I try the door. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 5, 2013 Author Share Posted September 5, 2013 Stuck a 1/2 ratchet under the lever to hold it up, used the plastic trim tools to pry the door open. The car just came from the body shop, the gas door looked a little off centered. May the buffer hit it to hard. Also the gas cap cord broke a little while back it may have bee caught in there some where. A pry of cutting pliers fixed that cord. It's open now, I'll close it after I fill the tank... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted September 5, 2013 Author Share Posted September 5, 2013 Tank is full. Door works good. I'll go oil the hinge now. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTEASER Posted September 5, 2013 Share Posted September 5, 2013 Thanks for the play-by-play. Informative. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
FJuan Posted September 5, 2013 Share Posted September 5, 2013 Glad we could help. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
rob-2 Posted September 5, 2013 Share Posted September 5, 2013 Have this happen after high speed runs on really hot days. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 5, 2013 Author Share Posted September 5, 2013 Thanks you guy's were a big help...LOL I'm thinking about taking the wagon to Mt Washington this weekend. It kind of bummed me out that I couldn't get the door open. The other option was drive the 86' F150 to work tomorrow and drop it off at the body shop where the Spec B is getting a new rear bumper cover. It will be done tomorrow. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
GTEASER Posted September 5, 2013 Share Posted September 5, 2013 Have this happen after high speed runs on really hot days. Caused by the vacuum from the fuel pump. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 5, 2013 Share Posted September 5, 2013 Caused by the vacuum from the fuel pump. Either that or it's the Mumunson Volpolizer leaking at the festerus valve and that causes undue friction on the cable.... Link to comment Share on other sites More sharing options...
rob-2 Posted September 5, 2013 Share Posted September 5, 2013 Caused by the vacuum from the fuel pump. ha! I think the added heat of 100f cases the cable to stretch just enough to be a problem Link to comment Share on other sites More sharing options...
Max Capacity Posted September 10, 2013 Author Share Posted September 10, 2013 Next update, wouldn't open again. Used the above trick to get it opened and then bent the flat spring so it has more tension in it. Open's pretty well now....will update again if if stops working. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 10, 2013 Share Posted September 10, 2013 Glad we could help. Link to comment Share on other sites More sharing options...
rob-2 Posted September 10, 2013 Share Posted September 10, 2013 Next update, wouldn't open again. Used the above trick to get it opened and then bent the flat spring so it has more tension in it. Open's pretty well now....will update again if if stops working. Where is the spring? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 12, 2013 Author Share Posted September 12, 2013 It's more of a L shaped piece of metal by the hinge. It has the black plastic cap on it. Look where the door closes in the middle of the door by the edge. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Bbc84 Posted September 13, 2013 Share Posted September 13, 2013 Might be the cable is stretched out. On my old accord I had to replace the cable. Link to comment Share on other sites More sharing options...
specialB Posted September 13, 2013 Share Posted September 13, 2013 Ah bastards this just happened to me for the third time last night! My hinge does feel stiff though, maybe some spray lube will do the trick...for now. Sent from my HTC6500LVW using Tapatalk 2 Link to comment Share on other sites More sharing options...
Max Capacity Posted September 13, 2013 Author Share Posted September 13, 2013 Worked fine today when I put gas in her. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted September 13, 2013 Share Posted September 13, 2013 How often do you fill up? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 13, 2013 Author Share Posted September 13, 2013 At least once a week, this time of year. Once skiing starts it's twice to three times a week or 8 or 9 day's. Today it was $56.00. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 14, 2013 Share Posted September 14, 2013 Today it was $56.00. Last week, fill up was 110 USD Link to comment Share on other sites More sharing options...
ehsnils Posted September 14, 2013 Share Posted September 14, 2013 Last week, fill up was 110 USD I know the feeling. Last monthly invoice for fuel was $570... Link to comment Share on other sites More sharing options...
xt2005bonbon Posted September 14, 2013 Share Posted September 14, 2013 I know the feeling. Last monthly invoice for fuel was $570... Yeah. It sucks indeed.. Luckily I ride my bike to work and do about two fill ups per month. Still 220 USD though Link to comment Share on other sites More sharing options...
laz Posted September 14, 2013 Share Posted September 14, 2013 My gas door is doing the same. Took it to the dealer, they fixed it in 5 minutes, but it stopped working again in the third fill up. It is annoying as hell! X --- Link to comment Share on other sites More sharing options...
