GTO5005 Posted August 27, 2013 Share Posted August 27, 2013 I have just started to hear a like whistle noise is the best reference to explain it under acceleration. I did notice that the last two years my turbo under stage 2 is only putting down 8 to 9.5lbs of boost. Car has only 45,652 miles on it. Thought it might be my blowoff valve considering I hear it from the driverside. I do not get the noise when I sit at a stand still and rev it up. Is that damn VF40 turbo ready to blow again?, is that a funny spooling noise I'm hearing? Please advice. I have found the post back from 2008 that member's are still commenting on about having blown turbo's and how the dealers for the most part cover the repair. THe motor in this car has already been replaced from the previous owner at 34,000 miles. Link to comment Share on other sites More sharing options...
PtPixel Posted August 27, 2013 Share Posted August 27, 2013 You wont hear anything whistling at stand still because there's no load on the engine. no load = no boost, you're basically idling at a high rev Link to comment Share on other sites More sharing options...
GTO5005 Posted August 27, 2013 Author Share Posted August 27, 2013 Is the damn turbo going? I did not see a crack or anything loose under the hood to cause that noise someplace else. Link to comment Share on other sites More sharing options...
Gex Posted August 27, 2013 Share Posted August 27, 2013 Paging Max Capacity.... Max Capacity to the white courtesy phone please..... Whistling when it didn't whistle before is bad. Best bet is pull the downpipe and check for shaft play. Link to comment Share on other sites More sharing options...
JJr Posted August 27, 2013 Share Posted August 27, 2013 A new motor @34k, and new turbo within the last 11k amazing. I'm knocking on wood. I guess there is something to stay stock, stay happy. I hope it's not something major. I'd surely be pissed though. GL Link to comment Share on other sites More sharing options...
GTO5005 Posted August 27, 2013 Author Share Posted August 27, 2013 It was in stock form when the motor blew and turbo went the first time. Link to comment Share on other sites More sharing options...
JJr Posted August 27, 2013 Share Posted August 27, 2013 It was in stock form when the motor blew and turbo went the first time. WOW!! Link to comment Share on other sites More sharing options...
PtPixel Posted August 27, 2013 Share Posted August 27, 2013 Does it sound like a mechanical whistle or air escaping whistle? If the latter then my (optimistic) guess would be BOV or wastegate, you're still making boost just not as the pressure's you should be - you're losing pressure somewhere. Gex is right though, checking the turbo for shaft play should be the first thing to do - make sure that's not going to go => most expensive fix Link to comment Share on other sites More sharing options...
chato Posted August 27, 2013 Share Posted August 27, 2013 sounds like you have a boost leak and your computer has defaulted to wastegate spring pressure. but still check for shaftplay. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2013 Share Posted August 27, 2013 A whistle is not good. Before you start the engine again, do a boost leak test. Put a pint size paint can in the hose off the air filter box, Pull the small hose off the BOV and give it a quick blast of air from a compressor. Put your thumb over the hose and listen for leaks. Hopefully your tmic is leaking. If not, you need to pull the down pipe and check the turbo for shaft play. Do not start the engine until you do those test. If the turbo is making the noise you'll risk putting metal into the oil system. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RabidWombat Posted August 28, 2013 Share Posted August 28, 2013 If suddenly let off the gas after revving the engine under load do you hear the whine spin down? If so, its the turbo. Best test is floor it up to ~40, then let off the gas and shift to Neutral. The boost will drop instantly, the turbo will take 2-3 sec to spin down. Link to comment Share on other sites More sharing options...
GTO5005 Posted September 2, 2013 Author Share Posted September 2, 2013 It was the turbo inlet, it came loose off the turbo, I have put it back up tight again and did not tightned it down as much, seems to be holding on better, tighter I guess on that Perrin inlet tube does not mean better grip with the material its made of. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 2, 2013 Share Posted September 2, 2013 if it pops off again, try some hair spray on the surface, it helps the hose to stick to the metal. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PtPixel Posted September 2, 2013 Share Posted September 2, 2013 good to hear it was an easy fix Link to comment Share on other sites More sharing options...
LatentWagen Posted September 3, 2013 Share Posted September 3, 2013 I have just started to hear a like whistle noise is the best reference to explain it under acceleration. I did notice that the last two years my turbo under stage 2 is only putting down 8 to 9.5lbs of boost. Car has only 45,652 miles on it. So this has been going on for two years? :huh: I'm hoping that you meant "gears," not "years." LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
chato Posted September 3, 2013 Share Posted September 3, 2013 make sure you reset the ECU, sounds like you are in limp mode at those boost levels. Link to comment Share on other sites More sharing options...
