Gear oil + rear diff oil ?
mikesubie13
Hey everyone plan on doing the transmission and rear diff service on my legacy gt 5spd 2005 . Want to use the motel 75w90 gear oil . Was wondering if anybody esle is using it and have pros and cons ? Also for the rear diff will I need any kind of a LSD addictive or fluid ? Or just the gear oil is fine ? Thanks guys
I run Motul Gear 300 75w90 mixed with Redline light shockproof. This is what Andrewtech recommends for the 5-speed and it works great in cold weather.
For the rear diff, the stock R160 is a sealed viscous unit, so you can run any 75w90 back there. A quart of Motul is fine for the rear diff.
I support all of this.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
Don't use Mobile 1 gear oil, you will get the famous 4th gear grind. I did, and switch back to Extra S and never had a problem since.
Truf, but I had problems with Mobil 1 not Moblie 1 :lol:
Extra S is magic.
I never used Moblie 1 oil either. :lol:
It's a double fail.
My wife's balls are delicious.
What's the ratio of Motul 300 75w90 to Redline Lightweight Shockproof?
Make that 3 qt's redline and the .8 of the Motul.
Or Extra S if the tranny shifts fine.
Here's the best $130 I've spent lately.
http://i185.photobucket.com/albums/x40/92Si/DSCN5242_zps79584338.jpg
Engine Build - Click Here
I run 50/50. I think that is what Andrewtech recommends also
It depends on the person.
I've run both 50/50 and 75/25 LWSP to Motul with spectacular results.
Any of you guys running the mix of both lubes is it because you started to have issues with shifting or grinding ? Or just running it because you feel it's the best fluid combo? I don't have any issues with my transmission just wanted to upgrade to a good fluid. I autocross and run the 1/4 mile with the car , plus daily driving .
I ran it because it's a good combo. Put it in my Outback almost right away.
When I did my clutch I used the Walmart synthetic fluid as it was the only thing I could find locally in enough quantity to do the job. :(
I was having serious issues getting into 1st gear even when creeping up to a light but not fully stopping. I finally switched to Extra-S and that problem went away. I was pretty surprised but I think I will stick with the Extra-S going forward. I used it in the trans/front diff as well as the rear diff.
I have Extra S in the transmission and Castrol Syntrax LSD in the rear diff. The transmission is so smooth with the Extra S compared to whatever was in there when I bought it. Difference was night and day.
Instead of starting a new thread and without searching.. A guy locally is selling 5qts of Amsoil Synthetic Manual Synchromesh Transmission Fluid on Craigslist.
That's not the same thing as the redline LWSP mentioned above is it? Can I use it in my 5mt with the quart of extraS I have sitting around?
Nvm : straight from BAC "You should NOT use Synchromesh in a Subaru 5MT. Synchromesh is a fluid intended for gearboxes requiring GL-4 fluids."
  • 4 weeks later...
The dealership can only get you 5 gallon drums.
The following vendors sell 1qt bottles. There may be more vendors that sell it by the quart, but these are the first guys that come to mind.
Fred beans subaru out of PA
http://www.fredbeansparts.com/subaru-75w90-extra-s-gear-and-transmission-quart-bottle.html
Infamous Performance out of CA
http://www.infamousperformance.net/servlet/the-612/Subaru-75W90-Extra-dsh-S-Gear/Detail
AZP out of NJ doesn't sell it by the quart, but they do sell it by the gallon.
http://azpinstalls.com/web/index.php/products/maintenance
