G5892 Posted August 21, 2013 Share Posted August 21, 2013 This problem has randomly appeared and dissapeared from time to time. When I start my car for the first time of the day, I get a some smoke coming out of the hood for the first 20 minutes of driving. It smells like burning oil. I've read about the possibility of it being the pcv line or a valve cover gasket, but I just wanted to get some more opinions. Thanks for the help and please excuse the bad grammer. I'm typing this in a hurry. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 21, 2013 Moderators Share Posted August 21, 2013 You need to poke around in the engine bay--from the sound of it you should be able to identify the source of the leak fairly easily. Sounds like it's dripping on your exhaust manifold or up pipe. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
G5892 Posted August 26, 2013 Author Share Posted August 26, 2013 Ive been looking around the engine bay the last couple of days, and I think I may have found the problem. I have a fmic now and I can see some burned black marks around the turbo to IC pipe connection. I still can hit the targeted boost properly, but I think oil may be blowing out of their while the car is warming. Then when things heat up, the gasket expands and closes that connection. I think I've messed up one of the screw holes on the turbo a while back; the screw cant really tighten all the way (aluminum). Im gonna talk to a shop and see if they can tighten down those bolts. Btw, the gasket I'm using is that thermostat gasket for the chevy truck. Ill try to post some pictures. Link to comment Share on other sites More sharing options...
G5892 Posted August 26, 2013 Author Share Posted August 26, 2013 After inspecting the pictures a bit more, there is also a possibility of that t-clamp not being tight enough. But here are the pics. Its a FMS fmic btw. Link to comment Share on other sites More sharing options...
G5892 Posted September 16, 2013 Author Share Posted September 16, 2013 As much as I wanted it to be something else, it turned out to be the passenger valve cover gasket. $200 replacement wasn't too bad. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted September 17, 2013 Share Posted September 17, 2013 $200 ! I'm such a penny pincher. Lol. $25 and two hours of my time and I had mine done Link to comment Share on other sites More sharing options...
G5892 Posted September 17, 2013 Author Share Posted September 17, 2013 $200 ! I'm such a penny pincher. Lol. $25 and two hours of my time and I had mine done I didn't trust myself lol. Link to comment Share on other sites More sharing options...
12sechatch Posted September 17, 2013 Share Posted September 17, 2013 It is all relative. I value my two hours much more than $200. Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 18, 2013 Share Posted September 18, 2013 I never see the Tour de France guys smoking while warming up......Doesn't sound like a good idea to me.. Link to comment Share on other sites More sharing options...
doobaruGT Posted September 18, 2013 Share Posted September 18, 2013 Just wanted to comment with similar issues. It doesn't happen to me during warmup, but rather after a short drive. I'll come to a stop light and some smoke will billow out (not in great proportions, but enough to concern you). It doesn't happen often at all so I thought, let me check the inner CV boot, maybe it's spraying grease on the DP. I checked and boots are good, however, I did see some oil on the valve cover rear bottom corner, with burnt drip marks on the UP. Sound like a VC gasket to you fellas? Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
chato Posted September 19, 2013 Share Posted September 19, 2013 +1 VC gasket Link to comment Share on other sites More sharing options...
G5892 Posted September 19, 2013 Author Share Posted September 19, 2013 Yea that sounds like it could be the VC gasket man. Especially since you found the burnt marks. Good luck. Link to comment Share on other sites More sharing options...
doobaruGT Posted September 19, 2013 Share Posted September 19, 2013 Yea that sounds like it could be the VC gasket man. Especially since you found the burnt marks. Good luck. Yea I'm guessing so, my shop is going to have a look since I'm having tires mounted tonight. I just want's sure if there was somewhere else I should be looking. At 163K, I guess it's time to expect these things. Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
