Jduke Posted August 15, 2005 Share Posted August 15, 2005 Not sure if this has been talked about... I did a search. Anyhow was installing front sway bar (I don't think I would have noticed if I had not done this) and noticed what I thought was oil residue all over the front underside of the car, but It was very evenly applied from the plastic protected area (oil filter/drain plug area) back. I looked real close to see if it was leak, nothing coming from the filter area and drain plug area were clean clean. Checked the trans oil, and it was full - smelly but full. So Im not sure what happened. It does not smell like oil or trans fluid but My first thought was trans leak or oil leak. But then I thought maybe some type of protection spray? Any ideas? John D. Link to comment Share on other sites More sharing options...
rao Posted August 15, 2005 Share Posted August 15, 2005 It is normal. Some sort of protectant. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Jduke Posted August 15, 2005 Author Share Posted August 15, 2005 If it is protectant, why doesn't it go all the way back? has anyone shown any pics of this stuff before? thanks. Link to comment Share on other sites More sharing options...
rao Posted August 15, 2005 Share Posted August 15, 2005 Got me, but they all have it. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
wukindada Posted August 15, 2005 Share Posted August 15, 2005 Talk about a mess...I removed the goopy sh1t from the surface of all my mechanical pieces. The car looks much cleaner to me now;) A little tip if you plan on doing this, use WD-40 & plan on @ least 2-3hours Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Jduke Posted August 15, 2005 Author Share Posted August 15, 2005 ah ha your def talking about the same stuff. def a mess. Good to know its supposed to be there, can't believe I never noticed it before. thanks guys, I will be able to sleep tonight... Link to comment Share on other sites More sharing options...
racerdave Posted August 16, 2005 Share Posted August 16, 2005 Yeah, that stuff must be on all of them. I got my son a cool little remote control go-kart and he kept driving it under the car while getting used to it. Kept getting the poor little Jeff Gordon driver's helmet all full of the stuff. Link to comment Share on other sites More sharing options...
mele63 Posted August 16, 2005 Share Posted August 16, 2005 You'll also find it on the inside of your front wheels (and tires if you look closely). I sure hope they have a robot spraying on that sh#t at the factory; talk about a nasty job! Link to comment Share on other sites More sharing options...
rallispec Posted August 16, 2005 Share Posted August 16, 2005 its cosmoline (rust protectant) turns black becuase it's sticky and dirt and grime stick to it. (it's a yellowish tint normally) Link to comment Share on other sites More sharing options...
wukindada Posted August 16, 2005 Share Posted August 16, 2005 It is truly a pleasure not having to deal with snow;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Jduke Posted August 16, 2005 Author Share Posted August 16, 2005 This stuff was not on your car? grrrrr Link to comment Share on other sites More sharing options...
