KCwagon Posted September 2, 2013 Share Posted September 2, 2013 The half inch wide ring of rust, that will form around the unswept portion of the rotor, should be plenty distracting. Link to comment Share on other sites More sharing options...
Cone_Killer Posted September 3, 2013 Share Posted September 3, 2013 I just saw this thread recently. I've been working on this for a while, onto the rears now. Link to comment Share on other sites More sharing options...
hybridandy Posted September 6, 2013 Share Posted September 6, 2013 Great, now I'm going to have an even harder time finding a set to bolt onto my S13. Link to comment Share on other sites More sharing options...
Sideways the Seven Posted September 6, 2013 Share Posted September 6, 2013 So would this same setup be possible on the smaller OBXT rotor? Sent from my SGH-T699 using Tapatalk -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Cone_Killer Posted September 6, 2013 Share Posted September 6, 2013 Not with the KNS front bracket. Your pad won't seat properly onto the face of the rotor. Link to comment Share on other sites More sharing options...
Sideways the Seven Posted September 6, 2013 Share Posted September 6, 2013 Hmm... I may just need to stick to the LGT upgrade idea. Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
boxkita Posted September 9, 2013 Share Posted September 9, 2013 Not with the KNS front bracket. Your pad won't seat properly onto the face of the rotor. if KNS were to remake the bracket, this caliper might fit the OB discs better with its smaller diameter. not so much unswept area Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
AZP Installs Posted September 10, 2013 Share Posted September 10, 2013 News flash... The OB brakes are the same rotors as the WRX. So your better bet is to just get 06-07 WRX front brakes or the FHI 4-pots and call it a day. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
Sideways the Seven Posted September 10, 2013 Share Posted September 10, 2013 News flash... The OB brakes are the same rotors as the WRX. So your better bet is to just get 06-07 WRX front brakes or the FHI 4-pots and call it a day... Ah, interesting. Did not know that. Thanks! Sent from my SGH-T699 using Tapatalk 2 -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
AZP Installs Posted September 10, 2013 Share Posted September 10, 2013 Ah, interesting. Did not know that. Thanks! Sent from my SGH-T699 using Tapatalk 2 Yup, the 02-07 WRX Rotors are a hair thinner. The OB ones are the same part number as the 08+ WRX. All of them clear the FHI/06-07 WRX 4-pots. -Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/145749898/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Now we have an Online Catalog where you can purchase Parts! AZPParts.com Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 11, 2013 Share Posted September 11, 2013 Probably have easier wheel fitment too with the stock 4 pots. Link to comment Share on other sites More sharing options...
starionesir Posted September 12, 2013 Share Posted September 12, 2013 Had a friend talk to kns and they no longer make the brackets so this option won't last long unless someone else takes the bracket and copies it. Link to comment Share on other sites More sharing options...
Cone_Killer Posted September 13, 2013 Share Posted September 13, 2013 I just ordered a pair yesterday, should be here today. Link to comment Share on other sites More sharing options...
jfg22557 Posted October 4, 2013 Share Posted October 4, 2013 Going to bump this thread with a relevant question to avoid starting a new thread. I run the FHI 4 Pots up front with 06 WRX rotors, and currently have a pair of rear FHI 2 pots on the way. Cone_Killer, I read in your thread that you attempted to use a WRX backing plate for the rear, just curious as to why? Do the 2 pots (whether they be the nissan or FHI) not fit with the LGT rear backing plate? I dont believe I'm missing anything else, thanks for the info. Link to comment Share on other sites More sharing options...
Cone_Killer Posted October 4, 2013 Share Posted October 4, 2013 Going to bump this thread with a relevant question to avoid starting a new thread. I run the FHI 4 Pots up front with 06 WRX rotors, and currently have a pair of rear FHI 2 pots on the way. Cone_Killer, I read in your thread that you attempted to use a WRX backing plate for the rear, just curious as to why? Do the 2 pots (whether they be the nissan or FHI) not fit with the LGT rear backing plate? I dont believe I'm missing anything else, thanks for the info. The Nissan/FHI rear calipers are nearly identical (nissan sits a few mm's higher). The two mounting points on the calipers are the same though. I was going to use the 06/07 back plates because they are made for the FHI calipers (ie. correct mounting points) and to keep it as OEM as possible. If you can't use these back plates, then you need to use a bracket from either Kartboy or FastWRX that will adapt the slider caliper mounting points to the ones of the nissan/FHI. You CANNOT use these back plates on the 05+ legacy but I believe you can use them on any non-sti impreza or any subaru with the same rear hub (possibly older legacy's?) Link to comment Share on other sites More sharing options...
jfg22557 Posted October 4, 2013 Share Posted October 4, 2013 The Nissan/FHI rear calipers are nearly identical (nissan sits a few mm's higher). The two mounting points on the calipers are the same though. I was going to use the 06/07 back plates because they are made for the FHI calipers (ie. correct mounting points) and to keep it as OEM as possible. If you can't use these back plates, then you need to use a bracket from either Kartboy or FastWRX that will adapt the slider caliper mounting points to the ones of the nissan/FHI. You CANNOT use these back plates on the 05+ legacy but I believe you can use them on any non-sti impreza or any subaru with the same rear hub (possibly older legacy's?) So to confirm, you cannot use the 06/07 backing plates on our cars for the FHI or Nissan rear2 pots. Meaning the only option is the rear adapter bracket. Do you have a link to the exact bracket necessary? I can't imagine its the same kartboy bracket used for the tear brembo conversion? Appreciate the help, -Jake Link to comment Share on other sites More sharing options...
KNS Brakes Posted October 4, 2013 Share Posted October 4, 2013 Oh man I didn't even know this thread exisited....SUBSCRIBED! -Nick Link to comment Share on other sites More sharing options...
KNS Brakes Posted October 4, 2013 Share Posted October 4, 2013 Had a friend talk to kns and they no longer make the brackets so this option won't last long unless someone else takes the bracket and copies it. Hmm I wonder who you talked to? We have a fresh batch coming out. They will be here on Monday! -Nick Link to comment Share on other sites More sharing options...
KNS Brakes Posted October 4, 2013 Share Posted October 4, 2013 So to confirm, you cannot use the 06/07 backing plates on our cars for the FHI or Nissan rear2 pots. Meaning the only option is the rear adapter bracket. Do you have a link to the exact bracket necessary? I can't imagine its the same kartboy bracket used for the tear brembo conversion? Appreciate the help, -Jake I believe this is what ya'll are looking for. This bracket is able to fit the Rear FHI calipers or the Rear Gold Brembos onto the rear of your: Impreza up to 07 Legacy up to 08 Forester up to 09 KNS Version 1.1 Bracket -Nick Link to comment Share on other sites More sharing options...
Cone_Killer Posted October 5, 2013 Share Posted October 5, 2013 So to confirm, you cannot use the 06/07 backing plates on our cars for the FHI or Nissan rear2 pots. Meaning the only option is the rear adapter bracket. Do you have a link to the exact bracket necessary? I can't imagine its the same kartboy bracket used for the tear brembo conversion? Appreciate the help, -Jake That is correct, we cannont use the backing plates. The brackets also won't work because the Z32 rear caliper is taller than the subaru FHI. You may be able to get the bracket and redrill the stock backing plate to lower the caliper down, however I'm not sure about this. Link to comment Share on other sites More sharing options...
KNS Brakes Posted October 5, 2013 Share Posted October 5, 2013 That is correct, we cannont use the backing plates. The brackets also won't work because the Z32 rear caliper is taller than the subaru FHI. You may be able to get the bracket and redrill the stock backing plate to lower the caliper down, however I'm not sure about this. I think the Z32 rear caliper also has a bit different offset so the LGT rear rotor would not be centered in the Z32 caliper. Our rear bracket should work w/ the FHI 2 pots though. Link to comment Share on other sites More sharing options...
TeriyakiBBS Posted November 4, 2013 Author Share Posted November 4, 2013 I rebuilt calipers with a kit from Z1 Motorsports and painted the calipers red and kept the Nissan white. I am not proud of the fitment. On the top and bottom of the caliper the edge closest to the rotors touches very slightly and rubs when driving. I had to shave down with a file to make sure it clears. $100 30mm Z32 Calipers $150 KNS Z32 Brackets $100 Centric LGT Rotors $50 StopTech Pads $30 Z32 Rebuild Kit $17 ATE SuperBlue I already have StopTech SS Brake Lines Grimmspeed BMC Brace StopTech Rear Pads and Centric Rotors http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zpsffdc4d18.jpg http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zps76e56a19.jpg http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zpsca2bd6b4.jpg http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zpsb4eb5329.jpg http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zpsa22574de.jpg http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zps12c27ba5.jpg http://i131.photobucket.com/albums/p318/FLCLgibson1968/null_zpsb7028cff.png Link to comment Share on other sites More sharing options...
KNS Brakes Posted November 4, 2013 Share Posted November 4, 2013 Looks good! Glad our bracket worked for your swap. -Nick Link to comment Share on other sites More sharing options...
TeriyakiBBS Posted November 4, 2013 Author Share Posted November 4, 2013 The calipers are not a perfect fit even with the brackets and I had to use a giant file to shave off some of the calipers closest to the rotor. After that was completed I have had little issues. Link to comment Share on other sites More sharing options...
Cone_Killer Posted November 5, 2013 Share Posted November 5, 2013 I shot you a PM^ I too had to grind mine down. Nothing that we haven't been doing in the z32 community for some time now. Install was fairly straight forward. Link to comment Share on other sites More sharing options...
