LGT_18_34 Posted August 2, 2013 Share Posted August 2, 2013 Alright so I have an auto 05 lgt I am currently stage 2 (cobb intake, grimmspeed AOS, Invidia uppipe and downpipe, and perrin top mount intercooler. topped off with a tune of course). And I am just looking for some ideas on what would be a good next step to go to from here, with the exception of a bigger turbo, because It was just replaced with the 08-09 model turbo when mine blew a few months ago... So just looking for some suggestions to give her a little more giddy up thanks ahead of time! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 2, 2013 Share Posted August 2, 2013 Brakes, then Koni yellows and springs. Hawk makes nice pads, "m sprank" has a good deal on Koni's and Epic springs if he has any left. http://www.infamousperformance.net Mike at http://www.AZPinstalls.com has some nice stuff to. I buy a lot from him. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted August 2, 2013 Share Posted August 2, 2013 Brakes - master cyl brace , stoptech pads, and new rotors, and stainless lines. Without a bigger turbo you are probably at the limits of power. Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 5, 2013 Share Posted August 5, 2013 Time to make it giddy up and turn. Whiteline LCA bushings, Front and Rear swaybars with rear swaybar supports, good swaybar end links, Koni/Epic combo is good. Wider, larger diameter wheels with less offset and stickier tires. Link to comment Share on other sites More sharing options...
PtPixel Posted August 5, 2013 Share Posted August 5, 2013 Methanol injection! That'll give you some kick Link to comment Share on other sites More sharing options...
