superbro Posted July 31, 2013 Share Posted July 31, 2013 I have searched a lot of different variations describing my problem but "car' and "wont" are too common of words for the search engine. Today I came back from the gym and let my car idle for a good 1.5 minutes, turned it off and wiped down the interior for sh!ts and gigs. I then tried to turn it over after it had been sitting for 5 minutes. The dash lights came on and went through the start-up sequence, so I cranked it and all I heard was a click and all the power cut out. After a delay of 30 seconds or so the red ignition courtesy light came back on indicating power was back; weird right? So again I tried to start it and the same thing happened only the power was off for longer. After 2 more attempts and checking for loose cables I decided to get second opinions. I think its a short but I'm not a very good mechanic so any advice or suggestions will really help. Link to comment Share on other sites More sharing options...
superbro Posted July 31, 2013 Author Share Posted July 31, 2013 There's a lot of acid build up on my pos battery post. I will clean it and say if it helped or not. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 31, 2013 Moderators Share Posted July 31, 2013 was gonna say bad battery connection before your second post... "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
superbro Posted July 31, 2013 Author Share Posted July 31, 2013 It worked. It was just weird how the dash lights would come on and off. Link to comment Share on other sites More sharing options...
ibr_adam09 Posted July 31, 2013 Share Posted July 31, 2013 Things get weird with a faulty ground. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 31, 2013 Share Posted July 31, 2013 Had this happen to me also. Just have to make sure the battery connectors provide good electrical contact, and that they are nice and tight. Link to comment Share on other sites More sharing options...
Strizzy Posted July 31, 2013 Share Posted July 31, 2013 How old is your battery? LGTs do some weird things when the battery is going bad. My bad luck build Link to comment Share on other sites More sharing options...
superbro Posted July 31, 2013 Author Share Posted July 31, 2013 I just bought this car last week private party so as far as I know it could be pretty old with as much acid tthat was on it. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 31, 2013 Share Posted July 31, 2013 Just go to Autozone. They can do a test load on your battery free of charge. Link to comment Share on other sites More sharing options...
superbro Posted July 31, 2013 Author Share Posted July 31, 2013 Just go to Autozone. They can do a test load on your battery free of charge. Right on, will do. Link to comment Share on other sites More sharing options...
jp233 Posted August 1, 2013 Share Posted August 1, 2013 Bad battery connections, and weak/intermittant ground connections can do very, very strange things to vehicles. Common on Subaru vehicles, also. Worst is a chafed wire that goes straight from the + terminal to the starter (have never seen that on a Subie, though). That sucker pulls a ton of juice. Link to comment Share on other sites More sharing options...
