Sideways the Seven Posted August 2, 2013 Share Posted August 2, 2013 Subscribed for updates and Megan reviews. -Brandon 2007 Chevrolet Suburban LT3 1981 Chevrolet C10 LWB Link to comment Share on other sites More sharing options...
Heffernan Posted August 3, 2013 Author Share Posted August 3, 2013 Ordered a bunch of Megan parts yesterday, including the camber and both lateral links. Will post results when installed. Link to comment Share on other sites More sharing options...
suds2250 Posted August 9, 2013 Share Posted August 9, 2013 Any updates on the Megan parts? 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
Scubaru03 Posted August 10, 2013 Share Posted August 10, 2013 Got mine today. They look good and feel really durable. Will install tomorrow and align Monday I'll let you guys know if any issues. I ordered mine from amazon and got Em like $25 cheaper. Link to comment Share on other sites More sharing options...
Heffernan Posted August 12, 2013 Author Share Posted August 12, 2013 Any updates on the Megan parts? I got everything in on Friday. Installing tomorrow. Link to comment Share on other sites More sharing options...
gordata Posted August 13, 2013 Share Posted August 13, 2013 Can we get some pictures of these parts installed. I want to pick up the camber arms but they say 00-09 and I have only heard about two people using them. These would replace the arms that I pressed the whiteline camber bushing? These: MRS-SU-0510 http://www.meganracing.com/uploadimage/regular/442013_183654_6259_MRS-SU-0510.jpg Link to comment Share on other sites More sharing options...
Heffernan Posted August 13, 2013 Author Share Posted August 13, 2013 ^ I'm getting those installed as well. Their replacing the KCA399 kit I have already. Link to comment Share on other sites More sharing options...
gordata Posted August 13, 2013 Share Posted August 13, 2013 Could you snap some pictures of what you are having installed when its done. Thanks Link to comment Share on other sites More sharing options...
Heffernan Posted August 14, 2013 Author Share Posted August 14, 2013 http://img.tapatalk.com/d/13/08/15/ygedu2yt.jpg Here's my setup with the new Megan goodies. Link to comment Share on other sites More sharing options...
Tehnation Posted August 14, 2013 Share Posted August 14, 2013 So wait, you can't buy whiteline rear control arms anywhere?? Are they discontinued? Link to comment Share on other sites More sharing options...
Heffernan Posted August 14, 2013 Author Share Posted August 14, 2013 Extended backorder until at least the end of next month. Link to comment Share on other sites More sharing options...
Tehnation Posted August 14, 2013 Share Posted August 14, 2013 Hmmm. I should have bought them when I had the chance. I was contemplating whiteline vs megan racing and decided to go for whiteline just because of the better customer support and poly bushings instead of rubber. But other than that I don't see any real issue with the megan racing, it is cheaper than the whiteline set, so its one of those you get what you pay for things. Â That kind of long wait and backorder probably means very limited production quantity or they are about to stop making them. Link to comment Share on other sites More sharing options...
sheppo9 Posted August 19, 2013 Share Posted August 19, 2013 So that curved arm (centre lateral link) - I doubt the bump stop can still touch it as there is nowhere for it touch. Right? Link to comment Share on other sites More sharing options...
Heffernan Posted August 19, 2013 Author Share Posted August 19, 2013 The top bar is for the camber adjustment. I don't believe its anywhere near it. Link to comment Share on other sites More sharing options...
Scubaru03 Posted August 19, 2013 Share Posted August 19, 2013 Did you have any issues aligning? Did you use the stock specs? Link to comment Share on other sites More sharing options...
Heffernan Posted August 19, 2013 Author Share Posted August 19, 2013 Alignments issues were all fixed with these new parts. Everything in spec but the camber, I decide to run a little negative in the rear. Link to comment Share on other sites More sharing options...
gordata Posted August 19, 2013 Share Posted August 19, 2013 Can't find these arm in blue, only that pink color... Where did you guys order them from? Link to comment Share on other sites More sharing options...
Heffernan Posted August 19, 2013 Author Share Posted August 19, 2013 I got mine from Import Image Racing. Link to comment Share on other sites More sharing options...
Scubaru03 Posted August 20, 2013 Share Posted August 20, 2013 Got my alignment today everything adjusted well. I ordered mine through amazon they showed blue but I still got pink. Good luck Link to comment Share on other sites More sharing options...
gordata Posted August 20, 2013 Share Posted August 20, 2013 Amazon does not show any available... Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 21, 2018 Share Posted October 21, 2018 For the megan racing lateral arm how did you lock what used to have the eccentric bolt? Link to comment Share on other sites More sharing options...
bigBADbenny Posted October 22, 2018 Share Posted October 22, 2018 Whiteline have this toe lock kit: https://www.whiteline.com.au/product_detail4.php?part_number=KCA307&sq=24450 Easy enough to diy a kit if req... Link to comment Share on other sites More sharing options...
