whitetiger Posted March 12, 2009 Share Posted March 12, 2009 I was contemplating putting the stock DP back in, but i was feeling lazy and said screw it. they passed me with out even a second look. i have EL headders with a catless turbo back exhuast and prodrive cans. the AP takes care of the ECU monitors and cat codes. I thought i would fail a vidual, but they didnt even do a visual. lucky me Link to comment Share on other sites More sharing options...
Regal05LGT Posted March 12, 2009 Share Posted March 12, 2009 That's awesome....I just recently passed catless too, but my pipe is gutted so it looks stock....didn't even check under my car either lol Link to comment Share on other sites More sharing options...
FireB Posted March 13, 2009 Share Posted March 13, 2009 Woo, I need more info on that! So you put the AP Maps to Stock or used your Pro-Tune Maps? And also, where the hell did you go to get your car to pass?! LOL I think I saw your car today in Cliffside Park, correct me if I am wrong. Link to comment Share on other sites More sharing options...
Regal05LGT Posted March 13, 2009 Share Posted March 13, 2009 Leave the maps alone....Stage 1/2/protune whatever keeps the CELs cleared so they don't register when your car gets scanned for inspection Link to comment Share on other sites More sharing options...
jerseyglock Posted March 13, 2009 Share Posted March 13, 2009 Passed my inspection back in September, they had me as Impreza. http://www.legacygt.com/forums/showthread.php?t=96295 Link to comment Share on other sites More sharing options...
whitetiger Posted March 13, 2009 Author Share Posted March 13, 2009 Woo, I need more info on that! So you put the AP Maps to Stock or used your Pro-Tune Maps? And also, where the hell did you go to get your car to pass?! LOL I think I saw your car today in Cliffside Park, correct me if I am wrong. i left the protune maps for stage 2 in. I just went the the Lodi Inspection station. I had no front plate on the car either and they still passed me. Link to comment Share on other sites More sharing options...
mikeislord Posted March 13, 2009 Share Posted March 13, 2009 Shit, I better pass in June. If you got through and I'll be going through Stg 2. Catted with stock cans. I'll flip a shit if I fail. Link to comment Share on other sites More sharing options...
FireB Posted March 13, 2009 Share Posted March 13, 2009 Doesn't it suck if you Fail the inspection? Won't they do you a more extensive test? I would have thought Lodi would be the most strict place for an inspection but, that's nice to hear! Link to comment Share on other sites More sharing options...
PhillyWilly Posted March 13, 2009 Share Posted March 13, 2009 This is nice to hear. I think Ill still go catted dp but now I better pass. If not Ill drive up to Lodi. Cape May inspection is pretty easy, tho i know they wouldve failed for no front plate. Link to comment Share on other sites More sharing options...
smokedoutv6 Posted March 13, 2009 Share Posted March 13, 2009 WT, did you do anything special before going to inspection? Some people have told me to drive around for a little bit before i go, supposedly it helps with emmission testing? I'm on a stg 2 tune with a catted 2nd section of the OEM DP. If you passed catless I should be fine. let me know if you have any "tips" though. Thanks. Link to comment Share on other sites More sharing options...
FireB Posted March 13, 2009 Share Posted March 13, 2009 What do you think about Stage 3 with bigger turbo for the inspection? Are the just gonna plug in the OBD Port and if there is no cell, that's it? Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted March 13, 2009 Share Posted March 13, 2009 Wow if Lodi is like that then ill prolly go there when i go stage 2. good to know. screw Wayne. Link to comment Share on other sites More sharing options...
whitetiger Posted March 13, 2009 Author Share Posted March 13, 2009 they didnt do a "sniffer test" as far as i could tell. they just did the obdII connecter test. I bet as long as your ECU monitors are all "ready" and you dont have and obnoxiously loud exhaust, you will pass. Link to comment Share on other sites More sharing options...
whitetiger Posted March 13, 2009 Author Share Posted March 13, 2009 WT, did you do anything special before going to inspection? Some people have told me to drive around for a little bit before i go, supposedly it helps with emmission testing? I'm on a stg 2 tune with a catted 2nd section of the OEM DP. If you passed catless I should be fine. let me know if you have any "tips" though. Thanks. nothing special. just drove there and did it. Link to comment Share on other sites More sharing options...
slimjoe Posted March 13, 2009 Share Posted March 13, 2009 Until inspection stations get all-wheel rollers we're not going to be tested with the sniffer. So until then, it's all visual and ecu. Link to comment Share on other sites More sharing options...
devobuzz Posted March 13, 2009 Share Posted March 13, 2009 It probably also depends on which tech is doing the inspection - some are more thorough than others, I would expect. Link to comment Share on other sites More sharing options...
whitetiger Posted March 13, 2009 Author Share Posted March 13, 2009 ^true. the tech in the other bay was doing a visual with a mirror on a stick with other cars, but the tech i got was just zipping cars through. you would think a car with an obviously aftermarket exhaust, lowered to the ground with obviously aftermarklet suspension parts would propt them to do a visual, but they didnt. go figure. Link to comment Share on other sites More sharing options...
smokedoutv6 Posted May 14, 2009 Share Posted May 14, 2009 just thought i'd bump and old thread....just passed NJ inspection yesterday @ Rahway DMV (TA Stg 2 Map, gutted OEM pipes, Perrin TMIC). The one thing I did notice that I hadn't before is they pop the hood and I guess look for after market air filters, etc. (not real sure WHAT they're looking for but so I'm just guessing). I was somewhat nervous since I dont have an engine cover and the perrin is just sitting there but I went through with no problems. HIDs were also not a problem. Just wanted to let everyone know. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted May 14, 2009 Share Posted May 14, 2009 Ive always seen them pop the hood. Sometimes i see em connect a computer to something. Link to comment Share on other sites More sharing options...
VXCL Posted May 14, 2009 Share Posted May 14, 2009 they didnt do a "sniffer test" as far as i could tell. they just did the obdII connecter test. I bet as long as your ECU monitors are all "ready" and you dont have and obnoxiously loud exhaust, you will pass. +1 but i prefer to just go to a private place and pay $70 because once you get a fail you are f'd!! plus i'm tinted all around so really have no choice MAYHEM #122/22 STS NNJR SCCA AUTOX4U.COM XENON RETRO GUIDE Link to comment Share on other sites More sharing options...
mikeislord Posted May 14, 2009 Share Posted May 14, 2009 So when you go to a private place, do you tell the guy exactly what you're paying not to fail for or what? I don't want to go to a guy like "Yo, I'm coming here because my tint is illegal." just to have him say, "Yup, you're right. You fail." Link to comment Share on other sites More sharing options...
brooklyngenius Posted May 14, 2009 Share Posted May 14, 2009 thats awesome!!! I remember how bad Jersey is with inspection when i lived there. Texas is almost as bad but since its handled by private shops I know some people who know some people who stick a passing car on the machine so I get a sticker! not that I need one for the LGT yet but my Honda did useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
THE RZA Posted May 14, 2009 Share Posted May 14, 2009 Doesn't it suck if you Fail the inspection? Won't they do you a more extensive test? I would have thought Lodi would be the most strict place for an inspection but, that's nice to hear! if you fail and go back when its fixed, they just check to make sure whatever you failed for is fixed and then you're good to go. Link to comment Share on other sites More sharing options...
vkchu Posted May 29, 2009 Share Posted May 29, 2009 can anybody recommend a ny inspection station for rockland cty? im stg2 catless too and my sticker is up end of june. Link to comment Share on other sites More sharing options...
bluesuby Posted May 29, 2009 Share Posted May 29, 2009 Until inspection stations get all-wheel rollers we're not going to be tested with the sniffer. So until then, it's all visual and ecu. I don't think so. Any car with OBD-2 (the past 12 model years or so) just gets the plug-in test of the on board diagnostics. About the only thing that should worry you regarding emissions is to make sure if you have disconnected or replaced the battery recently, make sure you've driven 100 miles between the disconnect date and when you take it in for inspection. The test reads the memory of the diagnostics and you need to build up a little history. The rollers in the inspection station should never be used on an AWD car. Subaru specifically warns against this and I will never permit my car to be abused by inspection station personnel. Link to comment Share on other sites More sharing options...
