Mach V Dan Posted July 14, 2007 Share Posted July 14, 2007 After not having these for a long time, they are back in stock. Tokico HTS are what I use on our own Mach V Legacy, and I think they're great. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
HansGT Posted July 14, 2007 Share Posted July 14, 2007 Link to comment Share on other sites More sharing options...
Wales Garage Posted July 14, 2007 Share Posted July 14, 2007 why yes, they are great bilstein FTL Link to comment Share on other sites More sharing options...
HansGT Posted July 16, 2007 Share Posted July 16, 2007 ^ don't knock them...heard good things. Link to comment Share on other sites More sharing options...
VTGT Posted July 16, 2007 Share Posted July 16, 2007 After not having these for a long time, they are back in stock. Tokico HTS are what I use on our own Mach V Legacy, and I think they're great. --Dan Mach V FastWRX.com shit is that price really $650? How many sets will you have, and if you run out will you restock them at that price? Link to comment Share on other sites More sharing options...
Mach V Dan Posted July 17, 2007 Author Share Posted July 17, 2007 shit is that price really $650? How many sets will you have... We have several in stock now. ...and if you run out will you restock them at that price? That's the plan, but nothing in life is certain, among them Tokico availability. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
psucaptainkickass Posted July 17, 2007 Share Posted July 17, 2007 Quick question...what's the advantage of getting these vs. getting coilovers? I am thinking about both, since I have iONs and I don't know if the stock struts are going to last that much longer. Between getting some entry to mid range coilovers and selling my iONs, the Tokico price will end up being around the same going either route. Link to comment Share on other sites More sharing options...
legacy_y_tu Posted July 17, 2007 Share Posted July 17, 2007 Dan, Is the adjustment screw on the rears on the top or bottom of the shock? Link to comment Share on other sites More sharing options...
Mach V Dan Posted July 17, 2007 Author Share Posted July 17, 2007 There are a couple of benefits to getting a normal-style shock instead of a coilover. One is that it can work with full ride-height springs, or with mild lowering springs. Many coilovers are very low even at max ride height. Another benefit is that the price is significantly lower than a set of coilovers. Finally, although not all coilovers have this problem, SOME sets can be noisy, with clunking and squeaking noises that a traditional shock/spring setup won't have. --Dan Mach V FastWRX.com Quick question...what's the advantage of getting these vs. getting coilovers? I am thinking about both, since I have iONs and I don't know if the stock struts are going to last that much longer. Link to comment Share on other sites More sharing options...
Mach V Dan Posted July 17, 2007 Author Share Posted July 17, 2007 Dan, Is the adjustment screw on the rears on the top or bottom of the shock? Top. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
psucaptainkickass Posted July 17, 2007 Share Posted July 17, 2007 There are a couple of benefits to getting a normal-style shock instead of a coilover. One is that it can work with full ride-height springs, or with mild lowering springs. Many coilovers are very low even at max ride height. Another benefit is that the price is significantly lower than a set of coilovers. Finally, although not all coilovers have this problem, SOME sets can be noisy, with clunking and squeaking noises that a traditional shock/spring setup won't have. --Dan Mach V FastWRX.com Cool thanks. I hear you on the clunking/squeaking noises...I have heard that on other cars for sure. Link to comment Share on other sites More sharing options...
poopy Posted July 17, 2007 Share Posted July 17, 2007 will these work with cobb springs? Link to comment Share on other sites More sharing options...
ping Posted July 18, 2007 Share Posted July 18, 2007 Are these monotube? Link to comment Share on other sites More sharing options...
wcbjr Posted July 18, 2007 Share Posted July 18, 2007 Clunking on coilovers are usually due to inadequate/not enough preload. The springs are jumping around. Easy fixable. The squeaking noises are usually from the collars not being tight enough. Again, easily fixable. I forgot what I was supposed to remember. Link to comment Share on other sites More sharing options...
Mach V Dan Posted July 18, 2007 Author Share Posted July 18, 2007 will these work with cobb springs? Yes. Are these monotube? No. They're a twin-tube design. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
Enlight Posted July 19, 2007 Share Posted July 19, 2007 Is a review available for these baaaad girls? muFreight.co A JDM Container Sharing Service from Japan to NYC Website | Instagram | Email Bessie II's Thread Link to comment Share on other sites More sharing options...
tougefox Posted July 22, 2007 Share Posted July 22, 2007 These still require jdm tophats correct? Do the tophats raise the car? Link to comment Share on other sites More sharing options...
Mach V Dan Posted July 23, 2007 Author Share Posted July 23, 2007 These still require jdm tophats correct? Do the tophats raise the car? No, they don't require the JDM hats. You can either use the stock LGT top hats (and then the top nut won't fully engage the shock shaft, but that's what we did on our car), or you can install USDM Spec B top hats, which will increase the ride height a little. It's up to you. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
tougefox Posted July 26, 2007 Share Posted July 26, 2007 well i have a 2.5i, will my tophats work? If not id rather just get whiteline hats bc i do not want the car raised. Link to comment Share on other sites More sharing options...
OhBe1 Posted July 26, 2007 Share Posted July 26, 2007 And we have a 2.5i LOB, the lost child of the aftermarket. Let me know if anyone tries it. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
Mach V Dan Posted July 26, 2007 Author Share Posted July 26, 2007 well i have a 2.5i, will my tophats work? If not id rather just get whiteline hats bc i do not want the car raised. I assume -- but do not know for sure -- that the LGT top hats are the same design as the 2.5i ones. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
allstar Posted July 27, 2007 Share Posted July 27, 2007 oooooh, you guys are right down the street from where I just moved:) May have to talk the wife into these..... will you be around the shop tomorrow? Link to comment Share on other sites More sharing options...
Mach V Dan Posted July 27, 2007 Author Share Posted July 27, 2007 oooooh, you guys are right down the street from where I just moved:) May have to talk the wife into these..... will you be around the shop tomorrow? Yes, we're open 12-5 tomorrow. I'll probably be there until 4. --Dan Mach V FastWRX.com Link to comment Share on other sites More sharing options...
flash_gordon Posted February 27, 2008 Share Posted February 27, 2008 Just to clarify from all the reading I have been doing: Tokico HTS Spec B Top hats Cobb Springs Cobb is listed 1.75 F, 1.0 R. With Spec B top hats the front will be up .5 more so in theory I should be sitting 1.25 F, 1.0 R,.... Is this correct logic? Locking to lower a bit, stiffen up the ride and still leave room for 18's down the road. Are the Cobbs to soft for the HTS's or would something else work better? Forgive me if this has been answered already, my head is spinning with all the different options. Thanks, Shawn Hey first post Crap, is the d-spec the fix? Just found them.... Link to comment Share on other sites More sharing options...
mylgt1 Posted February 27, 2008 Share Posted February 27, 2008 Is there a difference between the hts and the d-specs Link to comment Share on other sites More sharing options...
